Berlino
Enthusiast
- 6.358
AOSB basiert auf CyanogenMod
Hallo liebe Oppo-Gemeinde, ich stelle euch hier mit Erlaubnis von XDA-Member @Silesh.Nair (hier bei Android-Hilfe @sileshn) das AOSB-Rom vor, das er freundlicherweise für unser Oppo Find 7a portiert hat (er selbst besitzt kein Oppo!). Ebenso geht der Dank für die Erlaubnis der Portierung an Hany Alsamman aka @codexc bei XDA
Über das Rom:
Website : AOSB Project » Android Open Source BAM
Github : https://github.com/AOSB
Features : AOSB Project » AOSB Project Features
Google + : https://plus.google.com/communities/...38542924482954
Danke an:
- Hany Alsamman aka @codexc, AOSB chief and original founder. Learn more about him here.
- Silesh Nair for porting AOSB
- AOSB Team : details here
- JustArchi for his awesome optimizations, v3!!!!
- Sparsco for his sm toolchain 4.8.3!!!
Changelog:
AOSB KitKat v1.3.5
- base: Protected App
- base: Fix On-The-Go Tile
- base: Add Battery/Power Saver Tile
- base: New API From Mokee, phone number location support for chinese users
- base: listview: ensure active views are filled prior than scrap views
- base: Peek: Notification Helper fixes
- base: Fix animator display
- base: Gesture Device Lock
- base: Second Clock
- base: Add support for Peek external app
- base: New Base Code for Active Display a lot of improvements
- base: Fix light notification color picker force close
- base: HOVER From PA
- base:CM Themes, Add support for composed icons
- base:CM Trebuchet, a lot of improvements
- base: AOSB RecentApp v2
- PS1: Fix the memory leak and more and reduce memory usage
- PS2: Improvement thumbnail size also on landscape mode
- PS3: Attach the default thumbnail size and prevent conflict with slim recents
- PS4: ability to switch between 3 modes of recents
- PS5: set height, width for each mode and each DPI
- PS6: add standard clear app icon , instead of ugly icon
- Settings: Launch only contacts picker for blacklist entry
- Settings: Apps, Add blacklist interface
- Settings: HALO, color customizations
- Settings: listview,fix force close
- Settings: Active Display, Double tap to sleep
- Settings: Active Display, Hide Low Priority, Hide Non Clearable and Quiet Hours
- Settings: Apps, Add black listed app for HOVER
- Settings: Apps, Add black listed app for Peek
- Settings: Gesture Lockscreen
- Settings: Update Active Display
- Settings: Add AOSB Support translations for hungarian
- Settings: Fix FC "Settings - interface" on tablets like Flo
- Settings: Recent, Switcher bettwen App
- Settings: Recent, restart UI once in all cases
- Settings: Fix Battery light FC
- InCallUI: Hide Titlebar while loading InCallUI
- InCallUI: do not use reflection
- InCallUI: Store dialpad showing state
- InCallUI: fix location of answer ring on incoming call
- InCallUI: fix non-intrusive for RTL
- InCallUI: Dialpad key digit color TRDS update
- InCallUI: fix dialpad digits color while TRDS is on
- InCallUI: fix landscape layout
- Dialer: update TRDS for new 4.4.3 Dialer
- Dialer: Update landscape layout to match 4.4.3 codebase
- Dialer: Chinese Location Lookup
- Dialer: Hide shadow overlay for contact tiles with letter tile avatars
- Dialer: Fix force close if using chinese language
- n7100: fixes unexpacted random reboots
- sc03e: remove bloatware and not currently in-use
- sc03e: add missing blob
- jflte: use new device tree and kernel
- hammerhead: use new device tree and kernel
- vendor: Added apn settings for Mobitel and Etisalat, Sri Lanka
Screenshots:
AOSB ROM - Imgur
Installation:
- Ladet euch das Rom und die Gapps aufs Gerät
- Macht zur Sicherheit ein Nandroid Backup von eurem jetzigen Rom
- Führt einen Fullwipe aus (wipe /system, data, cache, dalvik cache)
- Flasht Rom und Gapps
- Neustart und freuen
Download Rom:
https://www.mediafire.com/folder/a2a5lyhox5lvd/FIND7
Gapps:
Banks-Gapps: Goo.im Downloads - Browsing GApps
PA-Gapps: [GAPPS][4.4.x] OFFICIAL Up-to-Date PA-GOOGLE APPS (All ROM's) [2014-06-20] - xda-developers
Slim-Roms-Gapps: Downloads - Addons4.4
Feature-Screenshots:
