Hen Ry
Enthusiast
- 1.680
vom XDA Mitglied Androguide.fr von dem auch diese ROM [ROM][KK][KOT49H][HOMEMADE] OmniRom [4.4.2][HONAMI] stammtPimp My Z1 is a sleek, holo, fully Open-Source (GPL v2 license) app which allows to control various sysfs interfaces present on some kernels for the Z1.
Most features require either*Pimped Kernelhttp://forum.xda-developers.com/showpost.php?p=50603482&postcount=1*(for CM-based roms) or*Doom Kernel*(for Stock-based roms), but the CPU & GPU Control as well as Touch Screen control will work properly with any kernel including the stock one.
Features
CPU Control:
Miscellaneous:
- Set your minimum & maximum CPU frequencies (and overclock if your kernel allows it)
- Set a different Governor for each CPU core
- Select your I/O Scheduler
- View your current CPU frequency in real-time and with a graph
- Set your minimum & maximum GPU frequencies (and overclock it if your kernel allows it)
- Select your GPU Governor
- View your current GPU frequency in real-time and with a graph
- Select your level of multi-core power savings, a.k.a sched_mc power savings (disabled/moderate/aggressive)
- Toggle the IntelliPlug hotplug driver on and off
- Toggle IntelliPlug's eco mode on and off
- Toggle between the default early_suspend PM driver and the newer power_suspend PM driver
- Toggle Dynamic File Sync on and off
- Set a different I/O Scheduler for the eMMC & the SD-Card
- Toggle Kernel Same-page Merging (KSM) on & off
- Define the amount of pages to be scanned by KSM at each run
Miscellaneous:
- Define the vibrator intensity at kernel level
- Manage Fast Charge mode & amperage level
- Independently control the digital headphone output left/right channels gain at a hardware level
- Independently control the analog headphone output left/right channels gain at a hardware level
- Independently control the speaker output left/right channels gain at a hardware level
- Control the microphone input gain at a hardware level
- Control the camera microphone input gain at a hardware level
- Enable/Disable Pen Mode to allow/disallow the use of any non-plastic pen or object as a stylus for the touchscreen
- Enable/Disable Glove Mode to allow/disallow using the touchscreen while wearing gloves
- Enable/Disable Double Tap 2 Wake
- Pimp My Z1 v1.1.4-beta -> XDA -> github/releases/beta
- Added CPU Governor customization through a dialog
- Added brightness control to the Color Control section
- Fixed custom voltages not being applied on boot
- Updated german translation thanks to @Henry2o1o (es fehlt noch einiges, zu gegebener Zeit werde ich es noch ergänzen)
- Pimp My Z1 v1.0.7-beta
- Added msm_thermal toggle
- Added amount of cores online under the CPU frequency graph
- Made the per-core governor spinners always enabled
- Fixed german strings in the english strings
- Pimp My Z1 v1.0.6a-beta
- Hotfix for the app crashing when applying the user's saved settings on boot
- Pimp My Z1 v1.0.6-beta
- Profiles: Implemented preset profiles to the kernel control: BatteryMax/Battery/Balanced/Performance/Benchmark/Custom
- CPU Control: Added option to toggle per-core control, allows to set the governor for all cores or for each core independently like before.
- CPU Control: The cores state (online/offline) is now automatically updated every 500ms
- Misc: Added Vibrator control under Miscellaneous
- Moved KSM to a new section: memory management
- Fixed laggy seekbars in Sound Control
- Removed unused internet permissions
- Updated german translation, thanks to @Henry2o1o
- Pimp My Z1 v1.0.5-beta
- Added support for faux123's Snake Charmer
- Added controls for eMMC & SD-Card readahead
- Added controls for eMMC & SD-Card entropy contribution
- Increased maximum allowed KSM pages-to-scan to 512
- Pimp My Z1 v1.0.4-beta.apk - aktuell
- Added support for showp1984's msm_mpdecision (recently ported to Pimped Kernel)
- Fixed KSM seekbars not updating their displayed values
- Updated japanese translation (thanks to @WedyDQ10)
- PimpMyZ1-v1.0.3.apk
- Added a Miscellaneous section under Kernel Control
- Miscellaneous: Added support to toggle KSM (Kernel Same-page Merging) on and off
- Miscellaneous: Added controls to define the amount of memory pages that should be scanned by KSM at each r un
- Miscellaneous: Added controls for the KSM sleep timer, which defines the time KSM will sleep after each run before scanning again
- SoundControl: fixed mic gain & camera mic gain
- PimpMyZ1-v1.0.2.apk
- Added TCP Congestion Algorithms control (in CPU Control)
- Added separate SD-Card I/O Scheduler control
- Moved I/O Schedulers control to I/O Tweaks section
- Added german translation (thanks to @Henry2o1o) -> ich habe jetzt alles übersetzt, mal sehen in welcher Build es eingefügt wird
- PimpMyZ1-fc-fix-4.apk
- PimpMyZ1-fc-fix-3.apk
- PimpMyZ1-fc-fix-2.apk
- PimpMyZ1-fc-fix.apk für siehe Zitat
- PimpMyZ1.apk
[*][URL="https://play.google.com/store/apps/details?id=com.androguide.honamicontrol"]Google Play Store
"i got FC when i click cpu control, gpu control, power management, on DooMKernel v06 kernel, stock 290 rom"
To-Do
- CPU Governor parameters control
- Touch-screen pressure scale tuning for normal & pen mode
- Sound control through mixer_paths.xml for kernels which don't implement faux sound control (i.e: stock)
- Voltage control
- Download of Pimped Kernel and open-recovery script to flash it automatically
- You tell me
