Tuplapukki
Stammgast
- 125
Neues ROM 16.07.2015
Huawei Ascend Mate - Прошивка (OS 4.1.2-4.X.X) - 4PDA
2015/7/16【风雨团队】 MT1联通版 EMUI3.0_B331原汁原味卡刷包,稳定全功能,完美ROO - 华为 Ascend Mate 论坛 - 智友
Download: MT1-U06_EMUI3.0_B331.zip - Google Drive
Demnächst auch in den Huawei Ascend Mate Ressourcen.
Beschreibung (mit Google-Translate aus dem Chinesischen):
The package is based on Huawei MT1-U06_EMUI3.0_B331 official firmware extract production, the system comes with the apparently useless and looked upset, built-in software to do the deletion, almost all retain the full functionality of Huawei official firmware to ensure system stability, add another a few simple modifications of humanity, is an excellent choice for the official control of local friends. Welcome to the machine friends to speak up, this package can be released on demand update.
PS: Since this package retains the full functionality of Huawei official firmware, so the volume may be higher than other starter pack to be larger.
ROM Profile
666 MB (Flashen über TWRP)
ROM Profile
- The package is based on Huawei MT1-U06_EMUI3.0_B331 official firmware extract production, it has been perfectly ROOT, users can customize their own phone system;
- Rationalization streamlined, freeing memory;
- Remove not commonly used software, and keep the original style of the official release of the memory, and to ensure the stability of the system;
- Careful layout, make the desktop icons beautiful, clean;
- Modify the boot animation;
- Boot from Kai init.d, convenient self-optimizing oil;
- And su added busybox binary files, easy to use some special tools;
- Power cust timely entry into force;
- zipali g N optimized application software to improve the efficiency of interaction with the phone system;
- Gps positioning optimization, which can be second location;
- Optimization wifi reception signal and reception range;
- Optimization of mobile phone touch sensitivity and sliding sensitivity
