FalcoKubny
[EOL] Ironman Rom 1.2.0 Final
NOTE 8 PORT
Kompatibel mit dem S7/S7 Edge (S8/S8+/N8)
Seit 17.02.2018 gibt es die finale Version 1.2.0.
Diese Rom wird für das S7/Edge nicht mehr weiterentwickelt!
Neuer Kernel: IronKernel 1.3.0
Der Entwickler dieser Rom ist: Tkkg1994 zusammen mit seinem Team "Grifo Development"
Ich und auch Android Hilfe übernehmen keine Haftung für etweiige Schäden die beim Flashen der Custom Rom enstehen.
Link zum Download auf Androidfilehost:
Loading site please wait...
Link zu Bootloader und Modem für SM-G93xF/FD/K/L/S/W8:
Rom features of V1.2.0 Nougat:
- Based on latest N950FXXU3BRA8 Nougat base
- Prerooted with SuperSU V2.82 SR5, Phh root r310 or MagiskSU (choose in aroma)
- Magisk V15.4 (aroma selectable)
- Latest Busybox 1.27.2 included in aroma
- Aroma installer! with support up to 4GB zip files
- CSC features are currently not available due to encrypted csc files (a workaround is to use the S8/S8+ csc but I'll figure something out)
- Adblocker included as aroma choice
- Full rom control!! App name is IronControl Free
- Fully deodexed
- Private mode working (only with Modded Settings from aroma)
- LED indicator settings
- choose IOS, Oreo or stock emojis in aroma
- DM-Verity disabled
- Force encrypt disabled
- Modded SystemUI with many tweaks in RomControl (header colors, qs colors, notification colors and much more)
- 3Minit Clock/battery in romcontrol
- Custom clock positions and customizations in romcontrol
- USB Plug/Unplug disable wake up
- Remove high volume warning for headphones
- Torch on lockscreen
- Use volume key on lockscreen to switch music titles
- Knox stuff can be choosen in aroma
- Back to kill and Recent to kill (in RomControl)
- Stock DRAG Kernel or IronKernel (choose in aroma)
- Based off from latest touchwiz source available at this moment
- Many apps are selectable in aroma debloat menu
- Selinux permissive on custom kernel
- Ram bar in recents
- Matrix animation in recents
- Dual speaker sound mod
- Xposed V89.2 included as aroma choice
- Latest January Security Patches (includes Blueborne Bluetooth and Krack Wifi fix)
- Many other features, can't list them all, please read changelog to see what changed over the time
S7/S7e related changes:
- Updated all libs to DRAG base
- Fixed resolution bug by taking libs from another 7.1.1 base (first boot screen may look a bit weird, I had to change the dpi in developer settings to 360 to get a good value for the s7 screen, default is 480)
S8/S8+ related changes:
- Fixed some camera issues such as zoom not working correctly
This is going to be the LAST update before Oreo. Since the S7/S7e and S8/S8+ will receive the same UI as the N8, this is the last version which includes all those models. Oreo update will have support ONLY for the N8 (no need anymore for a port)
- Fully deodexed
ZUERST:
Erlaube die OEM-Ensperrung in den Entwicklereinstellungen und speichere die Rom nach dem Download auf deiner Sd-Karte
1. Flashe TWRP (die neueste Version) über Odin.
2. Boote in den Recovery Modus, in dem du die Lautstärke lauter + die Hometaste + die Powertaste gleichzeitig drückst und hälst.
3. Wen du in der Recovery gefragt wirst ob du twrp erlaubst das System zu editieren, swipe zu "yes" um es zu erlauben
4. Nun klicke auf "Wipe", danach auf "format data" (ein Tastenfeld wird nun auf Poppen), tippe nun "yes" (ACHTUNG das wird all deine Daten löschen, besser du machst vorher ein Back Up)
5. Danach Bootest du wieder in die Recovery, und wählst die SD Karte und installiert nun die Rom.
6. Mit Hilfe eines Aroma installers wirst du durch die instalation geführt und kannst alle Einstellungen auswählen.
7. Warte bis die Rom gebootet ist. (Dies kann ein paar minuten dauern.. keine Angst)
8. Nach dem Du alles eingestellt hast, öffne die IronControl Free, dadurch aktivieren sich die standard Einstellung des Entwicklers.
Viel Spaß mit der Rom
Ironman NewsChannel (Telegram):
IronMan News Channel
- Samsung for the base
- SuperR for his awesome Kitchen
- Chainfire for his Super SU
- topjohnwu for systemless Magisk V14.4
- amarullz for aroma and nkk71 to make it compatible with bigger zip files
- wubydax and daxgirl for basic RomControl
- myellow for all the great animations!
- TheFreak for his work as designer and his help with the website
- mwilky for his fingerprint after reboot mod, private m- Based on latest N950FXXU3BRA8 Nougat base
ode, custom colors and other mods
- Asc1977 for a few mods I already used on SuperMan & BatMan
Der neueste Kernel vom 17.02.2018
IronKernel_SM-G93XX_V1.3.0 ist in die Version 1.2.0 integriert
Link zu Super Su 2.82 SR5:
SuperSU Download
Araya Soundmod(v.3):
Arise +Magnum+Opus 24.07.2017 ( Soundmods):
Google Pixel Kamera APK mit HDR+ & Porträt Modus für S7/Edge Exynos Modelle:
Google Camera with working portrait mode V7
- Die Samsung Gesichtserkennung funktioniert nicht. Dafür aber die Gesichtserkennung von Google.
- Die Hintergrund beleuchtung der Hardware Tasten (zurück & "recent apps" Taste) funktioniert nicht , da das Note 8 keine Hardware Tasten besitz.
- Knox basierte Dienste wie z.B. sicherer Ordner, Samsung Pay, Samsung Pass können aufgrund des Rooten nicht mehr funktionieren.
