[ROM][G900F][6.0.1] AOKP MM [OFFICIAL][NIGHTLIES]
hiowa93
hiowa93
AOKP-ANDROID OPEN KANG PROJECT
What is AOKP?
AOKP stands for Android Open Kang Project. It is a custom ROM distribution for several high-end Android devices. The name is a play on the word kang and AOSP (Android Open Source Project). The name was sort of a joke, but it just stuck, just like our infatuation with unicorns.
We fork the source code of Android that Google puts out in the open with every major version release, and we then add the magical unicorn bytes (read: we add some of the coolest features that are both useful and make your ROM awesome).
With AOKP, you can generally do a lot more with your device than what you could do with the original firmware that came installed on it.
Why AOKP ?
We were waiting for when you'd ask this.
There are a variety of reasons why a hilly billy Android user, on a bright sunny day, would suddenly start using AOKP and loving it.
For one, AOKP is lightweight. Most OEMs provide a heavy UI layer over Android and have loads of bloatware (i.e. apps that not everyone use every day, but you cannot remove because they're "baked in" by default). Since AOKP is built upon vanilla Android source, it has neither of the above.
Also AOKP has features that you will not find on your stock firmware. You can have a multitude of toggles to quickly flip a lot of your phone's settings right at your fingertips, or you can launch apps quickly from any screen using our Ribbons.
You can change almost each and every aspect of the OS, from its looks to the way it functions, with total freedom. And did we tell you, AOKP helps you make tacos?
Downloads
Instructions
Factory Reset/Wipe Data
Format System
Format Cache
Format Dalvik Cache
Install ROM
Install Gapps
Reboot
Reaktionen: HammDefy, j1gga84 und Olli von G
Ist aber ein inoffizielles build oder hab ich was verpasst?
welche gaps muss ich nehmen ? und muss ich die über recovery flashen ?
Du musst die ARM 6.0 Gapps nehmen, hier entweder die pico oder nano und geflasht wird die zip dann über die Recovery.
Ich habe dieses ROM mit den open gapps arm 6.0 pico, Xposed und dem Boeffla-Kernel geflasht. Läuft sehr gut.
Reaktionen: j1gga84
Interessant, wenn der Boeffla Kernel läuft basiert diese ROM nicht auf AOKP sondern auf CM wie alle anderen auch..
@hiowa93
Würdest du den Opener und Threadtitel bitte von Zeit zu Zeit aktualisieren?
Dem scheint so zu sein.
[doublepost=1458936167,1458934411][/doublepost]Dieses AOKP hat CM nur als Unterbau. Man sieht es, wenn man durchs Menü zappt.
Downloadlink editiert, da es nun offizielle Nightlies von AOKP gibt :thumbup:
Hey Leute,
Hab gleich zwei Probleme :(
Erstes Problem: ich kann telefonieren und SMS schreiben aber nicht ins Internet... Hab web.Vodafone.de als apn gesetzt (Standart ist fonic) und immer wenn ich online will, sagt mir die Statusleiste, dass ich mich im Netz anmelden soll und leitet mich dann auf eine Seite wo ich Daten-Pakete kaufen soll...
Vodafone Sagt das sei die Seite für prepaid Kunden und weiß keinen Rat...
Zweites Problem: hab eine 64 GB Micro SD mit ~90 lesen und schreiben und diese als internen Speicher eingefügt, beim migrieren bricht der kopiervorgang aufgrund von Platzmangel ab...
Weiß einer Rat?
[doublepost=1467912381,1467908799][/doublepost]Oh uuuund noch eins ^^
Vorgestern abend hatte ich noch einen schönen Sonnenuntergang in der Statuszeile und dann aufeinmal nicht mehr :(
Schade Ziehmlich wenig Resonanz hier, kann mal jemand ein Bild von den Akkustatistiken zeigen nach einen normal genutzten Tag ?
gatnnos
gatnnos
jzuchi
juni
