[Firmware][9.0] OxygenOS Open Beta 35 [Pie]
TomTim
TomTim
Ehrenmitglied
6.425
Was gibt´s neues?
System
  • General bug fixes and stability improvements
Weather
  • Improved scrolling experience for switching between pages
  • Weather cards for multiple cities can now be rearranged or deleted by tapping and holding on them
  • Optimized user experience by allowing you to use this app while app permission to access GPS location is disabled
Phone
  • Improved animation effects when switching between pages
  • Improved experience with searching for contacts
  • Optimized Quick Responses for declined calls and supported editing Quick Responses
Zen Mode
  • Added Zen Mode helping you keep away from the screen and back to life for 20 minutes
Reaktionen: radiomaxx
OnePlus 5 Updateverlauf
System
Weather
Phone
Zen Mode
System
  • Updated Android security patch to 2019.06
  • Added digital wellbeing (Settings – Digital WellBeing)
Fnatic Mode
  • Brand new Fnatic mode offering you immersive gaming experience
System
  • Fixed the bug where Facebook Messenger pops up notifications in gaming mode
  • Improved smooth-scrolling experience
Message
  • Supported PIN-TO-TOP for notification category (India Only)
Communication
  • Optimized the logic of dialing a contact while using two SIM cards
System
  • Updated Android security patch to 2019.05
OnePlus Switch
  • More accurate remaining time for completion
System
  • Display overheating device warning
  • New UI für system update
Quick reply in landscape
  • Supported mor IM APPs for Quick Reply in landscape
  • Apps don´t get paused when using quick reply in landscape
Community
  • Optimized search experience by adding search field, and grouping search results in different categories
  • Improved the UI of Social page
  • Oprimized Log recording in Bug Report section
System
  • Updated Android security patch to 2019.04
  • Improved network speed display
  • Supported shortcuts to access corresponding interfaces in Quick Settings
  • Supported quick reply in the notification bar
Launcher
  • Added tutorial in shelf
  • Added Parking location feature
  • Improved page Indicator to mirror Icon pack
System
  • Screenshot UI optimizations
Launcher
  • Improved color adaptation for cards in the shelf
OnePlus Switch
  • Supported permissions migration for applications
Weather
  • More details added to weather warnings
  • Weather timeline now follows system time format
  • General bug fixes
Phone
  • UI optimizations
Download
System
  • Updated Android security patch to 2019.03
  • New animation for flight mode
  • Optimized notifications for quick settings
  • Optimized battery consumption
Messages
  • Now able to select contact groups for sending SMS
System
  • Updated Android security patch to 2019.02
  • Gaming mode enhancement
OnePlus Clock
  • Added weather information to the clock widget
System
  • Optimizations for the screenshot function
  • Support for quick reply in landscape mode, now easier to reply to new messages when watching videos
System
  • Updated Android security patch to 2019.01
  • Improvements for screen brightness control
  • Confirm pin without tapping √ for app locker
  • Improved color adaptation for navigation bar when using third-party apps
Gallery
  • Added create collection, copy and move photos features
  • New illustrations and design on blank pages
  • General Bug fixes and overall experience improvements
Launcher
  • Added recommended tools in the toolbox
  • Improved UI for category tags in the app drawer
Phone
  • Added call history for incoming calls from unknown numbers
  • Improved UI for Call History
  • Deep integration with Google Duo
  • Added caller identification feature (For India only)
Weather
  • Added more search options to improve the accuracy of search results
  • Improved accuracy of weather descriptions
  • Added more unit options for precipitation, visibility, pressure and other data
  • Added more detailed descriptions to weather icons
OnePlus Switch
  • Now supports migrating data from iPhone
System
  • Fixed random audio tuner crashes
  • General bug fixes and system stability improvements
System
• Updated Android Security patch to 2018/12
• Fixed issues with custom accent colour not getting applied every second try
• Optimizations for Face Unlock
Launcher
• Fixed UI issues with scroller in app drawer
• Improved colour adaptation for navigation bar
Third-Party App
• Fixed issue with Netflix crashing randomly
System
  • Updated system to Android™ 9.0 Pie™
  • Brand new UI for Android Pie
  • Brand new navigation gestures (this is only for 5T)
  • Updated Android security patch to 2018.11
  • Optimizations for background app process handling
Do Not Disturb mode
  • New Do Not Disturb mode with adjustable settings
Communication
  • UI Improvements for emergency rescue
  • Optimized UI for speed dial and calling interface
  • Now able to assign a specific SIM for a specific contact or group of contacts when using dual SIM
Parallel Apps
  • Added support for more apps (Telegram, Discord, IMO, Uber, OLA) in parallel apps
Weather
  • Now able to switch dynamically to your current location
  • Display more suggestions when the search function is used
  • Fixed an issue that prevented the app from refreshing when the location is changed
  • Fixed an issue that resulted in some users being unable to find certain locations
Download
System
Updated Android security patch to 2018.10
General bug fixes and improvements
Reaktionen: Kosake77 und radiomaxx
Open Beta 22 mit Android Pie soeben eingetroffen!!!
hab mir open beta 22 auch grad über umwege installiert. kam vom stock und hatte noch keinen download gefunden.
also beta 21 installiert, OTA runtergeladen, aber zuvor nochmal beta 21 im twrp drüber gelassen, damit stock-recovery vorhanden ist und dann OTA installiert. (das zip-file ließ sich in einer pie-tauglichen version von twrp nicht flashen - "zip comp...err")
und schließlich nochmal einen werksreset, damit das system auch echt frisch ist ;)
jetzt richte ich halt nochmal ein.
Ich gehe mal davon aus dass hier keine allgemeinen Diskussionen zu Android Pie auf dem OP5 geführt werden sollen...?
Daher mach ich mal nen neuen Thread im Oneplus 5 Bereich auf.
Gruß, maxx
Nein, im gegenteil. Hier darf diskutiert werden.
Nachdem seit heute morgen die Open Beta 22 verfügbar ist (siehe hier) und damit die erste Version von Android 9 (Pie) endlich für unser OnePlus 5 getestet werden kann, wollte ich hier über die ersten Erfahrungen/Verbesserungen/Bugs sprechen.
Bisher läuft bei mir alles flüssig. Ich bin direkt von der Open Beta 21 gekommen und habe keinen Wipe oder ähnliches gemacht.
Schön finde ich die neuen Animationen und Übergänge zwischen Apps.
Auch die neue Statusleiste inkl. neuen Symbolen finde ich gelungen.
Neu sind auch die Ein/Aus- sowie Lautstärke-Menüs, die neben den jeweiligen Tasten eingeblendet werden.
Einzig meine SmartWatch (Vivoactive 3) musste ich neu koppeln. Anscheinend ist was an den Bluetooth-Ei-stellungen gemacht worden.
Alles in allem bin ich wie gesagt sehr zufrieden über dieses verfrühte Weihnachtsgeschenk! ;-)
Gruß, maxx
Wie gesagt, es kann und darf hier diskutiert werden. Es bedarf nicht zwei Themen dazu.
ich bin auch direkt von der offiziellen 5.1.7 (rooted, twrp) auf diese beta ohne wipe gesprungen...
Laeuft stabil und ohne Probleme, soweit jetzt sichtbar...
Welches twrp nutzt ihr denn? Hatte vorsorglich eine pie-taugliche Version installiert, haute aber nicht hin.
Hab's dann über Stock Recovery gemacht und twrp+magisk danach installiert
System läuft soweit super.
ich nutze das twrp-3.2.3-x_blu_spark_v9.85_treble-op5_op5t.
Habe zuerst in twrp das neue Rom geflashed, nachdem ich die compatibility.zip aus der zip entfernt habe.
Dierekt danach (ohne reboot) twrp nochmals geflashed wegen sonst vorhandenem Standard recovery. Dann reboot wieder in twrp und magisk und no-verity-op5(T)_V3_treble installiert. reboot system....
Und schon ist ein Update da...
Open Beta 23
Reaktionen: TomTim
Mal sehen, ob das Problem mit Face Unlock behoben wurde, dass es heißt, die Kamera wird von einer anderen App verwendet und daher geht Face Unlock gerade nicht.
Beta 24 wird verteilt... Frohe Weihnachten!
Reaktionen: radiomaxx, vaszago und denkmawos
Neues Update, mit einer etwas umfangreicheren Änderungshistorie wartet auf die drei letzten OnePlus 5 Besitzer. :)
Reaktionen: kallmeidroppe, HTC_Freak und radiomaxx
Neue Beta ist da.
Wurde die Beta 26 zurückgezogen?
Ich bekomme sie einfach nicht als OTA anfeboten...
Grus, maxx
Ja, sie wurde zurück gezogen.
Beta 29 wird ausgerollt.
Beta 31 wird ausgerollt.
Kosake77
Kosake77
Kosake77
Kosake77
traxxy
