[ROM][WIP][09.04] Sharpy STRPT V0.16 | Stripped CM9 | Under 75Mb! l Android 4.0.4
Tyrion
Tyrion
Enthusiast
405
Hab hier ein Rom gefunden welches mal voll schlank ist.
BT, Cam, und Video funzen.
Introducing Sharpy STRPT CM9. This rom is based on Vorbeths CM9 base which is still a WIP and as such will have a few bugs. I have taken this base and stripped it to its bare bones!
I realised i dont use many native apps, instead choosing to install my own apps from the market or other sources. This means all the native apps do is take up space on my device. If you are the same then maybe, just maybe, this rom is the one for you!
This ROM is not meant to be used 'as is'. You should install your own versions of apps such as gallery and sms.
Features:
  • CM9 ICS
  • Stripped for more memory and speed
  • ReloadedICS extended settings
  • Volume wake mod
  • Rooted
Its probably easier to list the things that are left rather than what ive removed!
  • Calendar
  • Camera
  • Clock
  • People
  • Phone (Dialer)
I have also removed the following:
  • Face unlock
  • All ringtones, notification tones and alarms
There's probably more that ive forgotten but ill update when i remember!​
Notes:
If you want to add your own ringtones, notification tones, or alarms then add them to the relevant folder under system/media using a root file browser.
There is a STRPT version of GAPPS below. This ONLY includes Market and Gmail. All other Gapps should be downloadable from the market.
I have changed the keyboard to Thumb keyboard, mainly because its smaller. There is a paid version available on the market HERE if you like it
Known issues:
Bluetooth - ID3 Tags not transmitted (Source of error unknown)
Gallery does not play recorded video - use mx player
Camcorder works in 720p and 1080p ONLY
IF YOU ARE HAVING ISSUES WITH THE HOME BUTTON THEN CHECK MD5. THEN WIPE CACHE/DALVIK AND REFLASH. IT MIGHT TAKE A FEW GOES TO TAKE!
Credits:
  • Vorbeth- rom base and general help! For his latest full compile check out his THREAD
  • Rob43- ReloadedICS mod, see the thread on this excellent mod HERE)
  • jrummy16- For Root browser. Check out his thread HERE. Search Play store if you want to donate!
  • Blahbl4hblah- an excellent compiling guide. Check out his guide THREAD
  • Hawke84- resized boot animation
  • Cyanogen- For making CM9!
  • XDA- all the devs and mods for keeping XDA alive
Downloads:
MD5 FOR V0.16: F973964576E65FFDD89A6D64C494C963
V0.08+ REQUIRES NEW 3.32 FIRMWARE, SEE POST 2 FOR DOWNLOAD
STRPT_Gapps_gmail_NEWmkt
WITH NEW GOOGLE PLAY MARKET​
Flashing:
DO A NANDROID BACKUP
BUILD V0.08+ IS NOT COMPATIBLE WITH SUPERWIPE, DO WIPE (WIPE/FACTORY RESET) FROM 4EXT RECOVERY
FLASH ROM IN RECOVERY
REBOOT
FLASH GAPPS IF NEEDED IN RECOVERY
REBOOT
original:[ROM][WIP][09.04] Sharpy STRPT V0.16 | Stripped CM9 | Under 75Mb! l Android 4.0.4 - xda-developers
Hab es seid 5 min drauf, und habe bisher nur geguckt ob BT geht, hab ein Bild auf das SE 905c von meiner Frau geschickt.
AddOns findet Ihr hier http://sharpystrpt.blogspot.co.uk/p/add-ons.html
Reaktionen: afrolicious187
Ha, ich rate allen die Tastatur nachzuflashen, die hier drin ist ist mal voll gewöhnungsbedfürftig, aber originell
Edit: So hab jetzt mal alle AddOns nachgeflasht, und muss sagen, es läuft sehr gut.
Weiss noch nicht wie ich das hellblau von der Statusbar ändere, aber es läuft rund sauber und schön
nochmal edit, statusbar geändert. Runterziehen, und da gibts noch mal einstellungen
Changelog
04/05/2012- V0.18:
Rebased on Vorbeths latest build (28/04):
- All updates from CyanogenMod gerrit (upto 28/04)
- Corrected partition sizes and block allocation
- Extract and use HTC/QCOM libv8
- Other minor bug fixes
20/04/2012- V0.17:
Rebased on Vorbeths latest build (15/04 Build 2):
- Fixed multitouch
- Tweaked scrolling
Removed Gapps to keep size down- flashable zip in 'add-ons' as usual
Updated ReloadedICS to 1.9b3, see changelog HERE
hat es schon jemand ausprobiert?
Japp, läuft 1a
und im vergleich zur offizielen CM9?
Nachdem ich diese Rom geflash hatte macht mein sensation immer reboots... und zwar gebe ich mein pin-code ein und dann geht es für 10 sek ca. und dann fragt er mit wieder nach meinem pin-code, wenn ich nochmals mein pin-code eingebe macht mein sensation einfach ein neustart... woher kann sowas kommen?
bevor ich dieses rom geflasht habe, habe ich natürlich auch mein gerät gewipt, dann geflasht, dann neustart, dann gapps geflash... sollte so doch stimmen, oder nicht?
achja, was mir auch noch aufgefallen ist, nachdem ich zum zweiten mal mein pin-code eingegeben habe und er ein neustart gemacht hat, steht oben in der blauen leiste: reloaded systemui loaded (v1.9 beta 4)
woran kann das liegen?
O
OneGamer
O
ger_kar
Bench
Bench
ger_kar
Esen
Esen
