[ROM] Cyanogen-Mod 10.1 - M1 Official Nightly´s (Jelly Bean) + STABLE CM10!
Adinoid
Adinoid
Enthusiast
1.104
CyanogenMod
CM10.1 Nightlies
OFFICIAL CYANOGENMOD 10.1 NIGHTLY
Google Apps
GOOGLE+ Account
CHANGELOG
GERRIT 'Entwicklercodes'
Reaktionen: motoroller, Irieginals, bavmouse und 26 andere
So in der Changelog tut sich jetzt was
Changes in next cm10 nightly for crespo
Fix NPE in InputMethodAndLanguageSettings
Merged on Jul 21st at 14:45:56 in android_packages_apps_Settings
Soll wohl gleich eine RC werden ????!!!:D:D:D
Add a restart for the default launcher, too
Merged on Jul 25th at 20:21:02 in themes-platform-vendor-tmobile-apps-ThemeChooser
bionic: Update fcntl header from the kernel
Merged on Jul 25th at 08:10:40 in android_bionic
Show dock battery level if available
Merged on Jul 25th at 08:00:02 in android_frameworks_base
Add support for external dock batterys
Merged on Jul 25th at 07:59:48 in android_frameworks_base
Torch: fix breakage from 19844
Merged on Jul 25th at 07:58:59 in android_packages_apps_Torch
Merge "systemui: permission to phonetoggler" into jellybean
Merged on Jul 25th at 07:58:51 in android_frameworks_base
Merge "Portuguese: Fix too long on/off text for setting toggle. Using same fix as the one used in ICS" into jellybean
Merged on Jul 25th at 07:56:54 in android_frameworks_base
Settings: Add ChangeLog to Settings
Merged on Jul 25th at 07:56:36 in android_packages_apps_Settings
Merge "Fix initial telephony FC for PIN locked SIMs This fixes misplaced substring operation causing unhandled exception occuring before SIM is PIN unlocked." into jellybean
Merged on Jul 25th at 07:54:09 in android_frameworks_base
Update Russian Translation-Mms-CM10
Merged on Jul 25th at 07:52:27 in android_packages_apps_Mms
Framework: Initial German translation
Merged on Jul 25th at 07:51:24 in android_frameworks_base
Merge "skia: compile SkTextBox for Samsung's libtvout" into jellybean
Merged on Jul 25th at 07:51:18 in android_external_skia
Update Russian Translation-Frameworks Base (2/2)-CM10
Merged on Jul 25th at 07:46:03 in android_frameworks_base
Merge "Update Russian Translation-Settings (1/2)-CM10" into jellybean
Merged on Jul 25th at 07:43:06 in android_packages_apps_Settings
Merge "Settings: Enable dithering if persist.sys.use_dithering=1|2" into jellybean
Merged on Jul 25th at 07:42:55 in android_packages_apps_Settings
Merge "HTCQualcommRIL: use ICS style RIL_UNSOL_RESPONSE_RADIO_STATE_CHANGED" into jellybean
Merged on Jul 25th at 07:40:42 in android_frameworks_base
DSPManager: res cleanup & lint flags
Merged on Jul 25th at 07:40:05 in android_packages_apps_DSPManager
Merge "Wifi: Fix the resume problem with wpa6 devices, for jb" into jellybean
Merged on Jul 25th at 07:39:05 in android_frameworks_base
Add HTC cam-mode config option
Merged on Jul 25th at 07:34:36 in android_packages_apps_Camera
frameworks/base: support devices with SoftAp that don't require firmware reload
Merged on Jul 25th at 07:33:00 in android_frameworks_base
Merge "Update Russian Translation-Phone-CM10" into jellybean
Merged on Jul 25th at 07:28:24 in android_packages_apps_Phone
camera: add 12 and 9MP
Merged on Jul 25th at 07:26:56 in android_packages_apps_Camera
Merge "Forward port write_raw_image changes to jellybean." into jellybean
Merged on Jul 25th at 02:01:58 in android_bootable_recovery
Merge "Adjust kernel data stack TCP parameters to optimize performance" into jellybean
Merged on Jul 24th at 20:25:07 in android_frameworks_base
Bionic/libm: fast neon pow() for small x,y
Merged on Jul 24th at 20:16:42 in android_bionic
Merge "samsung ril: add UNSOL_AM implementation" into jellybean
Merged on Jul 24th at 18:19:38 in android_frameworks_base
Merged on Jul 24th at 17:40:42 in android_frameworks_base
Merge "Lockscreen : Fix blank target highlight" into jellybean
Merged on Jul 24th at 16:37:39 in android_frameworks_base
SoundSettings: Don't use deprecated vibrate APIs
Merged on Jul 24th at 16:32:02 in android_packages_apps_Settings
Merge "Framework: Audio service - add missing pieces from CM9 port" into jellybean
Merged on Jul 24th at 14:54:10 in android_frameworks_base
Merge "Settings: Fix duplicate activity name" into jellybean
Merged on Jul 24th at 14:42:38 in android_packages_apps_Settings
Merge "Settings : Lockscreen targets alignment fix" into jellybean
Merged on Jul 24th at 14:42:08 in android_packages_apps_Settings
Phone: Enable LTE options for GSM LTE phones
Merged on Jul 24th at 13:10:32 in android_packages_apps_Phone
Merge "Changes PhoneInterfaceManager to allow toggling of LTE from outside of the Phone app." into jellybean
Merged on Jul 24th at 13:06:43 in android_packages_apps_Phone
Merge "Power Widget: Enable LTE switch for Power Widget" into jellybean
Merged on Jul 24th at 12:35:18 in android_frameworks_base
Merge "french from ics (meteo, global actions, reboot menu)" into jellybean
Merged on Jul 24th at 12:34:18 in android_frameworks_base
Merge "Add NT_MODE's for NETWORK_MODE's 8 and 10" into jellybean
Merged on Jul 24th at 12:26:53 in android_packages_apps_Phone
arm: Allow disabling PIE for dynamically linked executables
Merged on Jul 24th at 12:23:38 in android_build
Merge "GlobalActions: make silent mode the last toggle" into jellybean
Merged on Jul 24th at 12:13:10 in android_frameworks_base
ext4: Let make_ext4fs be grandfathered into builds
Merged on Jul 24th at 03:16:56 in android_system_extras
libaudiohw_legacy: Remove ICS_AUDIO_BLOB def. Should be defined in
Merged on Jul 23rd at 21:05:29 in android_hardware_libhardware_legacy
Merge "drawable: fix ugly gradient on dark holo background" into jellybean
Merged on Jul 23rd at 17:38:10 in android_frameworks_base
Settings: Make Volume overlay expandable by default
Merged on Jul 23rd at 16:38:42 in android_packages_apps_Settings
Merge commit 'android-4.1.1_r3' into aospmerge
Merged on Jul 23rd at 16:20:27 in android_frameworks_base
Merged on Jul 23rd at 16:18:42 in android_build
Merged on Jul 23rd at 10:48:57 in android_external_skia
Reaktionen: Patrick89bvb
Startpost angepasst mit guten Neuigkeiten. Sobald der Startpost mit allen Verfügbaren Links gefüttert ist werde ich mich mit dem Posten etc. zurückziehen aus dem Nexus S Forum.
Hat seine Gründe.. ich wünsche trotzdem allen Flashern viel Spaß :)
Reaktionen: bierpatriot1, Bondar, caralarmandmore und 3 andere
Endlich mal was Offizielles!
So und die Jungs haben Wort gehalten. Die Nightlies sind auf CM10 gesprungen. http://get.cm/get/jenkins/6327/cm-10-20120818-NIGHTLY-crespo.zip
Der ursprüngliche Beitrag von 06:25 Uhr wurde um 07:01 Uhr ergänzt:
Startpost ist nun auch so angepasst das hier nicht immer aktualisiert werden muss.
Von daher kann man sich alle relevanten Links aus dem ersten Post nehmen.
Viel Spaß dabei ;)
Reaktionen: Bondar, chris-86, hausmeisterxl und eine weitere Person
Viel Spaß dabei ;)
Endlich gehts wieder weiter :D
@Adinoid, danke fuer die viele Arbeit die du dir hier im Forum gemacht hast. :thumbsup::thumbsup::thumbsup:
Reaktionen: Adinoid
Hallo Zusammen,
seitdem ich mein Nexus S vor einem Jahr gekauft habe, hatte ich stets immer die Stock Images drauf.
Ich würde jetzt gerne mal auf den Cyanogen-Mod Zug springen. Ich bin jetzt keiner der jede Woche lust hat eine neue Version aufs Handy zu spielen weil irgendwas nicht funktioniert, allein schon aus dem Grund immer wieder alles neu einzurichten.
Jetzt sind ja NIGHTLY's rausgekommen. Sind die soweit entwickelt, dass ich keine Einschränkung auf meinem Nexus S hab?
Danke Adinoid
für dein immer waches Auge hier im Nexus S Forum, und die vielen Threads zu den Rom`s ohne den wären mache Roms nie entdeckt worden !!! Auch wenn hier manche ... (wegen der Höflichkeit) meinen das man nicht gleich immer ein neuen Thread aufmachen müßte ! Dazu sage ich: Schaut euch mal die Überschrift hier an "Custom-Roms für Nexus S"
Aber das sind leute die hier sonst nichts sagen außer solche Kommentare,
ich kann es nicht verstehen !!!
Reaktionen: taette
Scheinbar ist leider die Rotation bei den ersten Nightlies "kaputt".
T-REX600 schrieb:
Danke Adinoid
Dem kann ich nur zustimmen, ohne ihm hätte ich nie das CyberGR-Mod gefunden, eine der wohl besten ICS-Roms überhaupt, und die JB-Versionen von dem Ersteller werden wohl auch toll werden, auch wenn sie wegen seinem Präsenzdienst wohl etwas dauern werden.
Aber sie bereits gesagt, der Name dieses Bereichs hier sollte auch wirklich Programm sein, daher nochmals Danke Adinoid :)
Reaktionen: taette
hatten wir das auch nicht bei CM9 ne ganze Weile?
genauso sehe ich es auch,
deshalb meine ich weiterhin, dass wir hier Roms vorstellen sollten,
die wir zumindest mal auf dem Phone hatten und ein paar Sätze dazu schreiben können.
Hinzu kommt, dass die Forenleitung davon ausgeht,
dass wir bei der Vorstellung einer Rom auch eigene Screenshoots machen.
Ich halte auch weiterhin nix davon einfach nur per paste & copy Inhalte von den xdas hier zu platzieren.
Auch ich setze mal ein Danke an die Jungs hier welche immr Updates posten :)
Zu CM10, wer hat schon geflasht? Probleme?
Vom CM9 auf CM10 Fullwipen?
Gruss
Wie man weiter oben lesen kann, gibt es Probleme, ja.
FullWipe, ja.
Gruss
Ich hatte lieber nen fullwipe gemacht.
Scofield hatte ja schon die fehlende Rotation angesprochen.
Ich dachte das bezog sich nur auf die Homescreens,
aber den Browser kann ich auch nicht im Querformat nutzen,
deshalb bin ich schnell wieder weg.
Sorry, hab ich Blindfisch übersehn (Rotation)
Gut, dann bleibe ich noch bei CM9 ;)
Greetz
oder wechselst zu CMREX v.2
stabiles JellyBean-Fealing
:thumbsup:
d4Lux0r
Firetime
Firetime
d4Lux0r
AdO089
AdO089
forb'S
forb'S
forb'S
