[ROM][ICS Sense 4][21 April]RCMixSmartD Faster Smoother Better Tweaks, MMS
MarciWoi
MarciWoi
Dauergast
191
Changelog 2.1
-changed all the lib's system for a better performance
-changed an huge amount of key libs,etc,and bin files for a better system management
-revised all the build.prop tweaks for a better launcher management in terms of fps, and better tweaks performance
-updated a lot of system app to fit the new speed tweaks
-removed batt% due to request
-added new better drivers for touch responsive management
-removed nova launcher
-added Apex Launcher
-added Google Reader
-added aosp Sense 4 clocks widgets for a bit of Sense experience for aosp launcher lovers
-added @XxXPachaXxX as a new team member for a better team experience LOL
-updated internal app's
-more clean up's to the base
-something I can't remember now
Changelog:
RCMixSmartDroid v1.0
fixed rotation issue in RCMix Tweaks
fixed build.prop for Sensation, 4g and xe users
fixed genie.apk lack, now you got it
updated SU binary
updated Busybox
updated bash binary
updated kernel to 5.4
fixed sweep to unlock freezes for all users (please report us)
BassMod v1.6 xLOUD & Beats Audio & Dolby Digital (thx and credits to @bassini)
added Dolby Mobile app 1.1 with fix ( (thx and credits to @bassini)
added simtoolkit.apk
more clean ups i can't remember now
RCMixSmartDroid v0.1
Based on 1.53.401.2 CL47230 release-keys (thx baadnewz for the base)
Sense 4.0
Android 4.0.3
Tmous 4g users Support
rooted
busybox
DeOdexed
4Ext support
Multilanguages support
zippaligned for a better ram management
removed useless stuff
Beats Audio (with headphones)
Custom boot animation
Bravia Engine
HQ Camera for Sense4 (thx NODO-GT)
Speed Tweaks
Tweaked build.prop(memnoc)
init.d support
spywarefree(memnoc)
bloatwarefree(memnoc)
updated internal apps
RCMix kernel 5.3 by klquiksall
RCMix Tweaks (thx j4n87)
TRUE APM menu(thx j4n87)
Blocklist/secure sms (thx Capychimp)
FIXED mms drop signal (thx Capychimp, pm me for usage)
FIXED search button function
FIXED Partially Bluetooth ( thx mdeejay for first fix, thx memnoc for second part)
FIXED most lags in homescreens(memnoc)
FIXED weak aptic feedback
FIXED meta-inf+boot.img issues (memnoc)
Good support
Bugs:
Wifi Hotspot
HDMI Out
Download:
http://forum.xda-developers.com/showthread.php?t=1611293
Grüße Marcel
PS: Und nicht vergessen Danke zu drücken wenn euch der Rom gefällt :)
Reaktionen: ruhL und xXXSchokiXXx
Werde es jetzt mal drauf hauen und später dann sagen was ich davon halte, aber rein vom lesen hört es sich gut an !
Grüße Marcel
Bei gb war ich n großer Fan von RCMix. War auch mein lätezter gb Rom :)
Gesendet von meinem Sensation mit der Android-Hilfe.de App
Sooooo,
auf den ersten Blick scheint es wirklich sehr schnell zu sein, vom Gefühl her etwas schneller als Ordroid. Was aber auch damit zusammenhängen kann, dass er erst frisch geflasht ist.
Was mir positiv aufgefallen ist das ich keinen FC mehr beim Setup bekomme :D
Auch der Kernel scheint flott zu sein, mit Maximal Taktung von 1.7 Ghz.
Zum Akkuverbrauch kann ich jetzt noch nichts sagen, aber man wird sehen!
Probiert ihn mal selbst aus, läuft echt wie geschmiert :D !
Grüße Marcel
EDIT:
memnoc hat gerade noch Bescheid gegeben das er heute Nacht noch ein Update rausbringt, wo er Bash reinbringt, Beats Audio und Dolby Mobile Mod hinzufügt und weitere kleine Sense 4 Fixes reinpackt :)
Werde Morgen dann den Thread dementsprechend erneuern!
Kommt gleich auch mal drauf :)
Du wirst begeistert sein ! :)
Muss nacher neu laden. Bei 96% beendet xD
:D und hast du es drauf? :)
Wie gesagt muss nacher noch mal laden :D gehe aber eh jetz gleich an den lappy ;)
Gesendet von meinem Sensation mit Tapatalk 2
Ok berichte dann :)
Sehr gut!! Erste blick ist wirklich gut! sehr flüssig! sehr schick finde ich die downgreadanimation ^^ gehe aber erstmal wieder zurück zu OrDroid. Denke aber das ich früher oder später wieder RCMix nutzen werde :)
Mal sehen wie er sich weiterentwickelt ist ja erst 0.1 ;)
Genau! Das wird noch was ganz großes hier glaube ich !
Das glaube ich auch! Zwei sehr gute Entwickler sitzen dahinter, das kann nur gut werden ! :)
Grüße Marcel
Und wer es noch nicht getestet hat einfach mal ausprobieren ! Man bereut es auf keinen Fall :)
Ich flash es grad, komm vom Elegancia, leider hat RCMIX noch keine eigenen Tewaks, Mods oder Themen, aber so wie ich sie aus dem Incredible S Forum kenn, kommt das bald. Damals waren das die besten Tweaks von RCMIx.
Schreib dein Feedback dann bitte hier rein :)
Grüße Marcel
Grüße Marcel
Läuft flüssig, hab viel Ram frei, hab aber noch nicht gespielt oder sonst was, richte es grad wieder ein. Mal schauen was der Akku so übernacht macht.
Der W-Lan/GSM empfang ist viel viel besser, wahrscheinlich durch den RCMIx Kernel. :smile:
So,
v1 ist raus hier ist der Changelog + Download:
Changelog:
updated SU binary
updated Busybox
updated bash binary
Download
Ich teste heute vllt. Die neue Version
Ich lade gerade runter, Feedback wie immer später :)
Grüße Marcel
EDIT:
Hatte gestern wieder OrDroid drauf und es wahr viel langsamer als RcMixSmartDroid. Ich glaube ich habe meinen neuen Rom gefunden :D
  • candlebox
daniel9180
O
OneGamer
O
ger_kar
Bench
Bench
