[ROM][Android 4.4.2][MOKEE][Built From Source]
  • 0 Antworten
Technoolli
Technoolli
Stamm-User
112
:::: This ROM is based on CM 11.0 and made from MoKee Open Source. ::::
::::::: More about MoKee Open Source :::::::
Mfunz/Mokee os Official page MoKee OpenSource Project | Android Community Rom based on Kitkat
Developers 贡献者 | MoKee OpenSource Project
Statistics: é*”趣开源统计
Github: https://github.com/MoKee
code tracking: MoKee Bug Tracker Main Page
::::::::: Main Features :::::::::
- Android 4.4.2
- cLock Lockscreen and Homescreen widget
- HALO
- PIE control
- Calendar - with lunar and solar calenders
- Lunar calendar in lock screen
- Task switching sidebar in recent apps (the list will increase if you install supported apps)
- Bulk SMS recipients
- Adjustable SMS font size
- Smart dialing
- IP dialing
- Adjustable navigation bar height
- Custom transparency for status bar and navigation bar
- Ad-Hoc peer-to-peer network connection - Use MoKee's built-in kernel, otherwise the function is not available.
- Built in timer in Apollo - determine when to stop playing music
- CRT animation switch
- Custom operator name
- Network speed in status bar
- Preview option in launcher (similar to the preview function in launchers found in Play Store)
- Permissions Manager
- MoKee NotePad
- ListView animations
- global time refinement
- localization optimization and adjustment
- smart dialing optimization
- Volume Rocker Wake
- Split QS actionable area
- many more
::::::::: Downloads :::::::::
2nd BUILD LINK
::::::::: Screenshots and Installation Instructions :::::::::
::::::::: General Changelogs and Bug ::::::::::
FIRST BUILD
SAME BUG AS CM11
::::::::: Credits and Thanks :::::::::
- MoKee Developers for Opensource
- PA developers for Halo and Pie Control
XDA - For wonderful Forums
@Diego910 for test rom
@munjeni
maclawstudio
SOURCES
http://github.com/xperianovathor
Quelle: http://forum.xda-developers.com/showthread.php?t=2569955
