Samsung galaxy mega (gt-i9205 & gt-i9200) unofficial roms
Which dpi would you like roms set to by default?
  • 233
    Stimmen: 6 17,6%
  • 240
    Stimmen: 20 58,8%
  • 270
    Stimmen: 8 23,5%
  • Umfrageteilnehmer
    34
Hi guys, here's an answer to above statements and questions,
Sicfallacy, thank you for letting me know about the force close. Is anyone else having this issue? Perhaps i will build it again tomorrow as you guys need a working phone!
nguyenducanh.dan
I have had some issues with screen pinning. It seems to work if you use on screen buttons but i use the stock hardware buttons so it is something i cannot currently use. This is not an issue on my end but an issue on cyanogenmods.
Leverone, you are more than welcome. As i say i will look into it.
And a note to all, cm-12.1 is uploading!
Thanks for the support, appreciate it.
Reaktionen: sicfallacy
nguyenducanh.dan
On some versions it works fine, even I tried with nav bar.
Could someone tell me if I can ajust the hard button lightning scenario? Can I turn them off?
Go to settings/bottons/blacklight, you can adjust the time you want them to light up or turn the lights off if you are using Resurrection remix v5.44 you can disable the menu/back keys and home buton.
German
Gehen Sie zu Einstellungen / bottons / Schwarzlicht können Sie die Einstellungen der Zeit yiu wollen, dass sie zu leuchten , oder schalten Sie das Licht aus , wenn Sie Resurrection remix V5.44 können Sie nicht in der Lage die Menü / Zurück -Tasten und Heim buton werden .
So on CM12.1 I'd be able to turn of the lights completely?
Just asking for getting you right.
Also auf CM12.1 wäre ich fähig die Lichter komplett zu deaktivieren?
Ich frage nur um dich richtig zu verstehen.
Resurrection_Remix_LP_v5.4.4-20150513-I9205-I9200.zip online, same version as lastime, but still an update
German:
Resurrection_Remix_LP_v5.4.4-20150513-I9205-I9200.zip online, dieselbe Version wie lastime, aber immer noch ein Update
Reaktionen: MegaHolic, Don_Pedro, sicfallacy und eine weitere Person
Tomorrow I will build paranoid android and also a version of temaseks ROM with standard rotational speed. Just testing the waters to see what I can do with an aim to maybe building my very own ROM one day ;)
German:
Morgen werde ich paranoid android und auch eine Version von temaseks ROM mit Standard-Drehgeschwindigkeit zu bauen. Nur das Wasser zu prüfen, um zu sehen, was ich mit dem Ziel, vielleicht bauen meine eigene ROM einem Tag machen können;)
Reaktionen: Don_Pedro, sicfallacy, droidphil und 2 andere
Wopema71 schrieb:
...aim to maybe building my very own ROM one day ;)
German:
...vielleicht bauen meine eigene ROM einem Tag machen können;)
• Hi Wopema
Great plan ... :) Whish you'll succeed ... :) If it happens within the Android 5 era, it could be the worlds' first " WopPop " then ... :) thumb up
• Hi Wopema
Großartiges Vorhaben ... :) Ich wünsche, Du hast Erfolg ... :) Wenn es innerhalb der Android 5 - Ära dazu kommt, dann könnte es der Welt-erste " WopPop " sein ... :) Daumen hoch
Reaktionen: sicfallacy, Wopema71 und droidphil
German:
Great, i'll wait for PA, but unfortunately PA unofficial builds don't have the official's features. Can you build PA just from sources? Don't make an edit or mod on this ROM, and keep 240 dpi like what Silesh done before. Thank you so much on keeping these good works!
Große, werde ich für PA warten, aber leider PA inoffizielle Builds keine Funktionen des Beamten haben. Können Sie PA bauen nur aus Quellen? Machen Sie nicht bearbeitet oder mod auf dieser ROM, und halten 240 dpi wie, was Silesh zuvor. Vielen, vielen Dank an halten diese guten Werke!
Yes PA will be without mods, if i modify a rom it will be uploaded alongside the original so don't worry about any nasty surprises, the stock will still be there. I will also keep it at 240 dpi, as i say our device should be 233 and thats where mine is set but its personal choice.
German:
Ja PA ohne mods sein, wenn ich ein ROM wird es neben dem ursprünglichen hochgeladen werden, so zu modifizieren, nicht zu bösen Überraschungen sorgen, wird die Aktie immer noch da sein. Ich werde auch halten Sie es bei 240 dpi, wie gesagt unser Gerät soll 233 und das ist, wo mir gesetzt, aber seine persönliche Wahl.
Reaktionen: nguyenducanh.dan
Thank you Wopema71iam waiting for pa
Its compiling :)
German:
Seine Zusammenstellung :)
So we will have it in early morning? Also, do you build PA from legacy sources or official?
Building from legacy. And i dont know your time zone but it should be online in 2 hours or so. The "Official Non-Nexus iteration of AOSPA Rom" edition.
German:
Der Aufbau von Legacy. Und ich weiß nicht, Ihre Zeitzone, aber es sollte hier in 2 Stunden oder so. Der "Official Non-Nexus Iteration AOSPA Rom" edition.
Where are you come from? It will be at 11.00pm in Vietnam's time. (+7.00)
Im a UK dweller.
German:
Im eine UK Bewohner.
Also, can I make a dirty flash from 5.0 Alpha 2 0307?
I wish it would became official, can you talk Ayysir?
I see no reason why not.
German:
Ich sehe keinen Grund, warum nicht.
See my edit post above
I will certainly talk
German:
Ich werde sicherlich sprechen
Mammi
Koenigstiger
Jetson
