GSXR-750
Stammgast
- 284
Changelog:
System
Gallery
Network
Habe es noch nicht Bekommen über den Updater.
Quelle:
OnePlus: OxygenOS 11.0.4.4 für das OnePlus 8 (Pro) und OxygenOS 11.0.7.10 für das OnePlus 8T wird verteilt
System
- Optimized the experience of using long screenshots
- Optimized the UI display effect of the notification bar
- Improve the stuttering problem of some tripartite applications
- Fixed the small probability issue that Twitter may freeze
- Fixed the issue that opening app split-screen may fail
- Fixed the issue of failure to switch the accent color in a small probability
- Fixed the inaccurate display of the attribution of some numbers
- Fixed known issues and improved system stability
- Updated Android security patch to 2021.01
Gallery
- Fixed the issue that the video cannot be played in a small probability
Network
- Fixed the noise issue of 5G calls
Quelle:
