[ROM] [2.3.3 / Stock] Leaf GB r3 *FINAL* [28 Nov] [xRecovery]
Q
quercus
Gast
Quelle: XDA
Autor: doomed151
Link: [ROM] [2.3.3 / Stock] Leaf GB r3 *FINAL* [28 Nov] [xRecovery]
Super-lightweight stock ROM with minimal tweaks.
Also, it's fast. Did I mention it's fast? Maybe not in benchmarks but it's very snappy and smooth in actual usage. You won't believe it unless you try it.
In fact, this is the ROM that I've been using since I made it 2 months ago.
Q: "Is it just a stripped ROM?"
A: Yes, it is, but have you seen other ROMs like this? Almost every stock-based ROM out there are heavily modded, that's why I made this.
Q: "When did this ROM start?"
A: It started for the Wildfire and then X10 based on stock Eclair (released on MoDaCo only).
Screenshots (from Leaf GB r1)
Release notes
16/11
- Updated link.
- ROM should boot and work properly now.
r3 - 10/11 (Baseband .71)
*FINAL RELEASE* There will be no more further updates beyond this if everything went well since I've moved on to the arc.
- Remade.
- Better performance.
- Should be problem-free and stable.
Hotfix 2 - 25/9
- Fixed WiFi error experienced by users on stock kernel
r2 - 22/9 (Baseband .71)
- Removed Talk, Email, Gmail and some other hidden unused packages
- Integrated audio stutter fix
- Adjusted tweaks; better for gaming and slightly smoother UI
Hotfix 1 - 13/9
- Should run smoother
- FPS uncap fix
- Replace WiFi module with correct one
r1 - 12/9 (Baseband .71)
- Based on stock 3.0.1.G.75
- Works on either locked/unlocked bootloader
- Removed various apps
- Harmless build.prop tweaks
- Stock-like
- Ad-blocking hosts file
- What's inside is what you see in those shots, no Timescape and other SE add-ons
Download
Updated 16 November. Fixed problems with missing xRecovery and not booting. It was an error on my side, sorry guys!
update-Leaf-GB-r3.zip (81.4 MB / xRecovery)
Package doesn't wipe data. You can flash this over any ROM that is based on stock (ThGo2, Wolfs TW, X10x EWJet, T.E.A.M, Ultima, Blue Sparks etc.) and retain data.
Installation
1. Copy zip package to SD card
2. Boot into xRecovery
3. (OPTIONAL) For a clean install, do a full wipe
4. Flash zip package
5. Reboot
Credits
zdzihu
Bye X10, I'm gonna miss ya
Reaktionen: lkrys
Version - R2
Hotfix!
Update & Final
[ROM] [2.3.3 / Stock] Leaf GB r3 *FINAL* [14 Nov] [xRecovery]
28/11/2011
Entwicklung wurde mit dem letzten Update eingestellt.
meetdaleet
  • Gesperrt
  • Angepinnt
  • meetdaleet
meetdaleet
meetdaleet
  • susan72
susan72
O
Anonym6x6
Anonym6x6
