chris12205
Stammgast
- 264
CHANGELOG
Lock screen, status bar, notification bar.
New notification bar support to display the VPN icon (only supported on non-notch screen models)
Fix - drop-down notification after bar, the battery icon text is not displayed correctly
Calculator
Fix - Calculator converter module floating widget can not be dragged
Camera
New - Super Night mode function (Mi 8 standard / EE version / Mi 8 Pro / Mi MIX 2S)
Settings
Fix - Personal hotspot, when password is modified and click save, hotspot will automatically shut down
File Manager
Fix - Sporadic category page search function causes crash
Fix - Search interface icons display is truncated/cut off
Sound Recorder
Fix - After a pausing recording, notification is not displayed in status bar
HM5A and HM5Plus updated to Android 8.1
DELAYED DEVICES:
MI8LITE, MI8SE, POCOF1, HMNote3SE, MIMIX, MINote2, MI5S, MI5Splus, MI5X, MI5, HM6Pro
Und der "Nacht" Mode vom MiMix 3 ist fürs MiMix 2s dabei.
Werde heute abend/morgen früh ein paar Fotos hier posten.
Calculator
Camera
Settings
File Manager
Sound Recorder
DELAYED DEVICES:
