1. Mitglieder surfen ohne Werbung auf Android-Hilfe.de! ✔ Jetzt kostenlos Mitglied in unserer Community werden.
  1. Belze, 24.03.2013 #1
    Belze
    Belze Threadstarter Android-Experte
    Da die Rom in der Version 2.5 ruckelt und auch so paar kleine Bug´s (von mehreren Benutzen bestätigt) hat, ist die Rom nicht unbedingt zu empfehlen.
    --==Zelly Cream ROM==--
    Inspired from Xperia Z Jelly Bean
    [​IMG]
    Features
    ROM Features
    • ROM based on ICS .431/.587
    • Highly customized rom by AROMA installer.
    • Super fast, super stable and great battery life without sacrificing UI.
    • 100% bloatware free ROM.
    • CWM ready and pre-rooted ROM.
    • Latest Super User binaries.
    • Init.d support.
    • Magnification glass ported
    • Download music info for both locked/unlocked BL (v2.5+)
    • 360 degree rotation added
    • Skip track by volume keys
    • Kill app by back button
    • Extended power menu
    • Added hosts list to block ads.
    • SuperCharged services with Time Killer Killer mod.
    • Butterly smooth interface (try and experince by yourself).
    • Latest Adreno libs.
    • Latest Xperia T Jelly Bean messaging app with dual UI.
    • Latest Xperia T Jelly Bean keyboard.
    • Latest Xperia T Jelly Bean notes apps and walkman widget.
    • Latest Xperia T Jelly Bean media apps.
    • Latest Xperia T Jelly Bean media libs for better video and sound quality.
    • Latest Cyber-shot mod
    • Xperia T Jelly Bean small apps.
    • WiFi-Direct port(partially) by me.
    • Dual lockscreen support (JB and NXT lockscreen).
    • Jelly Bean lockscreen (slightly modded by me to suit my rom).
    • Jelly Bean easteregg (shows rom name).
    • Jelly Bean Google Play and GMail app.
    • Xperia Z themed framework for awesome user interface.
    • Xperia Z styled SystemUI with centered clock.
    • Xperia Z default themes by me.
    • Xperia Z default wallpapers by me.
    • Latest LockScreen Style™ app exclusively by me.
    • RAM tweaks to get 100-120 mb free RAM always (for great multitasking).
    • New Boost My Xperia™ feature to boost your rom to play HD games exclusively by me.
    • And many more, explore by yourself
    Aroma Features
    • Device selection
    • Launcher selection [Xperia GX | Xperia Launcher | Xperia Jelly Bean]
    • Bootloader selection [Xperia T Jelly Bean | Nexus]
    • Font selection [Jelly Bean | Xperia S | Stock]
    • Ringtone selection [Zelly Cream | Stock]
    • Root app [Super User | SuperSU]
    Additional features in Aroma
    • Root Browser Lite
    • Titanium Backup
    • Task Killer
    • Facebook Integration
    • Social Engine Core
    • Sony Timescape
    • Live wallpaper support
    Install
    Install Locked BL
    1. Reboot to cwm.
    2. Wipe data/factory reset.
    3. Wipe cache partition.
    4. Wipe dalvic cache under advanced menu.
    5. Wipe battery stats under advanced menu.
    6. Format data under mount and storage menu.
    7. Format system under mount and storage menu.
    8. Format cache under mount and storage menu.
    9. Install zip from sd card.
    10. Follow the steps in aroma installer to install the rom.
    11. Uncheck "Reboot device" after installation completed and click on next to go back to CWM.
    12. Now reboot your phone..
    Install Unlocked BL
    1. First flash stock .587 ftf file for your device to avoid bootloop. (below is the link)
    2. Install your desired kernel. (see list of recommended kernels.)
    3. Reboot to cwm.
    4. Wipe data/factory reset.
    5. Wipe cache partition.
    6. Wipe dalvic cache under advanced menu.
    7. Wipe battery stats under advanced menu.
    8. Format data under mount and storage menu.
    9. Format system under mount and storage menu.
    10. Format cache under mount and storage menu.
    11. Install zip from sd card.
    12. Follow the steps in aroma installer to install the rom.
    13. Uncheck "Reboot device" after installation completed and click on next to go back to CWM.
    Download
    Download Zelly Cream v2.5 - Full ROM
    *** Hot update (21/02/13) ***(OPTIONAL)
    Für Addon´s und ältere Downloads bitte bei XDA vorbeischauen.
    [​IMG]
  2. mephistho, 29.03.2013 #2
    mephistho
    mephistho Erfahrener Benutzer
    Könnt ihr mir erklären, warum dieser Schritt nötig ist?
    Ich hab Ultimate HD laufen mit dem Vengeance Kernel. Ich hätte jetzt eigentlich gedacht, ich kann die Zelly Cream ROM so flashen?!
  3. Belze, 29.03.2013 #3
    Belze
    Brauchst Du auch nicht machen. Funktioniert bei Dir auch ohne diesen Schritt. ;-)
    Gesendet von meinem Xperia S
    mephistho bedankt sich.
  4. mephistho, 29.03.2013 #4
    mephistho
    Mhh, irgendwie hatte ich mehr Jelly Bean erwartet. War ich da auf dem Holzweg? Was ist mit LockScreen-App-Shortcuts? Mehrzeilige GoogleMail Notifications?
    Und warum habe ich keine kleinen Vibrationen beim Tippen, obwohl ich's eingestellt hab. Gibt's noch mehr Optionen, die dafür relevant sind, als im Sound-Menu "Vibrate on touch"?
  5. Belze, 30.03.2013 #5
    Belze
    Man muss halt 1. die richtigen Einstellungen im Aroma Installer wählen
    und, richtig lesen bevor man schimpft, 2. die Addon's die man haben will installieren.
    Gesendet von Tf101 mit TeamEOS
  6. mephistho, 30.03.2013 #6
    mephistho
    Sorry, ich hab mich wohl etwas im Ton vergriffen. Ich wollte keineswegs schimpfen :) Die ROM fühlt sich klasse an, Lob und Dank für die Arbeit daran!
    Das mit den fehlenden Vibrationen ist aber doch nicht richtig, oder? Ich hab das Gefühl, da klemmt was bei mir...
  7. Belze, 30.03.2013 #7
    Belze
    Also bei mir funktioniert es.
    Schau mal in den Einstellungen - Sprache/Eingabe - Tastatur ob da ein Haken bei vibrieren gesetzt ist.
    Gesendet von XperiaS mit UXP
  8. mephistho, 30.03.2013 #8
    mephistho
    Arr, bei SwitfKey war die Vibration-Duration zu niedrig eingestellt... Läuft also
    Edit: Was gibt es denn so für Add-Ons? Ich lese ein bisschem im xda Thread. Gibt's noch andere Infoquellen dazu?
  9. Belze, 30.03.2013 #9
    Belze
    Also ich habe JB-Album, Xperia Z UI und Settings with CPU Control.
    Einfach mal auf XDA weiter runter scrollen.
    Hier nochmal die aufgeführten Addon´s.
    * Add Ons requested by some users
    Jelly Bean full Album app
    Social Engine Core (if you want picasa and fb picture integration)
    JB Weather Widget (working now)
    Stock Email app
    New Xperia Z style SystemUI (full HDPI, no more blurred icons)
    *****MAX Brightness Mod by gagan.u20 (request by several Zelly Cream Lovers)***** (No wiping is required)
    Note: Maximizing brightness may lower down battery backup, so if you have installed this mod then don't ask me for fast battery drain reasons and don't post bad results about battery backup. If you want to go back to stock brightness level then install this and choose Stock Brightness level.
  10. Urizen_Darkest, 31.03.2013 #10
    Urizen_Darkest
    Urizen_Darkest Android-Hilfe.de Mitglied
    Hat die RoM einen Theme Chooser? Offensichtlich hab ich das auf XDA überlesen. Weil ich mag die Z UI nicht wirklich leiden.
  11. Belze, 31.03.2013 #11
    Belze
    Das wäre Android 4.1
    Ich habe mal noch paar Bilder hinzugefügt.
    Siehe mal oben bei die Bilder rein. Meinst Du das mit Theme Chooser?
  12. Urizen_Darkest, 01.04.2013 #12
    Urizen_Darkest
    nein, ich meinte echten theme chooser heisst auch T-mobile theme chooser. RomTools hat unterstützung fürs suchen der themes, aber es hilft nix wenn der chooser nicht implementiert ist wie bei Cyanogen zum bleistift
  13. Belze, 01.04.2013 #13
    Belze
    Achso, nein das nicht.
    Man kann bloß im Aroma Installer verschiedene Sachen auswählen
  14. Urizen_Darkest, 01.04.2013 #14
    Urizen_Darkest
    ja das habe ich alles bereits gesehen. Ist nicht wirklich tragisch. dann muss ich eben einen weg finden um zum beispiel icons zu ändern oder farben. Hintrgründe kann man auch zum glück mit normalen wallpaper einstellen.
  15. Belze, 01.04.2013 #15
    Belze
    Es gibt aber auch Theme Chooser im Play_Store. Wenn die Dir zusagen. ;)
  16. Urizen_Darkest, 01.04.2013 #16
    Urizen_Darkest
    ja aber es sind ganze launcher, und eben das wollt ich eben nicht... ich mag den GX launcher
    den hatte ich schon mal
  17. Urizen_Darkest, 07.04.2013 #17
    Urizen_Darkest
    ist es normal das versteckte apps trotzdem im drawer auftauchen? seit vorgestern sind die verteckten wieder im drawer und auf der liste trotzdem als versteckt markiert.
    kommt mir seltsam vor.
    ich mag ungern schon wieder full wipe clean install durchführen... vor allem weil es ja sonst einwandfrei läuft
  18. StillerLeser78, 25.04.2013 #18
    StillerLeser78
    StillerLeser78 Erfahrener Benutzer
    Moin. Die Rom finde ich ganz gut. Allerdings bin ich mit dem rush-kernel in Sachen Akku-Laufzeit nicht zufrieden. Bereits nach 14 Stunden waren es nur noch 39%. Mit dem stock hatte ich das nicht, obwohl die Einstellungen die gleichen sind. Wie sind es mit den Alternativen aus?
  19. Belze, 25.04.2013 #19
    Belze
  1. gagan.freeram sony xperia xda
Du betrachtest das Thema "[ROM][JB]Zelly Cream v2.5 - True Xperia Z Jelly Bean ROM" im Forum "Custom-ROMs für Sony Ericsson Xperia Arc S",
  1. Android-Hilfe.de verwendet Cookies um Inhalte zu personalisieren und dir den bestmöglichen Service zu gewährleisten. Wenn du auf der Seite weitersurfst stimmst du der Cookie-Nutzung zu.  Ich stimme zu.
