1. Hast Du Lust, bei uns mitzuarbeiten und das AH-Team zu verstärken? Alle Details zu dieser aktuellen Herausforderung findest Du hier.
  1. Slassh, 23.02.2012 #1
    Slassh
    Slassh Threadstarter Android-Lexikon
    [​IMG]
    [​IMG] [​IMG]
    Virtuous S4X is the first custom Sense 4.0 ROM, scaled for qhd screens, to be based on the leaked HTC Endeavour RUU 0.96.401.2
    S4X is the result of a collaborative, team effort by the following developers:
    Code:
    Flemmard
    Diamondback2010
    rmk40
    chrisch1974
    m-deejay
    seo
    eViL D:
    cypis
    cjward23
    Virtuous X-Series​
    Code:
    This series is for ROM's that are not feature complete, are test builds that may or may not receive any future updates. We generally would not recommend these builds for people that rely on there phone 100% of the time, they may, assuming you can live with bugs or missing features be suitable for daily use.
    More info can be found on the blog
    Features​
    Code:
    Based on the leaked Endeavour test ROM (0.96.401.2).
    Resized for qHD (960x540) displays, using a purpose built tool to modify HTC's proprietary m10 binaries, developed by Flemmard and Diamondback.
    Heavily optimized for fluid performance and usability.
    Overclocked kernels with numerous additional kernel modules. (For Evo 3D only)
    Bloatware and unnecessary applications removed.
    Supported Devices:​
    [/B
    Code:
    ]HTC EVO 3D GSM (HTC Shooter_U)
    HTC Sensation (HTC Pyramid)
    Important Notes
    Code:
    You must complete a full wipe prior to installing this ROM the first time. We also recommend wiping between upgrades, but you are welcome to try upgrading without a wipe. However, no support will be provided if you file a bug without having wiped prior to submission.
    Bugs and Errors
    To ease the process of reporting bugs to the team, we made a public bugtracker where you can report the bugs you found. Please make sure you read all the existing entries there to avoid doubling the errors.
    The bugtracker is located HERE.
    (Official Website of Virtuous ROM)​
    Check out our forums
    [/quote]
    Gleich mal auschecken was Sense 4.0 kann schließlich war m-deejay und Co. wieder am Werk ^^
    Face Unlock Addon:
    HERE
    Custom OC kernel by SebastianFM:
    HERE
    Code:
    Virtuous S4X Alpha1 Preview
    Based on HTC One S Developer Preview RUU provided by Football
    Bugs (WIP):
    - Camera
    - BT
    - Animations
    - more? (you tell me)
    [B][COLOR="Red"]After first boot disable all Animations in Settings -> Display[/COLOR][/B]
    FULL WIPE
    [URL="http://files.virtuousrom.com/multi/s4x/rom/preview/virtuous_s4x_alpha1_preview.zip"]DOWNLOAD[/URL]
    Ravenna gefällt das.
  2. Slassh, 23.02.2012 #2
    Slassh
    Changelog:
    BUILD2: - FULL WIPE
    - Updated kernel (3.30 RUU)(Sensation)
    - Fixed Camera (not camcorder yet)(Sensation)
    - Fixed audio (Sensation)
    - Updated gapps
    - Fixed HTC Facebook sync
    - Added TuneIn Online Radio
    - Added ShowMe
    - Added HTC Watch
    - Added HTC Locations and HTC Trip
    - Resized Car Panel
    - Resized Folders
    - Added all Touch IME dictionaries
    - Added ES File Explorer
    - Rom cleanups (removed useless libs and apps)
    - Some graphics improvements
    BUILD1:
    - Initial release
    My Experience:
    - Keyboard takes long to pop-up and doesnt always work properly
    - Wifi works perfectly
    - Mobile network also works - kinda spottie - could be my connection
    - Exchange works ! With Smart-Sync!
    - GPS IS EXCELENT!
    - system volume is VERY low!
    - when scrolling the apps menu, from left to right, little delays and lags, artifacts?
    Bugs:
    - The boot annimation is still Virtuous Quattro
    - using the keyboard in the setup menu the "h" key makes an "f", the "o" key makes a "y", and more are out of order!
    - after the setup menu the keyboard works well, but still is not sized properly
    - when setting up an account, the first window can be out of order, appeard with Dropbox & HTCSense & Evernote setup, just go back and reopen it!
    - icon (app installed) in the taskbar is not resized yet
    - the weather is not resized properly yet
    - The pop-up menu button, doesnt work great with fullscreen apps!
    - "My Location" doesnt seem to be working for me
    - no bluetooth
    - no Audio through headphones
    - Camera & Camcorder don't seem to work
    - Mirror doesn't seem to be working
    by Giblet-dono
  3. Fallwrrk, 23.02.2012 #3
    Fallwrrk
    Fallwrrk Gast
    Na super, so sehr gefreut, dass erneut was Spannendes kommt und dann funktioniert nichtmal die Tastatur einwandfrei. Ich hoffe, dass da noch was kommt.
    mfg Marcel
  4. Slassh, 23.02.2012 #4
    Slassh
    Also habs jetzt ca. 40min drauf und finde Sense 4.0 eigentlich richtig gut :)
    Mal abgesehen von diversen Bugs halt.
    Hoffe da wir fleißig dran gewerkelt.
  5. Coil360, 23.02.2012 #5
    Coil360
    Coil360 Fortgeschrittenes Mitglied
    habe es jetzt auch mal geflasht und bin am testen. Wenn das wirklich mal Sense 4.0 werden soll, dann finde ich es richtig gut! Mal schaun was die Zukunft bringt, es kommen ja täglich neue ROM's auf XDA.
  6. stanlyyy, 24.02.2012 #6
    stanlyyy
    stanlyyy Android-Hilfe.de Mitglied
    Wtf Temperaturen von 50-62 ist ziemlich viel???
    Sonst schaut es sehr angenehm was mir besonders gut gefällt ist wie man die Widgets einfügen kann.
    Was mir gar nicht gefällt ist die Menü Taste unten auf dem Touchscreen nimmt viel Platz vom Display weg..
    Als Tastatur nutze ich SwiftkeyX läuft Super, es gibt schon einen Patch damit geht Sound.
    Sent from my HTC Sensation XE on Sense 4 using Tapatalk :-*
  7. Ravenna, 24.02.2012 #7
    Ravenna
    Ravenna Gast
    Du musst noch von Fahrenheit auf Celsius in den Einstellungen beim Clockwidget umstellen. Dann stimmt es auch wieder mit den Temperaturen. ;)
  8. stanlyyy, 24.02.2012 #8
    stanlyyy
    Hehe ne ne das war schon richtig eingestellt, hab aber wieder mein InsertCoin Backup drauf.
    Mehr wie zum ausprobieren und rumtesten ist Rom eh nicht zu gebrauchen.
    Gesendet von meinem HTC Sensation XE with Beats Audio mit Tapatalk
  9. Ravenna, 24.02.2012 #9
    Ravenna
    Ravenna Gast
    Sorry, hätte ja sein können, dass du das nicht weisst.
    Aber gut für mich, das zu wissen, dann stimmt wohl noch einiges nicht bei dieser Rom!
    Da kann ich mir das Installieren ersparen. Aber die sieht schon mal sehr
    vielversprechend aus.
  10. Suspiria, 24.02.2012 #10
    Suspiria
    Suspiria Android-Lexikon
    Hm, naja. Die Widgets find ich ja nich so prickelnd, aber das wird ja vielleicht noch. Freu mich schon auf das erste Elegancia Sense 4.0 Rom, hehe.
  11. Ravenna, 24.02.2012 #11
    Ravenna
    Ravenna Gast
    Mir gefallen die Widgets! :wubwub: anfangs hatte ich auch ein bisschen Mühe
    damit, aber mittlerweile find ich die gut! Freu mich auch schon auf
    weiteres "happy flashing"! :)
  12. Slassh, 24.02.2012 #12
    Slassh
    Kleiner Tipp von mir Flasht den 1.512 GHz OC kernel 3.0.16-g5e58c5e v1.01 for HTC Sensation damit läuft Sense 4.0 viel besser. Bin aber auch erstmal wieder auf VI 3.5.0.
    Cam und Sound Fix im Ersten Post.
    Edit.:
  13. hndrk, 24.02.2012 #13
    hndrk
    hndrk Neuer Benutzer
    Ich konnte endlich ein zweites HTC Sensation erwerben
    und nun heißt es flashen was das Zeug hält!
    Lohnt es sich also dieses Rom mal zu erforschen,
    oder steckt es noch zu sehr in den Kinderschuhen?
    Grüße, Hendrik.
  14. Dr. Locker, 24.02.2012 #14
    Dr. Locker
    Dr. Locker Android-Lexikon
    Ich denke frühestes preAlpha-Stadium. - Not usable at all
    In der Schule würde man das auf eine Testplatine packen - Im übertragenen Sinne.
    Wohlgemerkt - Meine bescheidene Meinung. Sehen Andere wiederum warscheinlich anders.
    AM BESTEN - WIPEN - FLASHEN - TESTEN/SEHEN - WIPEN - RESTOREN...
  15. Fallwrrk, 24.02.2012 #15
    Fallwrrk
    Fallwrrk Gast
    Build Nr. 2 ist erschienen! Changelog hab ich leider nicht gefunden und werd mit ner 1000er Leitung in den nächsten 2 Stunden auch nicht testen können. :(
    Aber hier der DL:
    Klick mich hart!
    mfg Marcel
    Edit:
    Ach, da isser ja:
    - Updated gapps
    - Added ShowMe
    - Added HTC Watch
    - Resized Car Panel
    - Resized Folders
    Zuletzt von einem Moderator bearbeitet: 24.02.2012
    hndrk gefällt das.
  16. hndrk, 25.02.2012 #16
    hndrk
    Das hört sich doch schon besser an,
    dann lad ich mir die Version mal runter.
    Ich danke dir ;)
  17. Slassh, 25.02.2012 #17
    Slassh
    Hier mal kleines Addon-Recent_Apps die Suchen-Taste gedrückt halten dann funktioniert es.
  18. Ravenna, 25.02.2012 #18
    Ravenna
    Ravenna Gast
    Wie läuft denn die Rom jetzt nach dem Update?
    Lohnt es sich, die mal zu flashen?
  19. Fallwrrk, 25.02.2012 #19
    Fallwrrk
    Fallwrrk Gast
    Ne, man merkt noch, dass der Pixelbeschleuniger (ich liebe dieses Wort :D ) noch recht träge läuft. alles baut sich langsam und oft voll Fehler auf. Das Wort "Performance" scheint die ROM auch noch nicht zu kennen. Viele Apps müssen außerdem noch resized werden und bei manchen Apps taucht sogar ein zweiter Menü-Button auf. :w00t00: Also wirklich tauglich ist da noch garnichts.
    mfg Marcel
  20. Sh0X31, 25.02.2012 #20
    Sh0X31
    Sh0X31 Android-Guru
    ist bei v2 die Tastatur noch verbuggt?
    Mein Problem bei v1 war, wenn man sich beim Setup angemeldet hat (mit e-mail) und man nach dem "@" gmail schreiben wollte und auf "g" gedrückt hat, kam bei mir @rapidshare.com -.-
    PS: Die Tastatur hat auch eine falsche Auflösung :(
