kaepen05
Hallo ,
hab es gerade gefunden bei der XDA community omr911
[ROM][Port] ICS 4.0.3 alpha 1 - xda-developers
Pure ICS 4.0.3 ported from Nexus S with johnnyperovvip's port base.
Let the entire XDA community contribute in fixing bugs!
Now touchscreen is noticeably fast but not working the way we want.
I've add .idc files (for touchscreen) in system/usr/idc lets c if someone can fix.
But we only need 1 of them rest should be removed when fixed!
Whats Working:
Screen brightness
External Apps
Widgets
Vibration
Buttons partially work
Gallery, Maps etc...
Some settings
+ You tell me
Whats Not Working:
Every thing else + You tell me
We have 4/5 ICS based ROMs & ports nearly all of them have same issues just like all other initial ports.
If any bug is fixed, it can be applied to other ICS based ROMs too.
I'm also working on CM9 & MIUI4
Dont mention same identified bugs again and again + before posting read the thread!
Your contributions are most welcome...
If you fix any bug kindly post/submit here in this thread.
This thread is for developmental purpose only..
Dont ask any noob related questions here!
Ask at Optimus Black Q&A section...
Do not post 'Thank You' comments
Only Hit ' Thanks ' button
Whats Working:
Screen brightness
External Apps
Widgets
Vibration
Some settings
+ You tell me
Whats Not Working:
: Unsicher: Alpa2 ist raus !
