[ROM][6.0.1_r13] Resurrection Remix Marshmallow - Togari [28/2/2016]
Baerchie
Gast
About Resurrection Remix ROM
Resurrection Remix the ROM has been based on CM,slim.omni and original Remix ROM builds, this creates an awesome combination of performance, customization, power and the most new features, brought directly to your Device
Many things that in previous versions were tweaked with mods, are now included by default in the ROM so, please enjoy!
Resurrection Remix
Special thanks to, the CM team,OMNI team ,SLIMROMS and of course to all the supporters
Included Main Features
Based On Latest Google Android 6.0.1 Release
Based On Cyanogenmod 13 Sources
RR Customizations:-
-Navigation Bar
-Enable/Disable Navbar
-Navbar Button Customization
-Navbar Slim Dim
-Animate Dim
-Dim Timeout Duration
-Dim Alpha
-Double Tap To sleep navbar
-Navigation Bar left/Right handed mode Switch for landscape
-Statusbar
-Brightness Slider
-Enable/Disable Show Notification Count
-SuperUser Indicator Switch
-Double Tap To sleep Statusbar
-Carrier Label
-Carrier Label Switch
-Carrier label Colour
-Carrier Label Size
-Clock Customizations
-Time & date
-Clock Colour
-Day & date Toogle
-Center/Right/Left Clock Choice
-Date Format
-Clock Font Styles
-Battery
-Battery Bar customization
-Battery Icon Customization(circle/landscape/Potrait and more)
-Battery % Text
-Network Traffic Indicator
-Network Traffic Arrows Switch
-Incoming/OutGoing Traffic
-Network traffic Color
-Statusbar RR Logo
-RR logo Color
-StatusBar Weather
-Weather Color
-Weather Position(left/right)
-Weather Style
-Weather Size
-Animations
-Toast Animations
-ListView Animations
-System Animations
-Gestures
-Gestures Anywhere Feature
-3 Finger Swipe Screenshot Gesture
-App Circle Bar
-Choose apps in AppSidebar
-Trigger Width
-Trigger Hieght
-Trigger Position
-App Sidebar
-Choose apps in App circle
-Trigger Width
-Trigger Hieght
-Trigger Position
-Pie
-Pie Trigger(left ,Right ,Bottom)
-Pie Targets
-Pie Colors
-More Pie Features
-Recents Panel
-Clear All button Switch
-Clear All Tasks Switch
-Clear All Button Location(Top right,Top Left,Top Center,Bottom Left,Bottom Right,Bottom Center)
-Recents Search Bar
-Full Screen Recents
-Slim Recents
-OmniSwitch
-Cclock Widget
-CLock And Alarm Customizations
-Weather Panel Customizations
-Calender Events
-LockScreen
-Lockscreen Bottom Shortcuts
-Lockscreen General Shorcuts
-100+ Icons for Shortcuts
-Double Tap to Sleep Lockscreen
-Lockscreen Media Art/Enable Disable
-Quick PIN/Patter Unlock
-LockScreen Blur
-Lockscreen Blur Intensity
-LockScreen Wallpaper
-Lockscreen Weather Widget
-Lockscreen Icons Color
-Quick Settings Draggable Tiles
-Customizable Tiles
-Show Two Main Tiles Per Row
-Dyanamic Tiles Adjustment
-Notification Drawer
-Weather Display Switch
-LongPress Toogles to Enter Settings
-Disable Immersive Mode Messages
-Force Expand Notification
-Task Manager Switch
-Time Contextual Header(HD,Modern,Poly)
-Quick PullDown Switch
-Buttons
-Backlight Timer
-Backlight Strength
-Advanced Reboot Menu
-Power Menu Customizations
-Power Off
-Reboot(Recovery, Bootloader, Hot Reboot)
-ScreenShot
-Power Menu End Calls Switch
-Restart SystemUI
-Airplane Mode
-ScreenRecord
-On the Go Mode
-Sound Panel
-Volume Buttons
-Wake Up Device
-Playback Control
-Ringtone Volume Control
-Keyboard Cursor Control
-Swap Buttons on Landscape mode
-Volume Key Answer
-Miscellaneous
-Selinux Switch (Switch Between Permissive and Enforcing Selinux if Device has Selinux Enabled)
-cLock Shortcut
-Disable Battery Saver Warning Color
-Disable Fc Notifications
-Wakelock Blocker
-Media Scanner On Boot Behaviour
-Cammera Shutter Sound Enable/Disable
-SystemUI Tuner
-Enabled By default
-Removed Demo mode and Tweaked SystemUI Tuner As compared To AOSP
-StatusBar Icons Cuzomizations
-Quick Settings Customizations
Other Features
-Perfomance Profiles
-LCD Density
-Expanded Desktop Mode
-Audio FX
-Heads Up Switch
-Live Display
-Configurable 0,90,180,270 Degree Rotation
-Lock Screen Autorotate Switch
-Native Tap to Wake From Marshmallow
-Double Tap Power Button To enable Camera gesture
-Prevent Accidental Wakeup
-Wake Phone on Charging Plug
-Battery Light Customizations
-Notification Light Customizations
-Font Size
-CM privacy guard
-Performance Tweaks(Kernel Aduitor Inbuilt)
-SuperSU Inbuilt
-RR OTA
-CM Theme Chooser
-OverAll Smoothness Improvements
-Optimizations to Improve Battery
-Includes All Android Marhsmallow Features
-Includes ALL CM13 Features
-AND MUCH MUCH MORE
-INSTALLATION INSTRUCTIONS-
- Download the latest build
- Download Gapps
- Take a nandroid backup
- Recommended - Full wipe and factory reset
- Flash ROM using latest TWRP 2.8.6.x Recovery
- Flash Gapps
- Reboot.
- Enjoy!
-UPDATE INSTRUCTIONS-
- Download the latest build of Resurrection Remix ROM
- Flash ROM using recovery
- Flash Gapps
- Wipe cache
- Wipe dalvik cache
- Reboot
- Enjoy!
Rom: https://www.androidfilehost.com/?w=files&flid=46085
Gapps: http://forum.xda-developers.com/slimroms/general/gapps-official-slim-gapps-trds-slimkat-t2792842
Big thanks to:
XDA developers
CM team
Omni team
Slim rom
AND OF COURSE TO ALL THE SUPPORTERS, DONATORS AND USERS
XDA:DevDB Information
Resurrection Remix Marshmallow - Togari, ROM for the Sony Xperia Z Ultra
Contributors
OmarEinea
Source Code: ResurrectionRemix · GitHub
ROM OS Version: 6.0.x Marshmallow
ROM Kernel: Linux 3.10.x
ROM Firmware Required: Unlocked Bootloader
Based On: CyanogenMod
Version Information
Status:
Testing
Created 2016-02-28
Last Updated 2016-02-28
Also Ich habe die Neue Version drauf geflasht und Ich muss sagen bei Mir Funktioniert alles einwandfrei.
Auch die Kamera und SD-Kartenzugriff?
Jip bei Mir Funktioniert die SD Card und ab und zu Spint die Kamera aber das kommt nicht so oft vor :D
Moin,
bekomme die gapps nicht aufs Handy. Die installation übers recovery läuft normal durch, nach neustart sind die gapps aber nicht vorhanden.
Ich hatte die rom auch mal drauf, zuerst hatte ich twrp 3 via Flashtool installiert, damit anschließend einen fullwipe gemacht, dann dieses ROM mit open gapps pico installiert.
War sehr cool, man konnte wirklich viel einstellen, allerdings hatte es für mich zu viele Force closes.
So dass das Wurstbrett ständig rebootet hatte, da bin ich dann schnell auf aicp official gewechselt.
Das läuft um einiges stabiler
ich bin noch mit keiner MM rom so wirklich glücklich. kamera geht nicht, sd card probleme und die ständigen reboots, auch bei aicp.
werde noch paar wochen die entwicklung beobachten und bleibe bis dahin auf hybrid-rom.
udo7777
Baerchie
TimeTurn
TimeTurn
V
der_henk
der_henk
