[KERNEL][ARC/ARC S]ArcKnight Kernel V7 FINAL - ICS/ Update April 27!
Ohja, GB ist schnell ;)
Version RC 3.5 ist da:
xda-developers - View Single Post - [KERNEL][ARC/ARC S]ArcKnight Kernel RC_3.5 (TEST Versions )- ICS/ Update July 12th!!
ArcKnight_Kernel: RC3.5 - Stock and OC Versions:
Changelog for both Versions:
  1. Removed BFS Scheduler - It was the cause of all the "Weird" touch issues, I'll try to implement it again later on once I figure out how to reduce the "Extreme" responsiviness of the Screen
  2. Added ZRAM Driver.
  3. Removed the 122MHZ freq.
  4. 245 MHZ freq. is now the lowest by default to avoid "wakeup" lags.
  5. ArcKnight_II Governor Updated to match the new frequencies.
  6. USB OTG modules preconfigured and are now part of the Kernel, no need to insmod them again... Just attach your USB OTG device and you'll be set
  7. Some minur bugfixes that I don't remember at the moment
Zram will provide a smoother UI and Kernel Experience so as Multitasking BUT it might affect performance with Heavy or RAM Hungry Games...
I need you to please test how is battery life when Zram is Activated...
Update:
ArcKnight Kernel RC3.5.1 - Wifi and Zram Fix!
Ok Guys!
I've had to recompile the RC_3.5 Kernel in order to fix the Wifi issue and the Zram issue as well. The changelog remains the same, only difference now is that Both Wifi and Zram are working Properly.
Please download your Prefered Version of the Kernel (Stock Based CPU or OverClocked CPU) and test again, you'll NEED to download and flash the ArcKnight_RC3.5.1_Test_Version_Modules.zip in order to have Wifi and Zram Working.
ZRAM Configuration:
The Zram Configuration running for this specific Build is:
  1. Swapinnes was set to 60
  2. Zram Disk Size is around 96~100 MB
If you need more space on your Zram Disk just type this on Terminal Emulator:
Code:
echo $(("Disk Size"*1024*1024)) > /sys/block/zram0/disksize
Where "Disk Size" is the ammount of MB's you want, for example you want a Zram Disk of 200MB's just type:
Code:
echo $((200*1024*1024)) > /sys/block/zram0/disksize
Reaktionen: Fire123
"PS: @Liquidrobotics - Buddy I'll make the "special" kernel you requested for me, just let me know based on what sources you need it ... I can be RC3.3, RC3.5.1 or this new build..."
Was ist da los, Liquid?
Die goldenen Zeiten für unser Arc sind leider fast vorbei und es wird mehr und mehr der Support der Dev´s eingestellt da sie alle auf neuere Modelle gewechselt haben.
Jimbo77 macht da keine ausnahme, er ist seit kurzem stolzer Besitzer eines Galaxy S3 und wird ebenso keine Kernel mehr für´s Arc machen.
Ich hab ja in der vergangenheit einige Bootlogos und Signaturbanner für ihn erstellt, allerdings ist das aktuelle Logo von jemand anderes. Ich hatte ihn gebeten für seinen letzten Kernel eine Version für mich zu machen mit meinem Bootlogo und deswegen durfte ich mir die version aussuchen.
Ich habe mich für die RC 3.3 entschieden da die mit abstand am besten läuft.
Im laufe des Tages wird noch RC 3.6 veröffentlicht, der wird dann möglicherweise der letzte Kernel sein.
Schade eigentlich
Was ist jetzt bitte der neueste ArcKnight Kernel?
Und hat jemand Changelogs?
Hey, der 3.6er bringt mir nach dem ArcKnight Logo einen schwarzen Bildschirm was aber auch oft im XDA Thread zu lesen ist. Hoffe es wird gefixed.
Für alle die den 3.5.1 Stock Kernel mit dem Original Sony Logo wollen habe ich ihn mal angehangen. Ich hoffe jemand von euch kann ihn im Thread bei den XDA Devs einfügen da ja öfters nach gefragt wird.
Ich bin nun soweit Happy mit dem Kernel. :)
  • ArcKnight_Kernel_RC_3.5.1_STOCK_TEST_SONY_BOOTLOGO.zip
Ich benutze auch die 3.3, da mein ARC mit dem 3.5.1 Kernel nicht in den DeepSleep verfällt.
Die 3.3 läuft perfekt, aber irgendwie finde ich nicht die richtigen Wifi-Modules, die von der 3.1 funktionieren ja nicht.
Die von der 3.6 und 3.5.1 schon, aber ist das ok (vorallem sind alle Funktionen gegeben - Reichweite vom wlan, Geschwindigkeit usw)?
Ich hab nun auch eine Version des 3.3-Kernels mit Sony-Logo erstellt (danke an Muwahhid - hab das Logo aus deiner 3.5.1 Datei.)
  • ArcKnight_RC3.3_OC_SONY_LOGO.img.zip
Denke, das wird nichts ausmachen. War damals beim Doomkernel genauso, da gabs 1x Wifi für 15 Kernel.
Es gibt wieder eine neue Version von dem Kernel
  • Gesperrt
  • diuty
iSchneiderle
I
  • 24559
snoopy-1
snoopy-1
  • Josh.
xy150
X
