[ROM][Sense 3.5][15 Jan]RCMix 3.5 v7.1 Faster Smoother Better ;)
  • 0 Antworten
Zekene
Zekene
Enthusiast
2.239
Hello every one!
Here is a new MegaMix of sense 3.5 roms, the best of all of them in one rom
RCMix 3.5 All In One
THX notown775 FOR THE MOVIE
SCREENS FOR NOW:
Features: *UPDATING
  • Base - 1.05.401.4 Runnymede, android 2.3.5, with Stock and Bliss Rosie(launcher) and Runny HTC Beats.
  • Kernel - Stock sense 3.5
  • Bliss/Stock flavour choosable within tweaks
  • Virtuous Auto Install Script - Thx RMK for that
    (read more about that here)
    This feature will do no harm, so if you dont want to use it, just install the rom as it is
  • Optimized and zipaligned all apks (to leave as low memory fingerprint as possible)
  • HTC Beats
  • Sensation XL clockwidget
  • Super smoothness selectable within tweaks
  • Low memory optimizations
  • Lots of tweak scripts
  • Advanced Power Menu
  • NEW More extended RCTeam Tweaks in settings *Note that some stuff need to be downloaded from our server!
    - Choosable Boot/Down animation
    - Choosable system fonts
    - Keyboard with or without arrows
    - Wake with volume buttons
    - Volume Key Camera
    - Hide Navbar label (Stock flavour)
    - Rosie 5/4 column on/off
    - Bliss/Stock flavour launcher
    - Clock center feature and colour change
    - CRT animations on/off
    - Battery % and colour change
    - dB signal on/off
    - Overglow/bounce on/off
    - Show/hide the quicksettings you want or need
    - Show/hide recent apps in dragdown menu
    - More settings on longpress in quicksettings (try to longpress some of the options)
    - #*#*4696*#*# (phone info and advanced settings)
    - Camera sound on/off, Block adds on/off, White/Black SystemUI, Andrev/Virtuous OC Daemon and many many more !!
  • Keyboard with arrows, arrows can be turned on/off in tweaks
  • Sliding animation on keyboard popup
  • Camera with extended options (bitrate choice for 1080p recording), Thx m-deejay for that
  • SMS/MMS backup feature
  • HTC Notes
  • Quicklaunch widget (the one you see on screens) + all other goodies from runny and bliss roms
  • Latest Market app
  • Latest Superuser + su binary
  • Updated google apps
  • TMobile WIFI calling + Video Chat (auto detect sensation 4g and istalls needed apps)
  • Screenshot with Power+Home
  • + more
Known bugs:
  • you tell me
Requirements:
  • Custom Recovery (so you can flash the rom
    hehehe)
Note:
  • Some of tweaks need data/WIFI connection to download extra stuff.
Tips:
  • To save some battery change the wifi power settings.
  • To make the battery last longer, turn off pocket mode in settings/sounds.
Changelog:
v7.1
  • no need to choose if you want the 720 or 1080p fix while flashing, we just needed that for 1080p recording, since m0narx modded the stock camera, the patch is not needed anymore now we have everything working as it should.
  • probably fixed the camera freeze
  • hopefully fixed the wifi calling
  • added amaze camera as a choice when flashing the rom
  • Fixed stock widget
  • Updated some market apps
  • Moved 4EXT updater to data, so it can be uninstalled if needed.
v7.0
dont complain about low build number anymore! hehe
  • Cleaned it a bit from some unneeded jpgs and apps (OTA and some other upgrade apps etc.)
  • Uppdated the market apps (maps, flashplayer, youtube etc.)
  • Resized Bootanimation, all bootanimations in tweaks are also resized, they look very nice now
    BigT did a very nice job!
  • Added one new Bootanimation to the Tweaks.
  • Removed Downanimation, have problems with resizing it... can be downloaded in Tweaks.
  • Added 4EXT touch recovery 1.0.3 beta8
  • Added 4EXT recoveryUpdater app (you can flash roms, fix permissions, make backups... + much more
  • Modded music app, now you have SRS, Equalizer and BEATS available, both on Headphones and speaker. Thx sbryan12144 for that.
  • Updated Beats
  • Removed the beatsnotify, didnt play well with the modded music app... you turn on/off beats in music app menu.
  • Laputa navigation should be fixed
  • Pattern lockscreen fixed
  • Playing video in landscape mode is ok now
  • Weather animation proper sized now
  • Mail does not trunkate 2/3 raws preview
  • Proper sized icons on homescreen
  • Updated Sony BRAVIA Engine
  • Paginated view in drawer has no ugly divider anymore.
  • Added original framework, which fixed sms/mail Return to dock mode issue and rotation animation, but broked 1080p recording, only 720p available. I have added the modded framework, as an option when you flash the rom.
  • Added possibility to choose 1.2GHz stock kernel or modded by sebastianFM 1.5GHz GPU 300MHz
  • Added possibility to choose original Bliss QuickLaunchwidget when you flash the rom. Be aware that the widget need a Bliss fusion.apk, so use it with Bliss Rosie. With Bliss fusion, stock Rosie will be transparent, so if you want to use stock Rosie again, you will either need to push the fusion from /system/app from this zip, or flash the rom without wipe and dont choose bliss
v10
  • Rebased to Runny base. All previous rtl fixes or framework/app mods, should be redone to work. dont flash old mods.
  • Added new extended RCTeam Tweaks, you need to see it
  • Added battery fix
  • Added Bravia engine
  • Wake with volume buttons, available in tweaks
  • Volume Key Camera, available in tweaks
  • Hide Navbar label (in stock flavour), available in tweaks
  • Camera sound on/off, Block adds on/off, White/Black SystemUI, Andrev/Virtuous OC Daemon and many many more, available in TWEAKS !!
v09
  • no more donut lockscreen, now it is nice as in stock
  • Quicklaunch widget is a bit different then the one from bliss, its from a pico rom, but is proper (i hope) resized so should be ok.
  • Notes propers sized
  • Notes widget proper resized too
  • added T-Mobile checking, when detects a 4g phone, will install wifi calling and t-mobile video chat
  • updated su and superuser
  • Updated some apps...
  • dont remember more for now hehe, sorry
v08
  • Music app with proper sized art work
  • HTC Beats now with even more basss
  • New Clockwidget from Sensation XL
  • tweaked Rosie (launcher) for supersmooooothness
v07
  • fixed the trash icon on remove screen (chopter view)
  • fixed the + button on add screen, adding screen now, not going to phone app (chopter view)
  • improved the beats
  • resized the message widget (was little to small)
  • fixed folder on home (size and the close/rename areas)
  • added all HTC wallpapers (bliss and XE with beats)
  • fixed the strange and wrong text on pattern lockscreen
v06
  • Should be almost perfect resized
    thanks QD2DC for making that!
  • Small MMS should be fixed
  • Should have Bliss v01 data speeds
  • Reworked the tweaks and cleaned the framework
  • Lockscreen issue should be fixed
  • Fixed mail and twitter widget
  • + more, will add here when i remember what else.
v05
  • test release
v04
  • well, sorry guys, its alpha stage so bugfixes and resizing...
Download:
Kernels:
  • any you want... but if you use custom kernel, remember to flash the cam fix.
Radios:
  • I use the one from ICS 1.23 firmware package... works fine
Extras:
To do:
  • you tell me...
--------------------> Drück den DANKE Button :) <---------------------
Reaktionen: anime
