[ROM][4.4.2][CM-AOKP][dt2w] CarbonRom UNOFFICIAL
Topy28
Topy28
Stammgast
178
ROM 4.4.2 CM-AOKP CarbonRom UNOFFICIAL from blueether
CarbonRom ist eine aftermarket firmware basiert auf Android Open Source Project.
Die Carbon Rom, die für mehre verschiedene Geräte entwickelt wird, zeichnet sich einerseits durch hohe Stabilität, andererseits durch vielfältige Einstellungsmöglichkeiten mit vielen zusätzlichen Features aus (im Vergleich zu Stock Android Roms). Hierbei wird darauf geachtet, dass regelmäßig Updates erscheinen, die stets die aktuellste Hardware unterstützen.
[quote ]
Original Text:
We are dedicated to fast, stable, and feature-filled roms, honesty and communication with our users, and openness with our code. We like frequent builds, with the very latest and greatest hardware support and fixes. We strive to not only provide you with the best rom we can build, but also to give back to the Android community and our fellow developers. For us, this is about creating something we can be proud of and hope you will enjoy.
We would like to thank CyanogenMod for their device trees, framework/settings mods and their code that was incorporated into this project. We also extend our gratitude to the devs whose code that we have incorporated. Proper authorship has been maintained and can be viewed on our repository.
Special thanks also go to Slim Rom for some of their features, AOKP, and anyone else we may have borrowed commits from that hasn't been mentioned here. If you feel you have been unfairly left out, please - let us know.
While we make every effort to test these builds as much as possible, we are not responsible for anything that may happen to your device, family, pets, or perception of reality. We ask that you do your part to know your device and know how to recover from problems before you flash! If you have questions, ask your fellow users or ask us in #teamcarbon on freenode IRC.[/quote]
Originale xda tread :
[ROM][4.4.2][Unofficial] Carbon KitKat - Togari[2014-03-29] - xda-developers
Installieren:
1) Unlocked Bootloader
2) boot.img flashen
3) im recovery full wipe
4) zip und gapps flashen
DOWNLOAD :
Build 5 [2014-03-29]:
Togari - Direct XDA Download (DT2W)
Build 2 [2014-03-18]:
Build 1 [2014-03-06]:
Changelog:
Carbon Changelog - Basic
Carbon Changelog - Full
ein paar Screenshots
Contributors
blueether, [vertigo], CarbonTeam, CM
ROM OS Version:*4.4.x KitKat
ROM Kernel:*Linux 3.4.x
ROM Firmware Required:*Togari with Unlocked Bootloader
Based On:*Carbon & CM
Reaktionen: Xi-bit
Top Rom, testen Leute
Super bin mal gespannt
Der ursprüngliche Beitrag von 12:29 Uhr wurde um 12:48 Uhr ergänzt:
wäre evtl auch cool ne liste was die Dinger alles machen :)
Ähm ja wenn ich mal Zeit habe mache ich im xpose tread so eine liste
Wäre super, dann kann ich raus suchen was am nützlichsten ist, welche findest du wichtig von der Liste?
Habe kein Empfang ab der rom Installation
Was war vorher für eine Sony-Firmware drauf?
Reaktionen: Topy28
Gibt's schon Neues update?
oje glaub 14.1.B.1.532 bekomme nur roms mit 4.3 drauf bei 4.4 habe ich kein netz
Geh mal auf die 136 mit Root und Flash dann eine 4.4.x
Neues update raus :):)
Wie gefällt euch die Rom?
Mir sehr gut ist die Rom die mit Abstand am längsten auf meinen ZU ist und auch noch bleiben wird
Start post aktualisiert
Habe die auch gerade installiert, läuft schön smooth :)
Version 3 online
Dt2w läuft wohl noch nicht rund ,ich habe zwar noch keine Probleme gehabt { Devise reagiert nicht mehr} ,aber es gibt wohl Probleme . .
Download weiter verfügbar aber ,
Use at your on risk.
Von der p.a.c. Version von reper61616 (die Rom von den dev von dt2w )Lauf aber wohl rund http://forum.xda-developers.com/showthread.php?t=2692552
Nutzt du aktuell die carbon Rom? Lohnt es sich zu installieren? Die
colarus
canada
O
  • oecsike
TimeTurn
TimeTurn
TimeTurn
TimeTurn
