[ROM][AOSP][OFFICIAL][4.4.4] LiquidSmooth 3.2 [Sirius]
  • 46 Antworten
  • Neuester Beitrag
Diskutiere [ROM][AOSP][OFFICIAL][4.4.4] LiquidSmooth 3.2 [Sirius] im Custom-ROMs für Sony Xperia Z2 im Bereich Root / Custom-ROMs / Modding für Sony Xperia Z2.
wwallace1979
wwallace1979
Experte
Und schon wieder gibt es ein neues Rom für unser Sirius:thumbup:
Den original Beitrag findet ihr auf XDA
[ROM][AOSP][UNOFFICIAL][4.4.4] LiquidSmooth … | Xperia Z2 | XDA Forum
LiquidSmooth is an aftermarket firmware based on AOSP and SlimROM.
Dedicated to providing users with smooth, stable and fast ROMs. A Lightweight modified AOSP and SlimROM base, and then add the features you crave! While we make every effort to test these builds as much as possible, we are not responsible for anything that may happen to your device. We ask that you do your part to know your device and know how to recover from problems before you flash!
Kurz gesagt es basiert auf AOSP und SlimRom und ist daher auf das notwendigste begrenzt und dementsprechend schnell.
Code:
Features below are from SlimROM which are included in LiquidSmooth SlimPIE Quiet Hours Slim Recents Lock screen Style Notification Reminder Hardware key rebinding Custom Carrier label Smart Pulldown ADB over network Glowpad Torch Advanced Reboot Listview Animations Liquid Dungeon National Roaming Custom Tiles flip to Mute/Reject Call Incoming call in background Hide USB debugging notification Stylus Support Stylus Gestures Notification Drawer Style Lock screen pin shuffler Quick Unlock Status bar Brightness control Volume rocker wake Safe headset volume Privacy Guard Status bar clock style Status bar date style More features with credit below...
Hier der aktuelle :
http://www.drdevs.com/devs/teamliquid/Nightly/Xperia_Z2/LS-KK-v3.2-2014-09-07-sirius.txt
Code:
SaberMod 4.8 GCC Toolchain for ROM SaberMod 4.7 GCC Toolchain for kernel O3 Strict-Aliasing & ISO C++11 Mode ARM Optimized String Handling Routines Linaro and Code Aurora Optimaztions HALO Credit: PA/cristinamatos/xjcook/beerbong New CM Theme Chooser/Engine OmniRom App Circle Sidebar Credit: SquadZone Allow Disabling of FC messages Credit: jmztaylor PEEK Credit: PA Allow notification vibration during calls Credit: maniac103 Gesture Unlock Credit: 0xD34D Lock screen Notifications Credit: AOSPAL Development Shortcut Credit: sarbyn Switch Recent panel styles Credit: cristianomatos Battery Bar Credit: cphelps76 Status bar notification count and signal style Credit: burnsra & rmcc (cm) Status bar clock font style Credit: daxxmax Network speed indicator Credit: htchoi1995 Time-context headers to the notification header Credit: Xplodwild Ram Bar Credit: cristianomatos Custom Clear recents button Credit: cristianomatos Camera Button Support Credit: CM On the Go mode Credit: Evisceration Custom Lock screen wallpaper and blur Credit: david96 Audio Theme support Credit: Xplodwild Battery around unlock ring Credit: Xplodwild Gesture Anywhere Credit: 0xD34D Active Display Credit: 0xD34D/AOSPAL Alternate default app picker Based on @kufikugel 4.3 idea Toast Animations Credit: XuiMod Custom Progress Bar Credit: GwonHyeok Custom Scrolling values Credit: Squadzone Wake Lock Blocker Credit: Squadzone Multi user support for phones Credit: AlmightMegadeth00 IME Animations Credit: Squadzone Custom System Animations Credit: Steve Spear Battery Saver Mode Credit: OmniRom/timpohladthomas
Code:
Download Link
PA GAPPS
Liquid Gapps gibt es hier:
index · powered by h5ai 0.26.0 ()
Installations Anleitung:
Seit sicher das ihr einen geöffneten Bootloader habt
1- schaltes das Gerät aus(Power off):
2- halte vol+ und stecke die usb Stecker an den PC um im fastboot Modus zu booten (blaue led)
3- flashe das boot.img aus der liquid zip
4- reboote
5- geht zurück in das recovery
6-Wipe /System , und Factory Rest durchführen
7- flashe die rom
8- flashe die gapps
9- reboote
10-und genießen
- Bei einen Update:
Wipe Cache / Dalvik Cache und Format System
- ROM installieren (select ZIP from SD)
- Gapps installieren (select ZIP from SD)
- Neu starten
Bugs:
Lockscreen - buttons actions doesn't work Lockscreen - shake to secure doesn't activate
Sirius specific bugs:
none so far if you find anything use dev-db bug report
wwallace1979
wwallace1979
Experte
Lt XDA hat sich etwas getan:
You guys now have official support for LiquidSmooth your maintainer will be David Makarove
Download Link
Changelog
Desweiteren funktioniert jetzt auch das Update per OTA
09-02-2014 ==================== * external/koush/Superuser/ 35fee20 SU: Use different strings for notification summary & popup list ==================== 09-01-2014 ==================== * external/koush/Superuser/ b5efcf2 Automatic translation import * packages/apps/Bluetooth/ 0c254c3 Automatic translation import * packages/apps/InCallUI/ cc52f67 cleanup from cherry-pick 36a0330 InCallUI: Fix landscape layout 61eb7a7 InCallUI: Landscape support (for in-dock use / qwerty sliders) * packages/apps/LiquidUpdater/ 45e9eca Set default update type to: All versions(incl.Nightlies) * packages/apps/LockClock/ 8239598 Automatic translation import * packages/apps/Settings/ 00c3c4a Properly remove HighTouchSensitivity preference * packages/apps/SoundRecorder/ 86ad192 Fix the previous fix 5aa6ccc Automatic translation import * packages/apps/ThemeChooser/ 44feb97 Automatic translation import ==================== 08-31-2014 ==================== * frameworks/base/ 0658a58 Change Thumbnail Size * packages/apps/Settings/ c52f4dd SRE: Add Adaptive backlight as dependency 969931c Display: Default SRE to off 4b21214 PIE color settings * vendor/liquid/ 043212c Xposed backup script ==================== 08-30-2014 ==================== * frameworks/av/ b548a6e ENGR00294739 coreimage, screenrecord sometimes fail when shift different video 3d09abf stagefright: Fix 24-bit WAV * frameworks/base/ 8a0cb00 PIE from ParanoidAndroid [1/2] * hardware/qcom/audio-caf/ 46242bd hal: Fix no Tx issue during multi party HFP calls ac48e50 hal: miscellaneous fixes df022cf post_proc: Fix bassboost/virtualizer not disabled on speaker db59680 hal: speaker protection is msm8974 only de66b3d hal: allow msm8610 to use same functions as msm8226/msm8974 * hardware/qcom/display-caf-new/ 3bc0feb hwc: Configure MDP with updated content attributes of PTOR layers * kernel/sony/msm8974/ b75f17e misc: Clean up warnings about uninitialized variables * packages/apps/InCallUI/ f4be101 InCallUI: Call Recording [1/2] * packages/apps/Settings/ f53bb80 Remove Quick Unlock and Menu Unlock 218dff8 Make Pa pie string match * system/core/ 320d26e healthd: increase healthd fast timer to 10mins instead of 1min ==================== 08-29-2014 ==================== * device/sony/rhine-common/ 415fc96 Fix typo, actually set Voice Call properties 5e1fc3f rhine: Disable audio offload 8803488 rhine: Add Qualcomm audio effects 0bd79f4 rhine: Add msm8974 policy HAL, audiod 6c974f4 Add stepcounter and stepdetector permission xml
Der ursprüngliche Beitrag von 09:04 Uhr wurde um 09:48 Uhr ergänzt:
Wie Ihr merkt habe ich micht jetzt auch an dieses Rom ran getastet.
Ich muss sagen man merkt hier deutlich das es sehr proffesionell gemacht ist und alles so scheint als sei es aus einem Guß. Das Z2 fühlt sich sehr geschmeidig an und kaum eine Funktion die man bisher von diesem Rom kannte fehlt.
Schön ist auch die Funktion "Dunkles Design" die das System und einiige Apps schwarz erscheinen lassen.Für mich neu ist es bei den Tönen die "Ruhigen Stunden" jetzt auch für jeden Wochentag einzeln einstellen zu können.
Ich denke für diejenigen die bisher viel Wert auf den "Stamina Modus" gelegt haben ist jetzt auch das passende dabei und zwar findet sich unter Einstellungen->Erweiterte Einstellungen->Battery Saver-> jede Menge Optionen und Möglichkeiten.
Desweiteren hat die Rom auch einen eingebauten Werbeblocker der sich an oder ausschalten läßt, so dass ihr nicht mehr auf AdFree oder Adaway angewiesen sein.
System apps die ihr nicht benötigt lassen sich auch einfach über den "System App Remover" entfernen.
Aber am besten Ihr schaut euch das selber mal an :smile:
SpezialM
SpezialM
sehr geile rom nur wird bei mir die speicherkarte nicht erkannt was kann ich machen?Hab sie schon formartiert exfat bringt aber auch nichts, hat jemand ne Idee??
Wolf65
Wolf65
Stammgast
Ja finde ich auch sehr gut die Rom. Bei mir wird die Speicherkarte erkannt kein Probleme.
SpezialM
SpezialM
wie hast du sie installiert??
Wolf65
Wolf65
Stammgast
Die Rom ganz normal über recovery dann den Kernel M5 fertig und alles läuft super.
SpezialM
SpezialM
welchen kernel m5?die img datei in der rom meinst du??
SpezialM
SpezialM
geile aktion von dir!!!wie findet ihr das alles immer;-))??
Wolf65
Wolf65
Stammgast
Wer suchet der findet
SpezialM
SpezialM
ja und hast du den davor installiert oder nach der rom??bin auf existenz ultimate
Wolf65
Wolf65
Stammgast
War ich vorher auch erst die Rom dann die gaaps denn einmal booten dann ins recovery und Kernel fertig ist die Laube. Habe mir dann eine cam app von playstore geholt weil die Standard ist nicht so gut.
SpezialM
SpezialM
und welche cam kannst du empfehlen????
Wolf65
Wolf65
Stammgast
Ich habe mir die HD Cam aus den playstore geholt ist gut und schlicht. Kann zwar keine Videos drehen aber so oft mache ich es nicht.
Der ursprüngliche Beitrag von 17:30 Uhr wurde um 17:32 Uhr ergänzt:
Die faux clock app läuft auch mit den Kernel M5 wenn du die haben solltes.
SpezialM
SpezialM
hab alles so gemacht wie du leider erkennt das handy die speicherkarte nur im recovery,bin am ende mit meinem latein!!!
Wolf65
Wolf65
Stammgast
Ich denke das liegt an der Karte vielleicht mal rein und raus nehmen. Oder Google mal vielleicht findest du was darüber.
SpezialM
SpezialM
keine chance alles schon durch!bei mir wird die exfat4 nicht unterstützt wieso auch immer
Wolf65
Wolf65
Stammgast
Ja ist ja gedigen. Vielleicht meldet sich ja noch einer zu Wort.
SpezialM
SpezialM
habs hinbekommen hab sie öfters rein raus getan komischerweise gings dann!!
