[ROM][G900F][6.0.1] *20.08.2016* BrokenOS v.4.9.1 [UNOFFICIAL]
Blackjubel
Blackjubel
Dauergast
1.134
This ROM was created out of fun and the love of Android. It was meant to be a battery friendly, high performing AOSP/Slim based ROM. There are plenty of features to keep those who want more out of a custom Android experience but not compromising on speed, stability and that battery sipping quality this ROM has.
We have a short list of official devices (the ones we own). We will not do blind builds so don't ask! Check the "ALL USERS READ THIS" link for more info. Absolutely ZERO unofficial builds outside of this community without our consent.
This ain't XDA so we sure as hell aren't going to censor or coddle you. If you fling shit, expect it flung right back.
That said, enjoy the ROM and your stay.
Now let's break shit!
BrokenOs Landfill – Community – Google+
Dysfunctional ROMs
ROM Features :
- Layers
- Slim based
- Dark Dialer
- Dark Contacts
- Visuals Menu - Quick Settings & Status Bar options
- Tweaks Menu - Ad Blocker, init.d and baked-in Kernel Tweaker
- Sound & Notifications - Vibration Tunables, Heads Up notification control
- Battery - Battery Saver, option to change status/nav bar default color in Battery Saver mode
...and more coming
Installationsanleitung :
Ladet euch die aktuelle Rom und die Gapps herunter und kopiert diese auf eure SD-Card
dann
1. Ins vorhandene Recovery booten
2. Backup anlegen und Full Wipe und Factory Reset ausführen !
3. Rom flashen
4. Gapps flashen
5. Neustart
6. alles einrichten
7. Fertig
Updateanleitung :
- Download der aktuellsten BrokenOS ROM und kopiert diese auf eure SD-Karte
- Reboot ins Recovery (z.B. TWRP)
- Erstellt ein nandroid backup
- Flasht die ROM
- Flasht die Gapps
- Wipe cache
- Wipe dalvik cache
- Reboot
- Fertig
Gapps 6.0.x ( Gapps nach wahl , die am besten passen für sie)
Open Gapps : The Open GApps Project
CyanogenMod 13 Android 6.0 Google Apps
Banks gapps
Slim Gapps
Reaktionen: DarkSouls21 und j1gga84
Ist die stabiler als deine RR version?
Ansichtssache einer sag ja einer nein am besten selbst mal testen :winki:
Moin blackjubel gibt es ne Möglichkeit die Vibrationsstärke einzustellen? Finde leider keine. Ansonsten läuft alles perfekt bis jetzt auch noch keine laggs nach dem einschalten wie die RR von dir oder jede andete cm13 rom
Hab mir die Broken noch nicht auf git geholt und deswegen noch keine Änderungen vorgenommen .
Ist ja auch keine CM Rom is ne layer .
Danke hab es mal edit link zu 4.4 und extra link zu 4.5
Hat schon wer Erfahrungen mit der BrokenOS ? Irgendwelche Bugs?
New Build
04-12-2016
* bionic/
46d9156 Fix GNU/POSIX basename headers.
3752924 Don't leak sockets if setsockopt() or fchown() fail.
fdb40a4 Add prlimit to LP32.
3316115 Merge tag 'android-6.0.1_r24' into m6.0.1
* build/
15d5a7a Revert "Add some color to the dumpvar" for now till i can see why its breaking some people This reverts commit 55f55035d6f0879711c1c44b4afc234c21019db5.
55f5503 Add some color to the dumpvar
* device/samsung/klte-common/
022ab48 klte-common: remove unused location folders
* frameworks/base/
cac2a95 Change trigger region color so its veiwable in white (day) ui
5a755f7 Appcircle Sidebar code cleanup
a30dae0 App Circle Sidebar: Support for Configurable Trigger Region [1/2]
f94db1b AppCircleSideBar [1/2]
* hardware/qcom/gps/
bd36ae2 Merge tag 'android-6.0.1_r24' into m6.0.1
* kernel/samsung/msm8930-common/
7bbb290 wlan: Send directed Probe Request frames only for hidden SSIDs.
ea92f4f net: tcp: fix rtable leak in tcp_is_local[6]
bc0261c net: diag: support v4mapped sockets in inet_diag_find_one_icsk()
7218693 net: tcp: deal with listen sockets properly in tcp_abort.
eb973e2 net: diag: Support destroying TCP sockets.
759a407 net: ipv6: tcp: fix potential use after free in tcp_v6_do_rcv
acd9d25 ipv6: do not clear pinet6 field
27f518e inet: Fix kmemleak in tcp_v4/6_syn_recv_sock and dccp_v4/6_request_recv_sock
7f34f8b net: diag: Support SOCK_DESTROY for inet sockets.
76b4295 net: diag: Add the ability to destroy a socket.
c4e3fa0 net: diag: split inet_diag_dump_one_icsk into two
b425e39 ipv6: clean up anycast when an interface is destroyed
1c9a500 New Build Breakage in branch: kernel-m-dev-tegra-flounder-3.10 @ 1960706
45c606a net/unix: sk_socket can disappear when state is unlocked
42c21b3 nf: IDLETIMER: Adds the uid field in the msg
dbeca05 ANDROID: dm-crypt: run in a WQ_HIGHPRI workqueue
dac09d6 ANDROID: mmc: move to a SCHED_FIFO thread
e75a55b drivers: input: touchscreen: Disable DEBUG_TSP
* packages/apps/Settings/
ea286eb Add a Seekbar and fix some thing Conflicts: res/layout/seek_bar_preference.xml res/values/custom_attrs.xml
02072d6 App Circle Sidebar: Support for Configurable Trigger Region [2/2]
c334054 AppCircleSideBar [2/2]
* vendor/broken/
680ac8e Fuck with some colors in the build script
* vendor/samsung/
c4104ea Merge pull request #756 from RGIB/cm-13.0
04-11-2016
* bionic/
2f447d5 linker: Allow text-relocs for x86 (only)
* frameworks/av/
7bb2c2a nuplayer: Allow devices to force a flush when surface changes
* frameworks/base/
3529c50 intel: Pick the best ABI based on number of libs, not just priority
* vendor/broken/
3b0c9b6 add draconis
* vendor/samsung/
73b5e87 Merge pull request #757 from raymanfx/cm-13.0
04-10-2016
36f7c57 remove duplicate cell settings
04-09-2016
* hardware/qcom/audio-caf/msm8974/
844647b hal: Add support for AUDIO_DEVICE_OUT_LINE
314a683 Fix after the shuffle
5c47426 Settings: Fix NFC Tap & pay removal
17f9ae3 Settings: Move NFC payment under NFC category
ee583b2 Properly remove NFC payment preference
ccab295 Settings: update layouts
* vendor/broken/
dcb4e52 Fix import of apns for lte tablets
20b6627 Broken: Cleanup and organize telephony make files
c2b4722 Make the official zips relocate to OFFICIALS folder for daisy chaining builds
* vendor/lge/
3ac60fd Merge pull request #179 from Raienryu97/cm-13.0
* vendor/samsung/
074d149 Merge pull request #754 from haggertk/cm-13.0
65a6a21 kltevzw: Remove unnecessary libs
d01fee4 n5120 : blobs update from 4.4.2
04-08-2016
* kernel/samsung/klte/
ffec6f8 f2fs: fix to avoid deadlock when merging inline data
819ea66 f2fs: introduce f2fs_flush_merged_bios for cleanup
c54dcb1 f2fs: introduce f2fs_update_data_blkaddr for cleanup
63114bb f2fs crypto: fix incorrect positioning for GCing encrypted data page
8ebd51b f2fs: fix incorrect upper bound when iterating inode mapping tree
e9c61ba f2fs: avoid hungtask problem caused by losing wake_up
fa821a6 f2fs: trace old block address for CoWed page
56cd2b9 f2fs: try to flush inode after merging inline data
94b61f5 f2fs: show more info about superblock recovery
eb296c4 f2fs: fix the wrong stat count of calling gc
f15cb2c f2fs: remain last victim segment number ascending order
6a20f5e f2fs: reuse read_inline_data for f2fs_convert_inline_page
e54fe95 f2fs: fix to delete old dirent in converted inline directory in ->rename
ab4c13c f2fs: detect error of update_dent_inode in ->rename
6b51993 f2fs: move sanity checking of cp into get_valid_checkpoint
03cfaa4 f2fs: slightly reorganize read_raw_super_block
3d0e340 f2fs: reorder nat cache lock in cache_nat_entry
452da20 f2fs: split journal cache from curseg cache
ade5336 f2fs: enhance IO path with block plug
b5538b0 f2fs: introduce f2fs_journal struct to wrap journal info
78e75ed f2fs crypto: avoid unneeded memory allocation when {en/de}crypting symlink
5d5266e f2fs crypto: handle unexpected lack of encryption keys
03ef3cd f2fs crypto: make sure the encryption info is initialized on opendir(2)
19443af f2fs: support revoking atomic written pages
817cb1c f2fs: split drop_inmem_pages from commit_inmem_pages
f97c539 f2fs: avoid garbage lenghs in dentries
33161f9 f2fs: use correct errno
66a9555 f2fs crypto: add missing locking for keyring_key access
c83e261 f2fs crypto: check for too-short encrypted file names
0c930eb f2fs crypto: f2fs_page_crypto() doesn't need a encryption context
f09d838 f2fs crypto: fix spelling typo in comment
40e7cc7 f2fs crypto: replace some BUG_ON()'s with error checks
c288cb9 f2fs: increase i_size to avoid missing data
5a57f3c f2fs: preallocate blocks for buffered aio writes
910e08a f2fs: move dio preallocation into f2fs_file_write_iter
faa482b f2fs: fix missing skip pages info
31d678b f2fs: introduce f2fs_submit_merged_bio_cond
490db95 f2fs: fix conflict on page->private usage
2146640 f2fs: flush bios to handle cp_error in put_super
e49d61d f2fs: wait on page's writeback in writepages path
5b29295 f2fs: fix endianness of on-disk summary_footer
e3ef40c f2fs: speed up handling holes in fiemap
4256d20 f2fs: introduce get_next_page_offset to speed up SEEK_DATA
c502240 f2fs: remove unneeded pointer conversion
56c172b f2fs: simplify __allocate_data_blocks
6f6a292 f2fs: simplify f2fs_map_blocks
41a5046 f2fs: introduce lifetime write IO statistics
6a5637a f2fs: give scheduling point in shrinking path
9be419b f2fs: improve shrink performance of extent nodes
1e53cce f2fs: don't set cached_en if it will be freed
3471681 f2fs: move extent_node list operations being coupled with rbtree operation
43bb324 f2fs: reconstruct the code to free an extent_node
8c694b0 f2fs: use wq_has_sleeper for cp_wait wait_queue
b484fe8 f2fs: avoid unnecessary search while finding victim in gc
78e721f f2fs: delete unnecessary wait for page writeback
008c85b f2fs: use wait_for_stable_page to avoid contention
a78bda9 f2fs: enhance foreground GC
cd227b2 f2fs: don't need to call set_page_dirty for io error
ece6b9c f2fs: avoid needless sync_inode_page when reading inline_data
d8918ef f2fs: don't need to sync node page at every time
4f2e93c f2fs: avoid multiple node page writes due to inline_data
8c782c1 f2fs: do f2fs_balance_fs when block is allocated
abf1c45 f2fs: fix to overcome inline_data floods
96aa475 f2fs: use writepages->lock for WB_SYNC_ALL
a4c18e8 f2fs: remove needless condition check
2cbe022 f2fs: correct search area in get_new_segment
a02874b f2fs: export dirty_nats_ratio in sysfs
7748e05 f2fs: flush dirty nat entries when exceeding threshold
f19e261 f2fs: relocate is_merged_page
fcc24b5 f2fs: should unset atomic flag after successful commit
b47d68c f2fs: fix wrong memory condition check
e29bcc5 f2fs: monitor the number of background checkpoint
0f5e78f f2fs: detect idle time depending on user behavior
1e28c91 f2fs: introduce time and interval facility
cdff8e0 f2fs: skip releasing nodes in chindless extent tree
4e1380d f2fs: use atomic type for node count in extent tree
83681c2 f2fs: recognize encrypted data in f2fs_fiemap
27e5e39 f2fs: clean up f2fs_balance_fs
10813bf f2fs: remove redundant calls
3793398 f2fs: avoid unnecessary f2fs_balance_fs calls
9bebb23 f2fs: check the page status filled from disk
75e483c f2fs: introduce __get_node_page to reuse common code
1bd7df7 f2fs: check node id earily when readaheading node page
ea76248 f2fs: read isize while holding i_mutex in fiemap
8e5205a Revert "f2fs: check the node block address of newly allocated nid"
7eae1d1 f2fs: cover more area with nat_tree_lock
424de31 f2fs: introduce max_file_blocks in sbi
d9fa2a5 f2fs crypto: check CONFIG_F2FS_FS_XATTR for encrypted symlink
280fa39 f2fs: introduce zombie list for fast shrinking extent trees
4137302 f2fs: monitor zombie_tree count
008c361 f2fs: use IPU for fdatasync
6f70ad1 f2fs: write pending bios when cp_error is set
66c2455 f2fs: remove f2fs_bug_on in terms of max_depth
4919d73 f2fs: fix f2fs_ioc_abort_volatile_write
eb90177 f2fs: fix to skip recovering dot dentries in a readonly fs
276ae56 f2fs: load largest extent all the time
0a8f9c9 f2fs: use i_size_read to get i_size
d03d6f7 f2fs: early check broken symlink length in the encrypted case
5a22f95 f2fs: clean up f2fs_ioc_write_checkpoint
f985827 f2fs: add a max block check for get_data_block_bmap
3e2a0e8 f2fs: fix bugs and simplify codes of f2fs_fiemap
77f27bc f2fs: let user being aware of IO error
8adf25b f2fs: add missing f2fs_balance_fs in __recover_dot_dentries
3c2cf08 f2fs: declare static function
162b4e3 f2fs: avoid f2fs_lock_op in f2fs_write_begin
68e4a4f f2fs: return early when trying to read null nid
1e4aaa8 f2fs: introduce prepare_write_begin to clean up
5292682 f2fs: don't convert inline inode when inline_data option is disable
fcd63a1 f2fs: report error of do_checkpoint
621ff88 f2fs: call f2fs_balance_fs only when node was changed
c0062ab f2fs: reduce covered region of sbi->cp_rwsem in f2fs_map_blocks
379183d f2fs: record node block allocation in dnode_of_data
a2d6262 f2fs: avoid unnecessary f2fs_gc for dir operations
4fbbb49 f2fs: check inline_data flag at converting time
e84e9b8 f2fs: speed up shrinking extent tree entries
570e11b f2fs: use atomic variable for total_extent_tree
6b7b2d9 f2fs: add a tracepoint for sync_dirty_inodes
40e0a69 f2fs: optimize the flow of f2fs_map_blocks
ff8263d f2fs: support data flush in background
3b51070 f2fs: stat dirty regular/symlink inodes
a59fd5c f2fs: introduce new option for controlling data flush
e17a10a f2fs: record dirty status of regular/symlink inode
9b0ecc6 f2fs: introduce __f2fs_commit_super
d479bc6 f2fs: relocate tracepoint of write_checkpoint
8eb640a f2fs: don't grab super block buffer header all the time
a6b3a72 f2fs: backup raw_super in sbi
f3b1a72 f2fs: fix to reset variable correctlly
e32a00b f2fs: introduce __remove_dirty_inode
7bb1237 f2fs: introduce dirty list node in inode info
c5705f1 f2fs: rename {add,remove,release}_dirty_inode to {add,remove,release}_ino_entry
d949a51 f2fs: add symbol to avoid any confusion with tools
97d62b7 f2fs: do more integrity verification for superblock
607500b f2fs: fix to update variable correctly when skip a unmapped block
5c0cd39 f2fs: write only the pages in range during defragment
e4da2e6 f2fs: clean up node page updating flow
e0dd4c8 f2fs: use lock_buffer when changing superblock
668739e f2fs: refactor f2fs_commit_super
f0a39da f2fs: enhance the bit operation for SSR
5105aae f2fs: fix to convert inline inode in ->setattr
bba33f9 f2fs: use sbi->blocks_per_seg to avoid unnecessary calculation
adca3f4 f2fs: kill f2fs_drop_largest_extent
02bbb43 f2fs: clean up argument of recover_data
a9579fa f2fs: clean up code with __has_cursum_space
7104490 f2fs: clean up error path in f2fs_readdir
11512b5 f2fs: do not recover from previous remained wrong dnodes
71d40ef f2fs: avoid deadlock in f2fs_shrink_extent_tree
7eaf71c f2fs: fix to report error in f2fs_readdir
ae710a1 f2fs: clear page uptodate when dropping cache for atomic write
1cb7acc f2fs: optimize __find_rev_next_bit
a74981b f2fs: fix to remove directory inode from dirty list
c5a2f1d f2fs: fix to enable missing ioctl interfaces in ->compat_ioctl
700ed36 f2fs: fix memory leak of kobject in error path of fill_super
d71b52c f2fs: support file defragment
6f25ca7 f2fs: commit atomic written page in LFS mode
88a7dcb f2fs: report error of f2fs_create_root_stats
a6d81a6 f2fs: Fix a system panic caused by f2fs_follow_link
0f6cd73 f2fs: catch up to v4.4-rc1 from googlesource
* platform_manifest/
b04967a Merge pull request #5 from Orion116/m6.0.1
a0e676f Kills hardware/samsung_slsi-cm at start of build for lt03wifi
* vendor/broken/
cf4c3dc Revert "Duggable build by default - adb logcat FTW"
e95d214 Change official echo statement and color
04-07-2016
* bootable/recovery/
eae4d91 Merge tag 'android-6.0.1_r24' into m6.0.1
* build/
9394558 Merge tag 'android-6.0.1_r24' into m6.0.1
* external/sepolicy/
a7956c5 sepolicy: allow logthatshit to work with SuperSU on Enforcing
* external/skia/
8312935 Merge tag 'android-6.0.1_r24' into m6.0.1
* frameworks/av/
810ebca Merge tag 'android-6.0.1_r24' into m6.0.1
* frameworks/base/
036bc07 Revert "Allow WiFi & Bluetooth tile details to scroll"
6db5294 Merge tag 'android-6.0.1_r24' into m6.0.1
* frameworks/native/
e71e357 Merge tag 'android-6.0.1_r24' into m6.0.1
* frameworks/opt/net/wifi/
1b1e77f Merge tag 'android-6.0.1_r24' into m6.0.1
2f51eea pipe: Fix buffer offset after partially failed read
086e642 UPSTREAM: include/linux/poison.h: fix LIST_POISON{1,2} offset
8abb315 pipe: iovec: Fix memory corruption when retrying atomic copy as non-atomic
0379fed tty: Fix unsafe ldisc reference via ioctl(TIOCGETD)
f01ed6e kernel/hz.bc: ignore.
34ad662 kernel: Replace timeconst.pl with a bc script
c0b0713 kltevzw: Import kltevzw_defconfig
* packages/apps/BrokenCenter/
7b3181a Fix bugreport for reals this time..still need to adress sepolicy shit
924ad6c Fix: don't use runSuCommand when it ain't needed, for selinux changes and add some missing shit Change-Id: I814bc8543622287d48bf923014873fbb7299e49e
d318eab Selinux Switch [1/2]
9bcbc29 Selinux Switch [2/2]
* packages/providers/DownloadProvider/
2fbbafe Merge tag 'android-6.0.1_r24' into m6.0.1
* packages/services/Telecomm/
eac6eea Merge tag 'android-6.0.1_r24' into m6.0.1
* packages/services/Telephony/
8b4e9eb Merge tag 'android-6.0.1_r24' into m6.0.1
3e85ff0 add back BrokenCenter
7e6084a 6.0.1_r24
* system/core/
9d3191e Merge tag 'android-6.0.1_r24' into m6.0.1
* vendor/broken/
c5d6420 Add back BrokenCenter
dfa800f v4.5
* vendor/lge/
5fe36bf hammerhead: update vendor binaries from MMB29X
8f980f2 hammerhead: update all vendor blobs from MMB29V binaries
cf4e4e5 hammerhead: add back missing soundfx lines
6722b38 Merge pull request #178 from jakew02/cm-13.0
d22e097 bullhead: MHC19Q
04-06-2016
* device/samsung/serranodsdd/
615e9ea Merge pull request #14 from Silviumik/cm-13.0
* external/ant-wireless/ant_native/
7674604 Merge tag 'LA.BF64.1.2.2-04040-8x94.0' of git://codeaurora.org/quic/la/platform/external/ant-wireless/ant_native into HEAD
* frameworks/base/
7434704 Performance Optimization: Align texture dirty rect
dcf5892 Remove opaque check in preparing dirty region for all QCOM device
9acce30 Remove opaque check in preparing dirty region
* frameworks/opt/telephony/
d851974 Fix a telephony issue for tablets
624f14f hal: allow compress voip on raw output streams
eba00b7 hal: APQ8084 uses AUDIO_PARAMETER_KEY_BT_SCO_WB for bluetooth wideband
* hardware/qcom/audio-caf/msm8996/
6e235c3 post proc : volume listener : fix effect release crash
* hardware/samsung/
5905f06 Automatic translation import
4aeb765 timerfd: support CLOCK_BOOTTIME clock
c68d026 hrtimers: Move SMP function call to thread context
b5e5188 hrtimer: Add expiry time overflow check in hrtimer_interrupt
eb51054 hrtimer: Fix ktime_add_ns() overflow on 32bit architectures
abf1813 hrtimer: Prevent hrtimer_enqueue_reprogram race
173c9fa hrtimer: Update hrtimer base offsets each hrtimer_interrupt
504b421 hrtimers: Move lock held region in hrtimer_interrupt()
02e4106 hrtimer: Provide clock_was_set_delayed()
3728eaf tick: Prevent uncontrolled switch to oneshot mode
e2062da tick: Cleanup NOHZ per cpu data on cpu down
403f9f0 clockevents: Set dummy handler on CPU_DEAD shutdown
b5279ae nohz: Make tick_nohz_irq_exit() irq safe
e180f04 time: Move ktime_t overflow checking into timespec_valid_strict
1e48c07 time: Avoid making adjustments if we haven't accumulated anything
a9c0c96 time: Improve sanity checking of timekeeping inputs
737a91d ntp: Fix STA_INS/DEL clearing bug
6adba1e timekeeping: Provide hrtimer update function
e98fa24 timekeeping: Maintain ktime_t based offsets for hrtimers
d6a49ad timekeeping: Fix leapsecond triggered load spike issue
17ac959 sched/nohz: Rewrite and fix load-avg computation -- again
af910f3 ntp: Correct TAI offset during leap second
f8aed30 timekeeping: Fix CLOCK_MONOTONIC inconsistency during leapsecond
d865841 clockevents: Don't allow dummy broadcast timers
84bd4c2 timekeeping: Cast raw_interval to u64 to avoid shift overflow
* packages/apps/LockClock/
ff6a3f0 Automatic translation import
411d47f Remove SlimLaucher and BrokenCenter
* vendor/broken/
6973382 Fix the script so no -c flag tells the user hes an idiot
ac6d4d0 Duggable build by default - adb logcat FTW
d368317 Remove BrokenCenter and SlimLauncher
* vendor/samsung/
826b3b4 Merge pull request #755 from RGIB/cm-13.0
6fc0adf n5110 : blobs update to 4.4.2
380ceb3 kona : update blobs to 4.4.4
00355e5 n5100 : blobs update to 4.4.4
04-05-2016
* build/
1e6e809 Update the dumpvar
ee78866 klte-common: Update TCP performance from CAF
f352cc6 klte-common: remove deprecated init script
5f0c899 klte-common: remove mounting debugfs
2e142ba Synced with @arco`s sources . Fixed 3G -> 2G
* frameworks/base/
324504a Revert "Only window position changed, update window crop."
fe15b60 REVERT: TMP: MSIM: Don't return -1 for getDefaultDataSub() if there's SIM in
46f181b Add back notification title removed during increasing ringtone changes
04-04-2016
4dbf97b Telephony : Allow multiple default dialers
* vendor/broken/
d9db88f Update T-Mo apns
* vendor/samsung/
814d174 kltevzw: Update proprietary libraries
04-03-2016
* vendor/broken/
211028f FOR OFFICIAL MAINTAINERS ONLY!
Fleissig :thumbsup:
Wenn ich am Wochenende die Zeit finde, werd ich BrokenOS mal testen.
Kann das sein, dass die Devs von BrokenOS was gegen XDA haben? Zumindest scheints mir so...
Grad gelesen, die scheinen sich ja mächtig mit den Leuten von XDA in der Wolle zu haben...
Sehr schade, aber da werd ich mich nicht reinhängen.
Vorweg, ich bin ein ziemlicher Neuling, aber ich habe mich schon gut reingefuchst... :D
Habe es gerade geschafft das die CM 13 im boot menu hängen bleibt^^
Habe mir gerade die BrokenOS gezogen, werde die mal testen und vllt ein kleinen Bericht aus Neulings-Sicht abgeben :p
ps. bei der Updateanleitung steht: "Download der aktuellsten Resurrection ROM und kopiert diese auf eure SD-Karte" ;)
MfG Rob
lol ja Faulheit .......ändere es mal ....danke
Edit:
Wenn ich die Statusleiste nach unten ziehe, dann kommt so ein Graffiti mit BrokenOS.
Kann man dieses i-wie ändern oder entfernen?
Edit2:
puhh mache die broken noch nicht lange kann ich dir jetzt nicht sagen .
okay, naja kann ich erstmal mit leben :)
Soweit wie ich es brauche und was ich benutze funktioniert alles stabil. Starte gleich mal WhatsApp, mal gucken ob hier auch der Kamera-Fehler vorhanden ist.
andere Frage.....
hatte eigentlich Root, jetzt sagt der root-checker: ich habe es nicht...
Gibt es da noch i-wo eine einstellung oder muss ich nochmal rooten ?
Hast Entwickleroptionen an und da root zugriff angemacht ?
Ja genau Entwickleroptionen und da suche ich verzweifelt nach root zugriff :O
SuperSu ist da ??
gatnnos
gatnnos
jzuchi
juni
