burner8
Ehrenmitglied
- 16.384
hier die Lösung, für diejenigen die die einstell-Möglichkeit der Lautstärke im Taschenmodus unter Android 9 vermissen.
Finally, a solution to missing pocket mode option
Hello,
I have finally solved it, I tried it and it works perfectly.
Here are the steps:
1- Install settings database editor by 4A from Google Play store
2- Allow developer options in your phone's settings
3- Allow USB debugging
4- Install platform tools ADB on your PC
5- Connect your phone to PC
6- Make sure your phone is recognized by ADB, type command: adb devices
7- if the ADB console list your device number, type the command:
adb shell pm grant by4a.setedit22 android.permission.WRITE_SECURE_SETTINGS
8- On your phone, open the application Setedit
9- Go to the Secure Table from the top right menu
10- Find the line "Hide_Pocket_Mode", select the value, change it from 1 to 0.
11- Restart your phone, and you'll find the option in the dialer options, More settings.
Beim P30/P30 Pro und Mate 20X funktioniert es auf jeden Fall.
Frohe Ostern an Alle
Hello,
Here are the steps:
