[ROM][14thSEP] MIUI BlackEditionHD_v0.2[Gingerbread 2.3.5]
Q
quercus
Gast
Quelle: XDA
Autor: crowds
Link: [ROM][20thSEP]BlackEditionHD_v0.2[Gingerbread 2.3.5]
BlackEditionHD​
(Based on MIUI 1.9.9 | Android 2.3.5 | Full Language Pack)
GINGERBREAD PORT MIUI 1.9.9 NEXUS1 FROM HERE
Credits:
  • Rdannar (who help me and give some lights on how-to, thx pal
  • DooMLoRD (who show me the way on a god damn issue i had, thx pal
    and kernel);
  • jerpelea & zdzihu & FreeXperia Team for not freakin`out
    on port/use files. And of course for sharing there sources/knowlage
    and kernel;
  • Huge thanks to briandevlin for testing this before release
  • iridaki for excellent Suave Icons HD used on v0.2
  • MIUI Dev Team
Notes on this build:
  • Personally i just "hate" the iPhone look of MIUI but i really love the other stuff so this is a sort of mix.
  • This is not to be as others around here. This was made to preform a good performance/clean/battery rom so if you miss animations and other visual aspects don´t blame me. Blame you. You just pick the wrong rom
Features:
  • LP Sense UI;
  • Stock Kernel to support DeepSleep (Doom´s Kernel supported as well);
  • Completed striped version - 78mb/191mb RAM free/421mb Internal Storage;
  • Circle battery;
  • All animations disable;
  • and more...
Bugs/Not Working:
  • Date on lock screen;
  • Sometimes data loss (i´m convinced this happens due MIUI/port issues and not because any other thing. I may be wrong tho;
  • Let´s found some
Installation procedure:
  • wipe everything;
  • install BlackEditionHD_v0.2.zip;
  • reboot;
  • Press menu (left button) > Preferences > Restore Backup;
  • reboot;
  • go to data > system and delete batterystats.bin with root explorer then reboot
  • always check 2nd post for tweaks, fixes, patches (if any);
  • enjoy (or not
note: v02 take longer to cache everything and/or do anything so it´s expected it returns fully operational after 5/10 minutes
Downloads:
old version
Changelog:
MIUI 1.9.9 Changelog (Full):
Changelog:
  • MAY 13th - first release
  • MAY 14th - minor bug fixes, reboot fix, some hacks added
  • MAY 18th - New launcher, added LaucherPro tweaks from DooMLoRD (follow instructions bellow), added some widgets, contacts clean-up (fix for SMS - read bellow), uncap fsp, some general improvements
  • MAY 24th - Now you can choose beetween 3 launchers at anytime (LaucherPro, ADW and Go Launcher EX), new system animations, GoodMorning, Bubbble, Chrome2Phone, DSP Manager, Spare Parts 4, XDA app and more
  • SEP 12th - 2.3.5 gingerbread with kernel support
  • SEP 14th - 2.3.5 gingerbread with kernel v05 from Doom support
    • Change from LP SenseUI to LP due some issues
    • Doom´s Kernel with deepsleep supported
    • Bravia Engine ON by default
    • xLoud OFF by default
    • Suave Icons on v0.1 Theme from My_Immortal
      .....uppps iridaki
    • MIUI Optimization thx to 28spawn
    • Increase screen sensibility
    • Much Smoother/faster
    • Unlock Slide Screen
    • Added aicbootfix.apk (may increase battery life)
    • Added talk.apk
    • Much more hacks & tweaks in system
apk files:
HERE you can find all removed apps.
foe mail app please install through xRec
If you don´t know how to use/install these apk ...
default_MIUI_apps - [mirror]
  • aicbootfix.apk
  • Calculator.apk
  • Calculator.apk
  • DeskClock.apk
  • Monitor.apk
  • SoundRecorder.apk
  • SoundRecorder.apk
  • VoiceDialer.apk
extra_MIUI_apps - [mirror]
  • CloudService.apk
  • MIUIStats.apk
  • Notes.apk
  • SimpleLiveWallpaper.apk
  • Stk.apk
  • TelocationProvider.apk
  • Updater.apk
gmail - [mirror]
MIUI_launcher - [mirror]
Add-Ons/Fixes:
- [mirror]
Basebands:
  • baseband supported 2.1.71
Hidden features:
  • Hidden phone tests: Open dial pad type *#*#MIUI#*#* or (*#*#6484#*#*);
  • More hidden phone tests/settings: Open dial pad type *#*#4636#*#* (more for advanced users!!! If u don't know what u doing than don't change any settings here !!!)
Figooo
Gast
Ich habs mal getestet. Spontan hatte ich das Problem, dass der mein WLAN-Netzwerk gefunden hat aber nicht verbunden hat. Kann keine IP-Adresse erstellen. Von daher nicht brauchbar
MfG, Figooo
Q
quercus
Gast
Welche Wifi-Module hast genommen? - bei mir gehts einwandfrei.
Figooo
Gast
Wo kann ich das sehen?
Scum
Scum
Experte
Brauch mal ne objektive aussage in wieweit es sich lohnt dieses ROM zu testen??
Figooo
Gast
Wenn wlan funzt werde ich es mal testen. Was muss ich tun??
veryjo
veryjo
Stammgast
habe mal bei den xda´s bezüglich des wifi-probs recherchiert.
folgende weiterführende posts habe ich kopiert:
wem die einzelnen vorschläge zu aufwendig sind, kann sich direkt die gefixte version downloaden (link ganz unten):
Crowds or anyone else
Installed the rom .how can i find the correct wifi mudole?
thanks
Replace it from v0.1
In system/lib/modules and don't forget to set permissions
Sent from my X10i using Tapatalk
i'm having error when trying to activate wifi, any chance somebody having the same problem?
With root explorer copy from v.0.1 system/lib/modules/wifi.ko to v.0.2, fix the permissions (all from first column plus top of the second) and reboot.
I tried it and it worked
-------------------------------------------------------------------------------[FONT=&quot]
This for all got error wifi and bluetooth [/FONT]
[FONT=&quot]
here which itrying to fix wifi and bluetooth its working for me no any problem now after 1 day ...
1- Need miui 199 ROM (ZIP file No Extract ) .
2- BlackEditionHD_v0.2 ( ZIP file No Extract ) .
3- Watch The my video instructions .
[/FONT][FONT=&quot]SRFile2011_9_16_1_12_16_359.avi - YouTube
[/FONT][FONT=&quot]
4- when you finishing add the file in BlackEditionHD_v0.2 colsed and flash with Xrec .. Don't wipe any thing just flash over the rom
Sorry for my bad English and i hope some experience man how can write the steps for us
Regards
-----------------------------------------------------------------------------------------------------------[/FONT]
Yes Wifi blue cam gps +++ working
Download link
BlackEditionHD_v0.2.zip (104,86 MB) - uploaded.to
Figooo
Gast
Das mit dem wlan funzt. Danke!!! Das flashen der apps funktioniert aber nun nicht via xrec. Wenn das klappt kann ich die rom testen.
MfG, figooo
Figooo
Gast
Danke kommt wenn ich am PC sitze!
veryjo
veryjo
Stammgast
MfG, figooo
na immerhin ist das wlan gefixt..
was meinst du mit "apps via xrec"?
versuchst du ein zuvor erstelltes backup wieder einzuspielen?
Figooo
Gast
Nein die apps von der xda seite...
MfG, Figooo
veryjo
veryjo
Stammgast
was genau hast du versucht...?
welche fehlermeldung erscheint..?
ertwas mehr info wäre hilfreich...!
Figooo
Gast
Jetzt bin ich auch am PC und kann mal was länger schreiben. Mit dem Handy ist es immer was komplizierter Links zu kopieren und einen längeren Text zu schreiben.
Ich habe die neue Version geflasht. Jetzt funktioniert das WLAN! Danach habe ich versucht die APKs von der XDA-Seite über xRecovery zu flashen. Die sollten doch einfach über "install custom zip" installiert werden oder? Es ergibt sich keine Fehlermeldung. Nach dem Reboot sind die Apps aber nicht da und der "alte" Standardlauncher ist immer noch drauf. Hätte gerne die MiUI Launcher...
[ROM][14thSEP]BlackEditionHD_v0.2[Gingerbread 2.3.5] - xda-developers
2. Post:
  • aicbootfix.apk
  • Calculator.apk
  • Calculator.apk
  • DeskClock.apk
  • Monitor.apk
  • SoundRecorder.apk
  • SoundRecorder.apk
  • VoiceDialer.apk
  • CloudService.apk
  • MIUIStats.apk
  • Notes.apk
  • Stk.apk
  • Updater.apk
gmail - [mirror]
Add-Ons/Fixes:
BEHD_MOD_xloud.zip
Ich hoffe, du weißt was ich meine..
MfG, Figooo
veryjo
veryjo
Stammgast
auch nach einer erfolgreichen installation musst du den neuen launcher erst als standard-launcher definieren.
führe mal eine entprechende aktion durch, zB mittlere taste lang drücken, dann kannst u den gewünschten launcher auswählen.
Figooo
Gast
haha...
Der findet den nicht. Ich habe nur den Standard-Launcher. Das ist doch das Problem. Er müsste ja auch alle anderen Apps drinne haben...
veryjo
veryjo
Stammgast
schaue mal unter system/app ob es da eine launcher2.apk gibt. das wäre dann der neue launcher.
wenn nicht entpacke die launcher.zip, in dem ordner launcher findest du unter system/app die launcher2.apk.
installiere diese von der sd-card...
Schmalzstulle
Schmalzstulle
Experte
Warum soll ich bei der Installation die Battery Stats löschen??? Was haben die mit dem Rom zu tun??
Figooo
Gast
Geht leider nicht. Die APK wird nicht installiert. APK war nicht vorhanden. Neue Idee??
veryjo
veryjo
Stammgast
gibt es eine fehlermeldung...?
wie läuft die rom denn sonst so?
Figooo
Gast
Der sagt nur dass die anwendung nicht installiert werden kann. Wenn ich unter einstellungen den launcher ändern will gibt es die fehlermeldung com.android.settings wurde unerwartet geschlossen...
Sonst gefällt die rom mir sehr gut. Sehr flüssig. Der browser macht im gegensatz zum stock android browser keine probleme. Lädt einfach alles. Nur optmich möchte ich den miui launcher gerne haben.
MfG Figooo
