1. TomTim, 24.10.2018 #1
    TomTim
    TomTim Threadstarter Moderator Team-Mitglied
    [​IMG]
    System
    • Updated Android security patch to 2019.1
    • Improved stability for OTA upgrade
    • General bug fixes and system improvements
    Phone
    • Deep integration with Google Duo
    Networks
    • Improved network stability
    Download
    ger_kar, deltay78, Pascal54 und eine weitere Person haben sich bedankt.
  2. TomTim, 24.10.2018 #2
    TomTim
    OnePlus 5 Updateverlauf
    System
    Phone
    Networks
    Download
    Hot Fix
    • Fixed connectivity issue with certain third-party Apps
    • Improved stability for Sound settings
    • Stability improvements for the system upgrade
    System
    • Improved stability for Wi-Fi connection
    • Optimized sRGB display mode
    • Optimized Reading mode
    • Fixed issue with 4G VoLTE toggle missing
    • Fixed random reboots when Screen Casting
    Hot Fix
    • Fixed WiFi connectivity issue with certain third-party Apps
    • Fixed issue with physical/capacitive navigation buttons not working at times(OnePlus 5 only)
    System
    System
    • Improved stability for Wi-Fi connenction
    • Fixed random reboots when screen casting
    System
    • Updated system to Android™ 9 Pie™
    • Brand new UI for Android Pie
    • Brand new navigation gestures (Available for OnePlus 5T only)
    • Updated Android security patch to 2018.12
    • Other new features and system improvements
    New Gaming mode 3.0
    • Added text notification mode
    • Added notification for 3rd party calls
    Do Not Disturb mode
    • New Do Not Disturb (DND) mode with adjustable settings
    Camera
    • Integrated Google Lens mode
    Hot fix
    • Fixed stability issue with Bluetooth for cars
    System
    • Supported for Project Treble
    • Supported IDEA Indea VoLTE (Default On)
    • Improved Bluetooth stabiltiy for phone calls
    • Updated Android security patcht o 2018.10
    System
    • Supported Project Treble
    • Supported IDEA India VoLTE (Default On)
    • Improved Bluetooth stability for phone calls
    • Updated Android security patch to 2018.10
    Download
  3. basian mile, 27.10.2018 #3
    basian mile
    basian mile Android-Lexikon
    Hallo zusammen
    Ich befinde mich grad auf 4.5.15 unlocked, rooted.
    Wie komme ich auf das aktuelle Stockrom?
    Ich bin voll raus aus den Thema und brauche deshalb grad was Hilfe.
  4. Krummi, 27.10.2018 #4
    Krummi
    Krummi Fortgeschrittenes Mitglied
    Hat schon jemand die neue Version getestet?
  5. Pascal54, 28.10.2018 #5
    Pascal54
    Pascal54 Erfahrener Benutzer
    Die angebotene Vollversion ist nicht neuer wie die 5.1.5, zeigt mir das Phone an wenn man sie installieren möchte.
    Als OTA habe ich noch nichts bekommen
  6. vaszago, 28.10.2018 #6
    vaszago
    vaszago Android-Hilfe.de Mitglied
    ja hab es am Freitag installiert über die APP Oxygen Updater vom Playstore. Nichts auffälliges nur das der GPS empfang sich deutlich verschlechtert hat. Sonst wer noch das Problem.
    Pascal54 bedankt sich.
  7. Pascal54, 29.10.2018 #7
    Pascal54
    Ist Dein Phone gerootet oder geht das auch ohne Root
  8. vaszago, 29.10.2018 #8
    vaszago
    geht auch ohne Root
    hier die App
  9. Pascal54, 30.10.2018 #9
    Pascal54
    Alles klar, Danke
  10. Pascal54, 01.11.2018 #10
    Pascal54
    Habe das Update durchgeführt, VoLTE musste ich trotzdem erst nach Anleitung aktivieren
  11. Krummi, 04.11.2018 #11
    Krummi
    Läuft bei mir auch wunderbar. VoWifi und VoLTE muss nach dem Update tatsächlich neu freigeschaltet werden.
  12. denkmawos, 04.11.2018 #12
    denkmawos
    denkmawos Android-Hilfe.de Mitglied
    Wird beim Updaten mit dieser APP das Gerät zurückgesetzt, oder bleiben die Einstellungen und installierte App´s erhalten?
    MfG denkmawos
  13. dasacom, 04.11.2018 #13
    dasacom
    dasacom Android-Experte
    bisher ist bei mir alles glatt gelaufen und die Apps/Einstellungen blieben erhalten.
    Die App lädt ja nur die originalen Update Dateien also ggf. kommt man so schneller ans Update, da Oneplus die Updates langsam ausrollt.
    denkmawos bedankt sich.
  14. denkmawos, 04.11.2018 #14
    denkmawos
    @dasacom
    Das Update ist problemlos durchgelaufen. Dein Problem bezüglich GPS-Empfang kann ich bei meinem Gerät nicht feststellen, habe mit "GPS Test plus"
    vor und nach dem Update keinen Unterschied festgestellt (sowohl Satfix als auch Signalqualität)!
    MfG denkmawos
  15. Pascal54, 13.11.2018 #15
    Pascal54
    Update 5.1.7 über Oxygen Updater installiert. VoWifi und VoLTE mussten diesmal nicht neu freigeschaltet werden.
  16. Krummi, 15.11.2018 #16
    Krummi
    Über das Systemupdate lief es auch ohne Probleme. Nur 38MB groß das Update.
  17. TomTim, 25.12.2018 #17
    TomTim
    Weihnachtszeit ist Kuchenzeit. Android Pie wird verteilt...
    CyPress1988 und denkmawos haben sich bedankt.
  18. Pascal54, 26.12.2018 #18
    Pascal54
    Habe heute Android Pie bekommen, wie meine Frau auch auf dem Oneplus 5T
  19. Scanda, 26.12.2018 #19
    Scanda
    Scanda Fortgeschrittenes Mitglied
    Schon irgendwelche Erfahrungen bei dem Update auf Android 9.0?
  20. denkmawos, 26.12.2018 #20
    denkmawos
    @Scanda
    Update problemlos durchgelaufen, bis jetzt keine Auffälligkeiten.
    Gesprächsqualität, GPS, WLAN, Bluetooth, sowie Kamera (Foto&Video) getestet.
Die Seite wird geladen...
Ähnliche Themen Forum Datum
[Firmware][9.0] OxygenOS Open Beta 28 [Pie] Original-Firmwares für das OnePlus 5 29.10.2018
[Firmware][8.1] OxygenOS Open Beta 20 [Oreo] Original-Firmwares für das OnePlus 5 15.10.2018
[Firmware][8.1] OxygenOS Open Beta 19 [Oreo] Original-Firmwares für das OnePlus 5 25.09.2018
[Firmware][8.1] OxygenOS Open Beta 18 [Oreo] Original-Firmwares für das OnePlus 5 11.09.2018
[Firmware][8.1] OxygenOS Open Beta 17 [Oreo] Original-Firmwares für das OnePlus 5 29.08.2018
[Firmware][8.1] OxygenOS 5.1.5 [Oreo] Original-Firmwares für das OnePlus 5 21.08.2018
[Firmware][8.1] OxygenOS Open Beta 16 [Oreo] Original-Firmwares für das OnePlus 5 14.08.2018
[Firmware][8.1] OxygenOS Open Beta 15 [Oreo] Original-Firmwares für das OnePlus 5 02.08.2018
[Firmware][8.1] OxygenOS 5.1.4 [Oreo] Original-Firmwares für das OnePlus 5 27.07.2018
[Firmware][8.1] OxygenOS Open Beta 14 [Oreo] Original-Firmwares für das OnePlus 5 16.07.2018
Du betrachtest das Thema "[Firmware][9.0] OxygenOS 9.0.4 [Pie]" im Forum "Original-Firmwares für das OnePlus 5",
  1. Android-Hilfe.de verwendet Cookies um Inhalte zu personalisieren und dir den bestmöglichen Service zu gewährleisten. Wenn du auf der Seite weitersurfst stimmst du der Cookie-Nutzung zu.  Ich stimme zu.
