[EINGESTELLT][ROM][G95xFx][8.0][XXU4CRJ5] *02.11.2018* RENOVATE ICE v14.1 [Stable][Nightlies]
SoLdieR9312
SoLdieR9312
Dauergast
1.508
Entwickler: mwilky, baadnewz & SoLdieR9312
Stabile Version:
Renovate ICE G95X 14.0 (31. 10. 2018)
-> Download <-
Änderungen "Stabile Version"
  • -Rebased on G950FXXU4CRJ5
    -Completely redone all mods on new base
    -Re-ported all tweaks/mods/awesomeness
    -Improved blur quality on notification pulldown blur tweak
    -Added option to choose blur amount to notification pulldown blur
    -Added option for qs tile animations
    -Added option for qs tile animations duration
    -Added option for qs tile animations interpolator
    -Added option to color the background behind notifications
    -Added remap option to launch assistant to all button remaps
    -Added remap option to launch voice assistant to all button remaps
    -Added remap option to turn screen off to all button remaps
    -Added remap option to open/close notifications to all button remaps
    -Added option to disable statusbar peek
    -Added option to enable seconds in statusbar clock
    -Readded hide keyboard notification tweak
    -Fixed and improved hide lockscreen help text tweak
    -Fixed some notification backgrounds not updating in real time
    -Fixed default values of QS layout tweaks
    -Fixed QS icon colors not applying in the customize section of quicksettings
    -Fixed QS text colors not applying in the customize section of quicksettings
    -Fixed brightness slider icon colors not applying when altering brightness
    -Fixed QS background color not applying to tile details views
    -Fixed QS text color not applying to buttons and header in tile details view
    -Fixed all rotations tweak needing a reboot to apply
    -Fixed fingerprint remap tweak needing a reboot to apply
    -Fixed hide keyboard notification tweak needing a reboot to apply
    -The cross icon in QS customize section now takes the color of quicksetting text color
    -Updated magisk
    -Probably more
Nightly Versionen:
Aktuellste wird auf der Downloadseite immer ganz oben angezeigt,
somit ist die höchste rXX Nummer auch die aktuellste Version.
-> Download <-
Änderungen "Nightly Versionen"
-> Changelog <-
Versionen (Nighlies / Stabile Versionen)
Nightlies: Werden jeden Tag gegen 23.30 Uhr auf den eigenen Servern erstellt und zum Download zur Verfügung gestellt. Dadurch ist man immer aktuell, es kann aber auch mal vorkommen, dass eine Version Fehler beinhaltet. Hauptsächlich für "Flashaholics" gedacht ;)
Stabil: Werden meistens freigegeben, nachdem ein neues Sicherheitsupdate verfügbar ist, und die komplette ROM auf dieses Update umgestellt wurde. Bis zur Stabilen Version kann es immer etwas dauern.
Features
Allgemein
  • Samsung Firmware: XXU4CRJ5 (Android 8.0)
  • Fake Knox 0x0 Status im System [Bootloader bleibt 0x1!]
  • AROMA-Installationsprogramm mit Option zum Einstellen der persönlichen Konfiguration
  • Magisk, SuperSU oder kein Root während der Installation auswählbar
  • Wählen Sie aus vielen verschiedenen CSC-Funktionen
  • Optimiert für verbesserte Batterie / Leistung
  • Tweaks App um Ihre persönlichen Einstellungen vorzunehmen
  • Gerätestatus auf "Offiziell" gesetzt
  • 5-Wege-Neustart-Menü hinzugefügt
  • Outdoormodus zu den Einstellungen hinzugefügt
  • LED-Benachrichtigungen zu den Einstellungen hinzugefügt
  • Zusätzliche erweiterte Animationswerte zu den Einstellungen hinzugefügt
  • Applock hinzugefügt
  • Bildschirmaufnahme-Kacheln in den Schnelleinstellungen verfügbar
  • OEM-Entsperrung aus den Einstellungen entfernt
  • Aktivierter SystemUI-Tuner, Aktivierung durch lange Tastendruck-Taste im Schnelleinstellungs-Panel
  • Anpassen der Alarm-Benachrichtungslautstärke im Schnelleinstellungs-Panel
RiCE Tweak's
  • Oberfläche
    • Aktivieren / Deaktivieren des Vollbildmodus
    • Alle Umdrehungen aktivieren / deaktivieren
    • Aktivieren / Deaktivieren der Lautstärkewarnung
    • Aktivieren / Deaktivieren der Warnung wegen hoher Helligkeit
    • Aktivieren / Deaktivieren des Fingerabdrucks / Iris nach dem Neustart
    • Aktivieren / Deaktivieren lange drücken, um App zu beenden
    • Fensteranimation Skalensteuerung
    • Übergangsanimation Skalensteuerung
    • Animatordauer-Skalensteuerung
  • Statusbar
    • Position der Uhr auf links, rechts oder mittig ändern
    • Aktivieren / Deaktivieren der Uhr-App beim Anklicken der Statusleiste
    • Aktivieren / Deaktivieren des Batteriesymbols in der Statusleiste
    • Aktivieren / Deaktivieren des Mehrbenutzersymbols
    • Aktivieren / Deaktivieren des doppelten Taps zum Einschlafen Wählen Sie die Anzahl der kompakten Quicksets Wählen Sie die Anzahl der Quicksetting Zeilen / Spalten
    • Aktivieren / deaktivieren Sie den Helligkeitsregler in Quicksettings
    • Aktivieren / Deaktivieren der Sperrung von Quicksettings, während das Telefon gesperrt ist
    • Aktivieren / Deaktivieren von gesperrten Quicksets, um verwendbar zu sein, wenn das Telefon gesperrt ist
    • Aktivieren / Deaktivieren von schnellen Quicksettings Aktivieren / Deaktivieren von Blur-Effekt auf Pulldown
    • Aktivieren / Deaktivieren von entfernbaren Systembenachrichtigungen
    • Aktivieren / Deaktivieren der Auswahl der Tastaturauswahl
    • Aktivieren / Deaktivieren der Batterieleiste und viel Anpassung
  • Anwendungen
    • Aktivieren / Deaktivieren der Sperrsicherung
    • Aktivieren / deaktivieren Sie den Sperrbildschirm-Hilfetext
    • Netflix Problemumgehung
  • Farben
    • Dynamische Navigationsleiste
    • Wähle Farbe für Header-Hintergrund
    • Farbe für Header-Text auswählen
    • Wählen Sie die Farbe für Kopfsymbole aus
    • Wählen Sie die Farbe für die Symbole der Navigationsleiste aus
    • Wählen Sie die Farbe für den Quicksetting-Hintergrund
    • Wählen Sie die Farbe für den Tauschtext aus
    • Wählen Sie die Farbe für das Trennen von "freigegebenen" Kacheln
    • Wählen Sie Farbe für das Setzen von "deaktivierten" Fliesen
    • Wählen Sie die Farbe für den Trenner
    • Wählen Sie die Farbe für den Regler für die Einstellung der Helligkeit
    • Wählen Sie die Farbe für den Quick-
    • Wählen Sie die Farbe für das Quicksetting Drag-Griff-Symbol
    • Wählen Sie Farbe für Benachrichtigungshintergrund
    • Wählen Sie Farbe für Benachrichtigungstiteltext
    • Wählen Sie Farbe für Benachrichtigungszusammenfassung Text
    • Wählen Sie Farbe für Benachrichtigung footer Text
    • Wählen Sie Farbe für Benachrichtigung footer Hintergrund
  • Verschiedenes
    • Display einschalten beim Anschluss von USB aktivieren / deaktivieren
    • CSC-Auswahl
    • Standard-App-Installationsort
Installationsanleitung
Anfang
  1. Installiert TWRP Recovery auf dem G950F bzw. G955F (Anleitung TWRP Install)
  2. Macht ein Backup der alten Daten!
  3. Downloadet das letzte Stable Build oder letzte Nighly Build
Installation
  1. In den Recovery-Modus (TWRP) wechseln
  2. Bei der 1. Installation einen Full Wipe und Format Data machen
  3. Das Rom-Zip auf das Phone bzw. auf die SD-Card kopieren
  4. in TWRP dann unter Installieren das Rom Zip wählen
  5. Nun startet der Aroma-Installer:
    1. no Wipe; Wipe dalvik + cache only; Perfom a full wipe; Quick install
    2. Welches Root? no root; Magisk; Chainfire SuperSU
    3. Willst du App's nicht mit dabei haben?
    4. Wahl der App's, die nicht mitinstalliert werden sollen
    5. Tweaks Fingerdruck/Iris Entsperren nach Reboot ja oder nein; Customize oder Stock CSC; Stock oder IOS Emoji
    6. CSC Wahl
    7. Mit Next startet Installation!
  6. Nach Installation Reboot Now
SVN Tutorial
Was brauchst du?
Einstellung am Anfang?
  • TortoiseSVN installieren
  • In dem Verzeichniss, in dem du das Rom speichern möchtest, lege einen Ordner an „Renovate-ICE“
  • Lege einen Ordner „renovate-g95x“ an
  • Einen Ordner „renovate-flashable“ an
  • In „renovate-g95x“ werden die Daten des Rom’s gespeichert und in „renovate-flashable“ werden die Dateien exportiert
1-png.581015
Download des Rom’s
  • Rechtsklick auf „Renovate-Dream“
  • Auf „SVN Checkout“ und dort den Link Renovate ICE SVN Repo eingegeben und dann Ok
  • Wenn es gefunden wurde, dann wird es herunter geladen (Dieses Mal wird das Rom komplett herunter geladen)
  • Wenn alles gut geklappt hat ist an dem Ordner „renovate-g95x“ ein grüner Hacken
Export
  • Zu allererst in Ansicht -> Option ->Ansicht „Ausgeblende Dateien, Ordner und Laufwerke anzeigen“ aktivieren
  • Rechtsklick auf „renovate-g95x“ und TortoiseSVN -> Export.. wählen und den Ordner „renovate-flashable“ wählen
  • Geh in den Ordner „renovate-flashable“ und markiere alle Ordner und Dateien
  • Gehe mit Rechtsklick auf 7-Zip -> zu einem Archiv hinzufügen…
  • Dort kannst du wählen wo das Rom in Zip-Form gespeichert werden soll
  • Archivformat zip wählen
Update
  • Bei den weiteren Male einfach auf dem Ordner „renovate-g95x“ Rechtsklick und SVN Aktualisieren wählen, dann werden nur neue/geänderte Dateien runter geladen
  • WICHTIG: renovate-flasbable Ordner leeren, bevor ihr neu exportiert!
Quelle
Aktualisiert 14.05.2018
Reaktionen: Scum, Omerta, petlura und 14 andere
Paar Screenshots wären nicht schlecht.
Hey, deine Verlinkung auf unsere Website geht auf den S8 Port Changelog, der ist vom S7. Fürs S8 ist der Button "Changelog" ohne Zusätze zuständig =).
Reaktionen: Baudolino
@SoLdieR9312 ups. Sorry, aber die Woche werde ich auf jeden Fall das Rom mal testen.
Kein Thema ;) Mach das, läuft echt hervorragend.
Hier geschlossen!
Wenn jemand Zeit und Lust hat, den Opener gemäß der Vorgaben anzupassen und zu übersetzen, melde er bitte diesen meinen Beitrag mit einer kurzen Erklärung.
Der Thread wird dann wieder geöfnnet und übergeben.
Danke fürs Verständnis und
Gruß von hagex
Reaktionen: Reddy und bandit1976
Gute Nachricht :),
der Thread ist wieder geöffnet und der Opener wird überarbeitet :thumbup:.
Gruß von hagex
Reaktionen: Reddy, hufnagel, TheKen und eine weitere Person
@hagex und an den restlichen Interessierten!
Ich hab den Start-Post angepasst und versucht es in ein "Ok-Deutsch" zu schreiben. Ich werde versuchen euch für Fragen zu Vergügung zu stehen und die aktuellen Stabilen Versionen sowie ihre Änderungen zu informieren.
MfG
Baudolino
Reaktionen: miccmaniac, Reddy, P4RTYH4RTY und 2 andere
Kann man reboot zu recovery im Neustart menü irgend wo aktivieren
Normal ist das erweitere Neustartmenü standardmäßig im Rom dabei wenn du auf die Powertaste - Neustart gehst.
Reaktionen: TheKen
[emoji20] ja okay jetzt wo Du es sagst...
War es nur vom S7 gewohnt das es gleich nach der Powertaste kommt
Aktualisiert um Changlog Nightly
> Zum Anfang <
Also ich bekomme da noch die Kriese mit dem Authentifizierungsproblem vom WiFi nach Reboot...
Anfangs noch Probleme mit Bluetooth gehabt das hab ich mit einen Clean flash der r46 gelöst bekommen.
Die ROM läuft sonst richtig gut.
Freu mich schon auf die nächste Stable hoffentlich mit WiFi fix.
Aber jetzt kommt erst mal die r47 drauf.
@Chojin Authentifizierungsproblem? Hatte vormals v1.2 drauf und ich hatte kein Problem mit den WIFI's, vielleicht liegt es daran, weil es österreichischiche sind. :)
Neee Ösi oder nicht daran liegt es leider nicht...
CSC ist Deutsch unbranded.
Edit:
So Lösung gefunden...
Ist ein Build.prob fehler / problem
ro.securestorage.support
Ist dafür zuständig
Wert muss auf false stehen.
Das war er bei mir aller Dings auch, auf true gesetzt reboot wieder auf false reboot und siehe da es geht.
Bearbeitet von: hanspampel - Grund: Doppelposts vereint. Bitte Editierfunktion über "Beitrag Bearbeiten" nutzen - "hanspampel"
ro.securestorage.support steht bei mir auf true, und habe dieses Problem nicht.
Hast du vllt. bevor du Renovate geflashst hast, nicht dein Internen Speicher formatiert?
Ich hatte das Problem bei den ersten malen auch, in den ersten Versionen - aber mit v1.2. aber ich glaube beim S6/S7 gabs auch das Problem!
Phone war quasi jungfräulich also out of Box OEM an und gleich root alles formatiert, und geflasht.
War nie was anderes drauf außer Renovate
Am Anfang hat alles geklappt nach irgend einer Nightly hat es angefangen...
Jetzt aber neues "problem" Musik lief auf einmal Musik aus und tada SD Karte komplett leer [emoji20] [emoji27] [emoji36]
Ja wir hatten in der 1.0 das Problem das Wifi Passwörter und Bluetooth Parings nicht gespeichert wurden, das haben wir aber nach dem 1. Nightly nach der 1.0 schon behoben, und in die 1.1 mit eingebunden. Deshalb wundert uns das, dass es immer noch einige wenige gibt, die Probleme damit haben. Hab das Problem grade an mwilky weitergeleitet, wir werden das mit dem secure.storage mal auf false umstellen ;)
[doublepost=1494753885,1494753793][/doublepost]@Chojin Nachdem du TWRP geflasht hast, musst du format data machen, da ansonsten die interne Verschlüsselung deines Speichers anbleibt, und es zu erheblichen Problemen kommen kann :)
Zum testen würde ich mal die SD Karte rausnehmen und im PC in nen Kartenleser stecken, würde mich wundern wenn das Handy einfach so die SD-Karte formatiert.
Frank65
Frank65
Frank65
SoLdieR9312
DJSeeBaa
SoLdieR9312
der von da
der von da
