Q
quercus
Gast
Quelle: XDA
Autor: Doomlord
Link: [KERNEL][ARC] DooMKernel [Rel: v08][Dt: 15/Aug/2011][FW:4.0.A.2.368]
hello guys!
i am new to kernel development but i think this kernel would be useful for a lot of ppl using stock SE 4.0.A.2.368 FW... for older kernel versions for older FW refer to following: Older Releases [FW: 3.0.1.A.0.145/146/148]
[ disclaimer ]
OVERCLOCKING CAN BE DANGEROUS! U RISK THE HARDWARE GETTING DAMAGED!
PROCEED WITH CAUTION! U HAVE BEEN WARNED!
I AM NOT TO BE HELD RESPONSIBLE IF U DAMAGE UR PHONE / SPILL UR COFFEE / MISS UR ALARMS / ANY OTHER CALAMITY/MISHAP
[ features ]
[ credits for features ]
[ requirements ]
[ how to install ]
https://github.com/DooMLoRD/Xperia-2011-Kernel-2.6.32.9
[ donations ]
if u feel that this work has helped u OR u think that the work i put into making this is worthy of donations, then click on the following link for buying me some coffee/beer/etc
PAYPAL DONATION LINK
FreeXperia PROJECT: if you want to support FreeXperia PROJECT (creators of working recovery) you can donate
https://www.paypal.com/cgi-bin/websc...=YJ7AK6HLAVNHU
[ downloads ]
<NEW>
[ARC] DooMKernel (v08) (FW: 4.0.A.2.368)
< OLD FILES >
[ARC] DooMKernel (v07) (FW: 4.0.A.2.368)
[ARC] DooMKernel (v06) (FW: 4.0.A.2.368)
[ARC] DooMKernel (v05) FIX-01 (FW: 4.0.A.2.368)
[ARC] DooMKernel (v05) (FW: 4.0.A.2.368) (has issues with recovery avoid this version)
[ARC] DooMKernel (v04) (FW: 4.0.A.2.368)
[ARC] DooMKernel (v03) (FW: 4.0.A.2.368)
[ARC] DooMKernel (v02) (FW: 4.0.A.2.368)
[ARC] DooMKernel (v01) (FW: 4.0.A.2.368)
known bug in v1:
lag... to resolve.. install setcpu/nofrills cpu app and correct min & max cpu speeds
[ for modders/themers/others ]
hey guys here i am attaching a template update.zip which has been tested to work on the recovery provided here... u can add ur stuff to that file and edit the updater-script so that the u can flash ur files via this recovery...
basically it contains the correct combination of update-binary & mounting syntax...
this file is NOT required for normal/general users
TEMPLATE UPDATE.ZIP (v1)
[ older versions ]
Autor: Doomlord
hello guys!
[ disclaimer ]
[ features ]
- [v08 onwards] added new logo!! Thanks to soheil_rf
- [v08 onwards] added I/O Schedulers:
- V(R)
- BFQ
- [v08 onwards] added CPU Governors:
- Smartass
- Scary
- MinMax
- [v08 onwards] enabled NLS_UTF8
- [v07 onwards] added user-level/runtime CPU voltage control [VDD control "sysfs interface"] (for more info keep checking this post: http://forum.xda-developers.com/show...&postcount=362)
- [v07 onwards] added Interactive CPU Governor
- [v07 onwards] added new Max frequency: 1.9Ghz
- [v07 onwards] added lots of intermediate frequencies (from 122Mhz to 1.9Ghz for almost every 100/120Mhz there is a select-able frequency)
- [v06 onwards] updated recovery related scripts to resolve mounting issue
- [v06 onwards] added cpu freq thresholds to throttle CPU speeds to stock values when inside recovery
- [v06 onwards] corrected adb issues (in both OS & recovery)
- [v06 onwards] added lots of intermediate frequencies
- [v05-FIX onwards] updated recovery related scripts to resolve mounting issue
- [v05-FIX onwards] added cpu freq thresholds to throttle CPU speeds to stock values when inside recovery
- [v05 onwards] updated recovery to CWM v4.0.1.4 FreeXperia Team [it is recommended to use v05-FIX and above]
- [v05 onwards] {ramdisk tweak} /sd-ext also symlinked to /mnt/sd-ext
- [v05 onwards] enabled SWAP support
- [v05 onwards] enabled CDROM filesystem support in kernel (now u can mount ISO files)
- [v04 onwards] enabled a few I/O Schedulers
- noop
- Anticipatory
- Deadline (default)
- CFQ
- [v04 onwards] enabled ARM THUMBEE extensions
- [v03 onwards] added new LOGO... no more boring SE TEXT logo
- [v02 onwards] under/overclocked from 128Mhz to 1.862Ghz [NOT UNDERVOLTED] (for sake of safe booting the device will always boot at min 245Mhz / max 1024Mhz)
- [v02 onwards] init.d scripts/binaries execution support
- [v02 onwards] enabled support (in kernel) for many file systems
- EXT2
- EXT3
- EXT4
- NTFS (Read & Write)
- [v02 onwards] enabled NFS (client & server) support in kernel
- [v02 onwards] enabled CIFS support in kernel
- [v02 onwards] enabled access to kernel .config (can be pulled from /proc/config.gz)
- [v02 onwards] enabled TUN/TAP driver support (integrated in kernel) [VPN support]
- [v02 onwards] USB-OTG support (already enabled in SE FW)
- [v01 onwards] autorooting (prerooted)
- kernel is insecure (ro.secure=0)
- su binary & superuser.apk will automatically be installed by kernel (thanks to Bin4ry for posting the file RootXperia.zip; i have used the superuser files from his zip)
- busybox already installed in /sbin/
- [v03 onwards] busybox will get copied to /system/xbin/ if its not present there
- adb server is persistent
- usb debugging enabled
- rootfs and /system mounted as rw (thank you Blagus for the tip )
- [v01 onwards] CWM recovery (Thanks to FreeXperia team)
- BFQ I/O Scheduler ported from richardtrip's Kernel sources for Bravo by richardtrip
- V(R) I/O Scheduler ported from LeeDroid Kernel sources for Ace by LeeDroid
- Smartass CPU Governor ported from UmaroKernel sources by umaro (original posted by erasmux) [Fixed/modified for SEMC Devices]
- Scary CPU Governor ported from UmaroKernel sources by umaro (original posted by scaryghoul)
- MinMax CPU Governor ported from UmaroKernel sources by umaro
- NEW LOGO Thanks to soheil_rf
- Interactive CPU Governor ported from UmaroKernel sources by umaro & from Bukington gaosp Kernel sources
- VDD control "sysfs" interface ported from UmaroKernel sources by umaro (original posted by snq- here)
- CWM Recovery FreeXperia Team
- {OLD} initial freq-Overclock table if2
- {OLD} bootscreen/bootlogo/bootimage used from http://forum.xda-developers.com/showthread.php?t=928352 with permissions of Sentinel196
- original RootXperia.zip file Bin4ry
- autorooting inspired from CF-Root for SGS2 (Chainfire)
- and finally ME for getting this all together for u guys
[ requirements ]
- stock SE 4.0.A.2.368 FW (available from here: http://forum.xda-developers.com/show....php?t=1199003)
- bootloader unlocked
- working fastboot
- u have read this: [How-To] Safely test custom kernels / custom ROMs and get back to stock SE 2.3 ROM
- android app for overclocking like SetCPU (paid) or NoFrills CPU Control (free)
- NoFrills CPU Control (free) to select I/O scheduler
- VDD control app: IncrediControl
- [OPTIONAL] CIFS Manager (free)
- [OPTIONAL] Swapper 2 (free)
[ how to install ]
- download the boot.img
- save the boot.img in the folder with fastboot binaries (fastboot.exe files)
- power down device
- start device in fastboot mode
- use the following command to flash the boot.img
Code:
fastboot flash boot boot.img
- reboot phone and enjoy the kernel
- FOR OVERCLOCKING
- start SetCPU/NoFrills CPU Control app on ur Arc (or any other app which supports overclocking) (u may get a popup asking for SuperUser permissions, click ok/yes/allow)
- now slowly increase the MAX slider to the right (one notch at a time) to increase the maximum frequency limit
- DO NOT JUMP TO THE LAST POSSIBLE FREQUENCY
- SLOWLY increase the frequency one notch at a time and do stability/testing for few hours
[ donations ]
[ downloads ]
<NEW>
< OLD FILES >
known bug in v1:
[ older versions ]
Kann mir einer von euch da vielleicht weiterhelfen oder mir ne nicht ganz so energie verbrauchende kernel empfehlen? Sollte es das nicht geben, kann ich meine alte Kernel wieder flashen? Und wenn ja wo bekomm ich die her?=) Danke für eure Hilfe!
