[ROM] ViolentOS "Apollon"-hotfix1 | 22/02/12 | locked&unlocked BL | CM7&AOSP
Q
quercus
Gast
Quelle: XDA
I have started this Rom with modding ZMOD and now there is a lot of new stuff in here. A lot of tweaks and optimizations, a lot of addons to create a bright spectrum of "different" and unique ROMS for every user.
So here it is, ViolentOS !!!
Have fun
Requirements:
  • BB .71
  • Doomkernel v06 with Bootmanager 2.0 STOCK VERSION (recommended) (thanks to DoomLord ) --> for unlocked Bootloader // or any custom kernel with the old bypass method
  • thkernel for unlocked bl will be soon supported only!
  • working xRec
  • locked or unlocked Bootloader
  • X10 (haha xD)
Install Instructions:
  • Flash Doomkernel v06 stock with Bootmanager 2.0 via Flashtool OR use stock kernel OR flash a custom kernel for locked BL
  • Boot into xRec (via Bootmanager with DoomKernel)
  • Factory reset, wipe cache, wipe dalvik cache (optional wipe batt stats - only with 100% charged battery)
  • install custom zip --> choose ViolentOS-Apollon-01.zip
  • do not forget to flash the wifi modules for kernel !!
  • reboot
  • set up your system how u like it
working: almost everything
not working: tethering (use tethering apps from market) --> will try to fix this !
Features:
  • blazing fast & smooth
  • very light (about 80mb)
  • great battery life
  • battery tweaks
  • performance tweaks
  • network tweaks
  • smoothness tweaks
  • sdcard tweaks
  • connectivity tweaks for every connection
  • VM tweaks
  • LagFix
  • AudioStutter Fix
  • LoopySmoothness
  • SuperCharger V6
  • newest Market
  • xLoud
  • Superuser
  • new Bootanimation
  • AND A LOT MORE!
TO DO LIST:
  • fix tethering
  • and a lot more ..
Hotfix1:
* added missing UberMusic
* added 360Launcher + ICS Themen (choose it in theme settings, download ics lockscreen optionally)
Changelog ViolentOS-Apollon:
* updated market
* removed xloud
* added tons of new init scripts
* removed stock music player --> UberMusic player+widget
* cleaned build.prop
* removed some unneccessary apps
* removed supercharger
* reduced ROM size a bit
* no UI changes for now because i dont have much time right now
* from now on i would recommend thjap Kernel n1-1 for unlocked bl. n3-3 is commin soon too. Dont forget wifi modules.
Changelog V6:
  • corrected some tweaks
  • added a lot of new tweaks
  • LoopySmoothness
  • SuperCharger V6
  • removed torch
  • hopefully fixed xLoud
  • and some tiny stuff..
Thanks to Wolfbreak for some tweaks
Download ViolentOS Apollon:
http://www.4shared.com/zip/u9BU0_dS/...pollon-01.html
Hotfix1:
http://www.4shared.com/zip/ZLyTYSH7/...n-hotfix1.html
Credits to maikinho10 and Wolfbreak!! Thank you very much
Big thanks to ThJap for the tweaks and maikinho for helping me out
ADDONS ARE IN 3rd POST!!!
Screenshots:
http://img594.imageshack.us/img594/1732/shot000001.jpg
http://img718.imageshack.us/img718/1569/shot000003.jpg
http://img580.imageshack.us/img580/526/shot000005.jpg
http://img717.imageshack.us/img717/102/shot000007.jpg
http://img809.imageshack.us/img809/2922/shot000009.jpg
http://img195.imageshack.us/img195/641/shot000018.jpg
http://img412.imageshack.us/img412/9269/shot000019.jpg
If you want to thank me for my work, you can hit the thanks button and/or buy me some beer, coffee, red bull and so on
If you want to donate just click the "Donate to me" Button above my avatar
Credits:
zdzihu, Wolfbreak, spaarc, FXP, a1exander,DoomLoRd,maikinho,seek4
Greets,
Violence
You are flashing this on your own risk, I am not responsible for any Damage your device takes with flashing this rom.[/QUOTE]
Reaktionen: lkrys
Update
[ROM] VMOD V5.1 | Best Battery Life & Performance | 14/11/2011 | locked & unlocke
UPDATE auf V 6
UPDATE
meetdaleet
  • Gesperrt
  • Angepinnt
  • meetdaleet
meetdaleet
meetdaleet
smokie.jo
  • smokie.jo
Ky Mani
Q
quercus
Q
