morpheus620
Android-Guru
- 2.479
Jetzt auch für das Ascend P1.
Ob die Sprache deutsch vorhanden ist kann ich nicht sagen.
Das müsste jemand mal testen und hier im Thread bescheid geben.
Noch was zum Kernel.
Ich weiß nicht ob Deep Sleep funktioniert.
Sollte es sein könnte man ihn eventuell auch für CM10 nutzen da auch Shendu auf 4.1.2 basiert.
Installation:
Rom auf die SD Karte kopieren
Ins CWM booten
Full Wipe
Rom Installieren
Gapps Installieren
Spaß haben
Download:
ShenDu_OS_1124.zip
Changelog:
Original Thread:
Klick mich
Installation:
Ins CWM booten
Full Wipe
Rom Installieren
Gapps Installieren
Spaß haben
Download:
ShenDu_OS_1124.zip
Changelog:
Foreword
The system for the the Huawei U9200 Ascend P1 System, the ROM is based on the latest the depth OS/4.1.2 compile production, thanks to the support of the depth of the OS project group, this the ROM only add ROOT permission to increase the charge display, updated SU and authorization management control version, we have not integrated any market and promote the software to ensure that the largest pure, and the right to choose to give the user more
First domestic machine ROM, there is something wrong, please correct me on this ROM first experience version, although experience version, but also close to perfect, all functions were normal, and only be counted as BUG resolution some questions on camera photographic FC next version will fix this problem, the next version might send the resolution also be resolved out
Specific highlights, see the ROM introduction.
Version information
ROM Name: Huawei U9200 Ascend P1 the latest 4.1.2 compiled based on the depth of the OS, stable and smooth, streamlined
Android version: 4.1.2
Based version: Based on the depth of the OS source code compiler
ROM makers: depth ROM group-ax918
Release time: 2012.11.25
Team support: depth ROM group
Features
Support advanced restart mode
Drop-down menu support quick turn off the screen mode
Support a key lock screen mode
Information backup support
5. Attribution support
Drop-down menu flashlight function
Drop-down menu Close notification feature
Drop-down menu of 12 functions (your own view it does not describe)
ROM introduction
The latest source code of the ROM is based on the depth of OS 4.1.2 compiler to produce generic versions, the depth thin optimize production, brush back up good contacts.
2 full animation default interface, the default interface of the system can be adjusted.
3. Integrates the latest Chinese input method.
The system has perfect ROOT, and add the latest senior administrative privileges.
5 all zipalign processing.
6. Maximize streamlined system.
Shut down the system default script parity greatly reduce memory temporary, let God to the force.
System framework set further optimized. Reduced the size of some apk
Magic sound effects add practical HTC, listening to music more to force.
Modify the default value of the call volume (you can modify ext below)
11 update the Hosts file, shielding 99% of the ad.
12 maximum to retain the official templates, including wallpaper and plug-ins.
13 kernel optimization, we installed the software on your computer Please turn on USB debugging mode.
14. Overall system optimization, fluency, stability, increased power efficiency
15. Delete all Google services
16 this ROM does not integrate with any third-party market, it is strongly recommended that the utility Google official original market.
Version information
Features
ROM introduction
Original Thread:
Klick mich
