Beanstalk 4.4.2
  • 13 Antworten
I
iSchneiderle
Ehrenmitglied
678
[ROM][4.4.2][Unofficial] BeanStalk Build 4.4.225
Infos zur Rom:
[ROM][4.4.2][Unofficial] BeanStalk Build 4.4.225 - Updated [Jan 20,2014] - xda-developers
Rom:
Dev-Host - BeanStalk-4.4.225-20140120-UNOFFICIAL-galaxysl.zip - The Ultimate Free File Hosting / File Sharing Service
Gapps:
[GAPPS][4.4.2] PA-GOOGLE APPS lite for galaxysl 20131230 55 Mo !!! - xda-developers
Funktionen der Rom:
CM based
Lockscreen background options (Color fill, Custom image, Transparent)
Customizable Lockscreen text color
Lockscreen rotation
Option to enable all widgets
Minimize lockscreen challange
Use widget carousel
Slider Shortcuts
Static Lockscreen shortcuts
Lockscreen button actions
LCD Density
Scroll elasticity options
Default App grip option
Custom Carrier label
Dual Pane options
Customizable boot animation (off, default, set your own bootanimation)
Custom original BeanStalk Wallpapers by skyliner33v
Custom BeanStalk bootanimation by skyliner33v
Status bar color and transparency
Clock and date options which includes color, location, style
Signal Styles which include color and text instead of icons, alternate GB signal layout, hide signal icons
Breathing SMS option
Battery styles - Includes specific colors and styles. Also includes battery bar
Do not disturb option
Show notification count
Pie controls (need to have lockscreen background set to something other then default to work correctly (dont ask why) )
Fully customizable navigation bar - Includes style, layout, color, nav rings, pretty much everything you can think of.
Quick settings color settings, tiles per row, Quick pulldown, text color
Notification shortcuts, behaviour, drawer style (customizable colors), toggle colors, longpress quicksettings icon to enable/disable toggles
Keyboard and input method options which include disable full screen keyboard and auto rotate
Kil app back button with customizable timeout values
High end graphic effects option
option to disable/enable vibrate on expand for notifications alerts
Low battery warning customizable options
Recents RAM bar fully customizable with color styles
Clock widget for LockClock including extra options to fully customize every feature of the lockclock
Build.prop MOD options to enable/disable tweaks as preferred
Less frequent Notification sounds options
CRT screen off/on options to specify how the animation shows
Enable/disable wake up on charge option
Superuser fully embedded into the build and accessed from settings menu
CM Performance options and features
About BeanStalk option with links to github source and facebook for beanstalk. Also links to my twitter and donate.
insane amount of edits/tweaks/fixes to make this build absolutely fly
option to use a fully themable MMS packages. You can access from mms - settings - theme settings
Numerous other options hidding throughout the build
Screenshots folgen muss erst welche machen =)
Der ursprüngliche Beitrag von 19:38 Uhr wurde um 19:39 Uhr ergänzt:
Bugs und Update Informationen.
Über ein Danke würde ich mich sehr freuen... =)
Reaktionen: playsat, Daniel 9003 und Mario1974
Dann will ich mich mal auch in Textform bedanken.
Ich bin zwar in den letzten Tagen etwas vorsichtiger mit flashen, da ich es geschafft habe beide Bootloader des I9003 zu zerstören.
Aber nach der Empfehlung von iSchneiderle werde ich es mal testen. Nicht dass das Forum umsonst eröffnet wurde ;)
Zerstören kann man eigentlich net viel =) Backup machen alles Wipen Rom installieren Neustart ins recovery gapps flashen Neustart und genießen
Reaktionen: Daniel 9003
Mit Odin eine defekte Bootloader-Datei geflasht (2x). Ja, ich weiß,aber meine Dummheit wurde mit 30€ für die Reparatur bestraft.
Aber jetzt endlich zu BeanStalk. Werde es am Wochenende mal drauf bügeln.
Beanstalk wird dir gefallen =) also meine Mama ist total zufrieden damit und mit 3 Tagen Akkulaufzeit auch in Ordnung =)
Meine erste erfahrung:
finde ich nicht schliecht, habe es jetzt installiert und werde mal sehen was die Tage bringen.
Reaktionen: Daniel 9003 und iSchneiderle
Damit ihr nicht so alleine seid, hab ich es auch mal drauf gespielt.
Mal Schau'n, was es aus meinem alten Akku noch raus holt.
Erstmal durch die englischen Settings kämpfen.
Sonst macht es keinen schlechten ersten Eindruck. :thumbup:
Gesendet von meinem GT-I9003 mit der Android-Hilfe.de App
Er hält keine angst =P
Akku hält auch bei mir ganz gut durch.
Eine Kleinigkeit ist mir aufgefallen: Von meiner Freisprecheinrichtung im Auto kann ich keine Nummer wählen. Kontakte werden zwar im Auto angezeigt, aber wählen geht nicht. Am Handy kann ich eine Nummer anwählen und dann hab ich das Gespräch auch auf der Freisprechanlage.
Reaktionen: iSchneiderle
Hey,
habe es jetzt auch installiert. Bin aber erstmal zurück auf CM11. HIer hatte ich 2 Probleme. Ist mehrfach neu gestartet und hatte es auf Englich und nicht auf Deutsch, obwohl ich es direkt eingestellt habe beim Installieren.??? War halb / halb.
Halte es aber im Auge, den es hat einen guten eindrück gemacht.
Mich stört auch etwas das Englisch in den Einstellungen.
Werd mich aber weiter durchkämpfen und testen.
Mir gefällt sie auch Super gut, allerdings habe ich einen extrem hohen Akku Verbrauch - denn sie ist ununterbrochen als aktiv geführt.
Ist an der Rom etwas zu ändern oder stört hier allein eine app?
Wakelocks habe ich kaum und dennoch 79% wach
Skip
Also bei mir hält der Akku ganz gut durch. Hab den Autostart etwas ausgemistet und bin so auf über 3Tage gekommen.
Gesendet von meinem I9003 mit der Android-Hilfe.de App
Schaut mal auf die Laufzeit =) nicht einen reboot gehabt =)
Reaktionen: Mario1974
