ROM5/11Xperia_AniKing_V7.0.0_DooMKernel(Unlocked BL)
Q
quercus
Gast
Quelle: XDA
【ROM】【5/11】Xperia_AniKing_V7.0.0_DooMKernel(Unlocked BL)
http://forum.xda-developers.com/showthread.php?t=1332646
Requirements:
  • Any working ROM with xRecovery
  • Flashtool
  • FTF bundle posted below
  • Unlocked BL
  • DoomKernel
  • Xperia_AniKing_V7.0.0_DooMKernel.zip
Features:
  • Stock Sony Ericsson 2.3.3 ROM
  • Pre-rooted (Superuser files pre-installed, busybox pre-installed!)
  • Recovery 0.3 (fully working)
  • FPS Uncap Hack
  • Mobile BRAVIA Engine, xLoud
  • More Free Memory&RAM
  • Build.prop tweaks
  • CPU Governor Tweaks
  • removed unneeded SE and Google Services
  • Ringtones and Notifications on SD Card to save internal Memory
  • faster Startup
  • better Memory Management [more free RAM]
  • improved Peformance, Smoothness and Battery
  • Reboot Options Mod included
  • Compcache Tweak
  • patched app_process & system_server for alot smoother ROM
  • patched sqlite for alot faster IO R/W + Battery
  • Battery Tweaks
  • Process Priority Tweaks
  • Automatic ZipAlign
  • SD Card Speed boosted
  • VM/Sysctl tweaks
  • Kernel tweaks
  • Android Internal Taskkiller tweaked
  • I/O Scheduler tweaks
  • Reduced lags
  • Better memory management
  • Network speed tweaks & improvements
  • Most of the beautification from ThGo2 thanks
  • alot more so check it out....
ScreenShots
How to install this ROM?!
1.Unlock BL
2.use flashtool flash X10_2.3.3_DooMKernel-v05a-BootManager-v1.3.ftf
3.Reboot into xRecovery and make a back-up of your current ROM. (You'll need a working xRecovery or else it will say Device/SD Card busy).
4.Wipe the following in xRecovery:
  • Factory Reset (Full wipe)
  • Wipe Cache Partition
  • Wipe Dalvik Cache
5.Go to install Custom Zip and chooseXperia_AniKing_V7.0.0_DooMKernel.zip
6.Go to install Custom Zip and choose x10_gb_DooMKernel-v05a_wifi.zip
7.reboot``` finish.....
8.Good Luck
9.thank you eyerybody```
DownLoad:
Reaktionen: lkrys
UPDATE
ROM】5/11】Xperia_AniKing_V7.0.0_DooMKernel(Unlocked BL)
AlexGfX
Q
quercus
Q
Q
quercus
Q
