crDroid AOSP 4.4 Unofficial
I
iSchneiderle
Ehrenmitglied
678
UNOFFICIAL 4.4 KRT16M CM11 crDroid AOSP
Hier könnt ihr euch Informieren:
[ROM][UNOFFICIAL][Nov29][4.4][CAF][CM11][HALO] **crDroid AOSP** [Build 6] - xda-developers
Rom Link:
Dev-Host - cm-11-20131129-crDroid-b6-UNOFFICIAL-galaxysl.zip - The Ultimate Free File Hosting / File Sharing Service
Gapps:
Changelog:
crDroid Version Build in Settings
Normal or Center Clock Mod with possibility to change color
Custom Data formats in Status (day, month and year)
Notification drawer & Notification row Transparency, custom Colors and custom image
sweep2wake & sweep2sleep
faux sound control
Update with CyanogenMod commits
Customizable low battery pop-up warning
Option to enable notification ligth when scree is on
Alternate default app picker
Network stats in status bar
Network stats custom colors
Network stats hide if there's no traffic
A lot of updates from CyanogenMod (check my github)
CRT with 5 options: don't show, collapse horizontal, collapse vertical, collapse orientation dependent, scale down
CPU info overlay
Wifi name in notification drawer
Slide through status bar to adjust brightness
Screenshot quick trash
Notification drawer shortcuts
Reenabled CM volume buttons custom actions
Updated with CyanogenMod commits
Custom battery styles (normal, percentage, circle, circle with percentage, doted circle, doted circle with percentage)
Custom battery colors and animation speeds
AOKP custom system animations
Animate carrier label when collapsing panel
Navigation bar customization
Navigation ring customization
Improved scrolling cache
Merged android KRT16S
Quick settings tile from CyanogenMod
New power menu from SlimRoms
Clear recents button
RAM bar
Power connect/disconnect notification support
Immersive mode (a.k.a Expanded desktop)
Active display from ChameleonOS
Lockscreen targets and shortcuts from SlimRoms
Quick unlock control
Halo
Big menu is back in Navigation bar
New Quiet hours from CyanogenMod
Bring back volume dialog feature from CyanogenMod
Bring back maximaze widgets in lockscreen from CyanogenMod
Forward port SystemUI: HSPA+ Support
Updated with a ton of CyanogenMod commits
Fix SystemUI crashes when Active display is enable
Lockscreen widgets from SlimRoms
Implement a PIN keypad shuffler
Enable navbar for hardware keys devices (dosen't affect mako)
Enable hepatic feedback for lockscreen shortcuts
Back with theme ability for GlobalActions.java
So installiert ihr es
1. Kopiert Rom und Gapps auf die SD-Karte
2. Neustart ins Recovery
3. Wipe Data/Factory Reset
4. Install zip from sd-card und installiert die Rom
5. Startet euer Handy erneut neu ins Recovery
6. Flasht die Gapps und Startet neu Booten lassen und genießen.
Bitte Flasht nur wenn eurer Akku mindestens 50% hat!!
WICHTIGER HINWEIS: Weder ich, noch Android-Hilfe.de, übernehmen eine die Haftung für jegliche Beschädigungen an eurem i9003 !!!!!
Daher flashen auf eigene Gefahr. !!
Credits:
Screenshots:
I
  • iSchneiderle
iSchneiderle
I
