[KERNEL][ARC/ARC S]ArcKnight Kernel V7 FINAL - ICS/ Update April 27!
Also mit Arconium 3.c funktioniert er wunderbar, liegt wohl an der .431 leak version.
ich bekomme leider bei JJ 3b kein wlan
module installiert und auch cache gelöscht
PS: nach dem 3. Versuch geht alles
Die neue Version ist raus, basierend auf den offiziellen Sony .431 Sources:
xda-developers - View Single Post - [KERNEL][ARC/ARC S]ArcKnight Kernel RC3 (.431 Sources)- ICS/ Update June 16th!!
So guys as promised ArcKnight Kernel RC3 is out for Testing!!!!
Thanks to
  1. XDAarc2011
  2. smsconim
  3. iambroken
  4. Specially LiquidRobotics for all the help through the day to find some fixes to latest bugs
@Testers: You'll have to download this new version, some minor fixes were done today so you'll have to update
ChangeLog:
  1. Merged with Latest .431 Sources - Thanks Sony for the Update
  2. Added CleanCache Driver
  3. Introduce of ArcKnight Governor
  4. Updated BFQ IO scheduler for smoothness
  5. Updated BFS Scheduler - The old one was causing some weird issues and freezes.
  6. Minor bugfixes that I don't actually recall hahaha...
ArcKnight_Governor:
The ArcKnight Governor is intended to provide some average to good performance while also providing some good battery life usage. The phone will step up to higher cpu freqs when cpu load is heavy but will decrease to the lower ones faster than Ondemand and all other Ondemand based governors.
The governor is a modified version of Conservative but with better performance.
IMPORTANT!!! FOR .431 STOCK USERS
If you want to use ArcKnight Kernel RC3 with your Stock .431 firmware you'll have to do as follows:
  1. Flash ArcKnight Kernel RC3 via Fastboot
  2. Flash Stock .431 firmware through Flashtool marking the "Exclude Kernel" option
  3. Reboot your device and you'll have no FC's at all.
Schade muss wohl warten bis ich den benützen kann
Wieso ? , funktioniert der mit deiner ROM nicht ?
Handy in Reparatur,
Freue mich aber schon wenn ich es wieder hab.
Mit meinen alten HTC Touch Pro 2 muss ich bin dahin auskommen
Habe mal den Kernel draufgepackt ! Fazit : Sau schnell und sehr Akku schonend !
Doch habe ich das Gefühl das er sehr ruppig ist , Reagiert sehr schnell und das Umblättern stockt dann schon mal !
Habe die Arconium 4.0 drauf .
Was mir noch aufgefallen ist das wenn eine SMS rein kommt wohl der Ton da ist aber nicht das Blinken der LED ? Gibt es eine Erklärung dafür ???
Gruß Kalle
Gruß Kalle
Versuch mal einen anderen Governor, hat bei mir geholfen.
Das mit der LED ist mir auch schon aufgefallen, das problem liegt allerdings nicht beim Kernel sondern bei der ROM bzw. Android 4.0.4, denn seit Arconium 3 funktioniert die nicht mehr.
Reaktionen: Fire123
Welchen Governor hast Du genommen ? Bei mir stehen sehr viele drin !
Ich hab als erstes den ArcKnight Governor getested, der hat bei mir dieses rütteln verursacht, nun versuche ich conservative mit sio scheduler, mal sehen wie der ist. Sonst versuche ich wieder den ondemand mit vr.
Ich schaff es nicht, mein WiFi zu aktivieren :(
Hab den Kernel geflasht und anschließend die Module per CWM, aber ich kann es trotzdem nicht aktivieren.
Hab die arconium 4.0 drauf.
Welche Version, bei RC3.1 funktionieren die WiFi Module noch nicht, muss erst noch gefixt werden. Nimm am besten RC3 mit den dazugehörenden Modulen.
Kernel: ArcKnight_RC3.img
Module: ArcKnight_RC3_WIFI_Modules.zip
Das hat man davon, wenn man immer up-to-date sein will ^^
Dann flashe ich heute Abend mal 'nur' den RC3 - danke für die Info.
Also ich bin auf RC 2.2 zurück gegangen !
Unter RC 3 nur am Stocken , egal welchen Governor ich wähle ! auch Deep Sleep war nicht so ganz Überzeugend ! doch OS blieb konstand bei 2 % !
vieleicht wird es ja bei der 3.1 besser !
Gruß kalle
Es gibt Test-Versionen von RC 3.3:
xda-developers - View Single Post - [KERNEL][ARC/ARC S]ArcKnight Kernel RC_3.3 (TEST Versions)- ICS/ Update June 22nd!!
Es gibt 2 versionen, Stock und Overclock:
The features of both versions are as follows:
STOCK CPU BASED KERNEL:
  1. Two Way Call Recording Patch
  2. 0% Battery Friendly with latest fixes.
  3. Latest Adreno Sources patched.
  4. KGSL power Management Tweaks. - Super Smooth UI
  5. Wifi Voltage Lowered
  6. Charging power increased, now charging from USB ports should be a bit faster
  7. LCD Panel voltage Lowered - It should use less battery when screen is on
  8. CPU Driver based on stock .431 sources, this means 1024 HZ for Arc users and 1400 HZ for Arc S Users...
  9. Removed VDD Support - Adding this will modify the clock source and hence loose the benefit of the "Stock" clock... I'll add it back if everything goes well
  10. Voltages lowered to a safe range for all frequencies - Though I can't remember now what values I've set hehehe...
  11. Tiny RCU instead of TREE RCU
  12. SLQB Allocator instead of SLAB
  13. CFQ, SIO and VR IO Schedulers modified and optimized fo Flahs Memory Devices..
  14. Memory Allocations tweaks like Kernel Granurality and Vm Dirtinesss
  15. ArcKnight CPU Governor modified to work with the NEW CPU Table, I know it was slow the first time but TRUST me it if smooth and fast and it will save your battery better than ondemand and intellidemand
OverClock Based Kernel:
  8. CPU Driver based on my own modified sources, it is the same as per the previous versions of ArcKnight Kernel
  9. Tiny RCU instead of TREE RCU
  10. SLQB Allocator instead of SLAB
  11. CFQ, SIO and VR IO Schedulers modified and optimized fo Flahs Memory Devices..
  12. Memory Allocations tweaks like Kernel Granurality and Vm Dirtinesss
  13. ArcKnight CPU Governor modified to work with the NEW CPU Table, I know it was slow the first time but TRUST me it if smooth and fast and it will save your battery better than ondemand and intellidemand
Version 3.4 ist raus:
xda-developers - View Single Post - [KERNEL][ARC/ARC S]ArcKnight Kernel RC_3.4 (TEST Version)- ICS/ Update July 6th!!
Changelog:
  1. Added Back BFS Scheduler
  2. Added Back BFQ IO Scheduler
  3. Removed 122MHZ Freq, it was replaced with the 245MHZ to avoid slowdowns
  4. Attempt to add USB-OTG Support for Mouse, Keyboard and Storage
USB-OTG Modules:
This are the modules specific for my kernel configuration, since I have no access to a USB-OTG Cable I Can't garatee that they will work, I need the users that actually have that cable to confirm wheter if it's working or not...
The procedure to load the modules should be the same as per any other modules:
  • Move the desired module to /system/lib/modules
  • Open up Terminal and do: insmod /system/lib/"name of the module"
  • Test if it's working
  • If you want to autoload the modules then just put a file in the init.d folder containing the line above and save it.
Also irgenwie will die 3.4 nicht so richtig bei mir ! Nur Stocken egal welchen Govaneur ich wähle ! Das Problem hatte ich schon unter der 3.0 ! Die wo bei mir am besten läuft ist die 3.3 .
Schon irgenwie komisch
Gruß Kalle
Da muss ich dir recht geben, bei 3.4 hatte ich auch Ruckeln/Zucken im Launcher, hab jetzt ArcKnight_II mit sio eingestellt und das funktioniert ganz gut. Das ganze ist auch sehr ROM abhängig, ich habe die letzten Tage mal jede Custom durchprobiert bin allerdings immer wieder zu Arconium zurück, die funktioniert für mich immer noch am besten.
Ich warte auch auf den neuen "ThunderBolt" Kernel, eine neuauflage des Trinity Kernels von ChaosFirZen, der Trinity war schon recht gut. Ausserdem darf ich mir auf die Fahne schreiben das der Name ThunderBolt Kernel meine Idee war und ich ebenso das Bootlogo sowie den Signaturbanner entwerfen durfte, was mich schon ein wenig stolz macht. :biggrin:
Reaktionen: Fire123
Na ich dachte ich bilde mir das nur ein mit dem Ruckeln , doch jetzt habe ich mal einen Anhaltspunkt.
Allerdings fehlt mir die zeit alles zu probieren und bin immer froh wenn es Leute wie dich gibt :cool2:
Werde mal abwarten was noch kommt und auf alle fälle Probieren !!!!
Habe die Tage nochmal mein X 10 Angemacht und musste festsellen das es um einen ganzen ecken schneller läuft :confused2:
Auf dem X10 ist doch sicher noch Gingerbread drauf oder ? , mein Arc war mit GB auch Pfeilschnell. :razz:
  • Gesperrt
  • diuty
iSchneiderle
I
  • 24559
snoopy-1
snoopy-1
  • Josh.
xy150
X
