[Kernel] [120811] NeoBlaze Kernel for stock/MCR - based on V10e [EXT4/OC/UV]
UKSheep
UKSheep
Dauergast
569
[kernel][120811] NeoBlaze Kernel for stock/MCR - based on V10e - EXT4/OC/UV
Quelle: XDA - [kernel][120811] NeoBlaze Kernel for stock/MCR - based on V10e - EXT4/OC/UV
Author: Imperticus
Imperticus schrieb:
Information about kernel, really, this contains everything (almost)
This is based on the newly released LG v10e kernel sources. It will only work with 2.2 (Froyo) stock/Modaco based ROMs. Will not work with CyanogenMod based ROMs, or 2.3 (Gingerbread) Modaco ROMs.
System and data WILL BE converted to ext4 automatically when you flash this. An ext3 version option will be released in the future.
Features:
- EXT4 built in (finally)
- OC/UV support, overclocking upto 1400 mhz - use pimp-my-cpu (other apps may not work)
- SDRAM, VDE and GPU overclock
- Voodoo Sound
- deadline I/O scheduler
- few other little tweaks inc some designed to improve battery life
- new wireless.ko module
- more to come..
Credits
- Cpasjuste for work on oc/uv, and learnt a lot from his posts etc.
- Beene for some of the tweaks to improve battery life
INSTALLATION
- Be sure to REMOVE "boot settings" from Pimp My Cpu before installing the kernel to reset default values.
1. reboot to CWM
2. Clear cache
3. Advanced, clear Dalvik
4. install zip from SDcard
5. Reboot
DOWNLOAD
make sure you back up before installing, just incase something goes wrong..
120811 - normal version
120811 - lower OC values
- removed USB accessory (wasn't working properly anyway)
- enabled RNDIS
- fixed init.d permissions (hopefully will solve bootloops)
- added a version with lower oc value - upto 1200Mhz
090811
- Voodoo sound added (thanks supercurio)
070811
- change to UV/OC values
- SDRAM, VDE and GPU overclock (thanks vork and morfic)
- fix for proximity and accelerometer sensor
- USB accessory mode enabled
050811b
- optimised app killing (thanks beene)
- 8 step clock speeds and volts - same as in vorkkernel (hopefully will fix some of the bootloops)
- overclock upto 1400mhz
- compiled with toolchain 4.4.3
040811
- included init.d (thanks ilos for the heads up) - should fix some of the bootloops
030811
- initial release
NB: I was building this as part of my learning process, and thought I would share it since V10E kernel doesn't have ext4 support yet. Please take it easy on me, i'm still learning ;)
If you like it dont forget that 'Thanks button' :D
.::[-Features-]::.
- EXT4 Dateisystem...
- OC/UV unterstützt, übertakten bis zu 1400 mhz - Nur [Pimp my CPU] funktioniert !!!
- SDRAM, VDE and GPU werden mit übertaktet...
- Voodoo Sound - [Voodoo Control] - [Voodoo Control Plus] - wird benötigt um dieses Feature zu nutzen...
- deadline I/O scheduler <- Sry noch keine Übersetzung !!!
- ein paar andere kleine Tweaks + Tweaks um die Laufzeit zu verlängern
- neues wireless.ko module
- weiteres wird folgen !!!
Bevor ihr den Kernel flashed, solltet ihr auf jeden Fall ein Nandroid Backup machen !!!
Es kommt bei einigen Usern zu einem Bootloop nach dem flashen, deswegen ist ein backup so wichtig.
.::[-Installation-]::.
- Sei dir sicher, das du die "boot settings" von "Pimp my CPU" entfernt hast. [falls du vorher einen anderen OC Kernel hattest]
1. Speed im Recovery (CWM) starten
2. Clear cache
3. Advanced, clear Dalvik cache
4. install zip from SDcard (NeoBlaze Kernel)
5. Reboot
.::[-Alternative Installation-]::.
1. KernelFix[Folder+File].rar herunterladen.
2. "KernelFix[Folder+File].rar" entpacken und den Ordner "init.d" auf die SD Karte verschieben.
3. per "Root Explorer / ES Datei Explorer" den init.d Ordner nach "System/etc" verschieben.
4. Nun müsst ihr noch die Permissions des Ordners + der Datei im "init.d" Ordner auf 755 setzen.
5. Root Explorer - lang drücken - permissions / ES Datei Explorer - lang drücken - eigenschaften
6. So sollte es aussehen... *klick*
7. Handy neu starten und ins Recovery booten...
8. Kernel flashen + reboot
So wie hier beschrieben hat es dank einiger User bei XDA auch bei mir endlich funktioniert.
Nun nutze ich das neuste Stock Rom mit dem NeoBlaze Kernel und bin sehr zufrieden.
MfG
UKSheep
Hier mal paar Benchmark Bilder...
[v10d Stock / NeoBlaze Kernel @ 1,4 Ghz]
MfG
UKSheep
Kannst du inzwischen schon was über den Kernel sagen? Was für Erfahrungen hast du gemacht?
ich selber nutze das Gerät nicht mehr.
Habe aber die paar Tage die es bei mir im Einsatz war die ganze zeit diesen Kernel genutzt.
Mir ging es aber in erster Linie um das UV (UnderVolten) der CPU um die Laufzeit nach Möglichkeit zu verlängern.
MfG
UKSheep
Meine Erfahrung ist, dass der Kernel sehr schnell ist, aber das Scrollen minimal schlechter als beim Stock Kernel ist. Daher benutze ich den Stock Kernel von der V10d.
sgspluss
  • sgspluss
sgspluss
sgspluss
UKSheep
chrissi77
chrissi77
R4G3
Donauschwabe
Donauschwabe
