CerealKiller77
Stammgast
- 435
OnePlus 5 - Original Firmwares OxygenOS
FUll ROM
Android 8.1.x
Android 8.0.x
Android 7.1.x
** Jeweils die 2 Part Files downloaden und 1x entpacken, so dass ihr 1 .zip Datei erhaltet **
Anmerkung: Diese Funktion erfordert derzeit den Zugriff auf die Seite über den integrierten Safari-Browser.
Hi all,
We are rolling out OxygenOS 4.5.3 OTA for OnePlus 5 globally, here are the changes:
Recommendation index: ★★★★★
Bug Fixes:
Optimizations:
- Expanded screenshot display issue
- Google Translate stutters
- Wi-Fi occasional drops
****Known issues and fixes:
- System stability improvements
- Camera effect and stability enhancements
- Effects of auto-brightness adjustment
- Accuracy of data usage statistics
Please feedback in the bug reporting forum here if you encounter any issues: Bug Reports - OnePlus Forums.
- Unable to use WeChat and PokemonGo under US T-Mobile network
- Please manually reconfigure your APN settings to:
- Name: T-Mobile US LTE
- APN: fast.t-mobile.com
- Proxy: <Not set>
- Port: <Not set>
- Username: <Not set>
- Password: <Not set>
- Server: <Not set>
- MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
- MMS proxy: <Not set>
- MMS port: <Not set>
- MMS protocol: WAP 2.0
- MCC: 310
- MNC: 260
- Authentication type: <Not set>
- APN type: <Not set>
- APN protocol: IPv4/IPv6
- APN roaming protocol: IPv4
- Enable/disable APN: <greyed out unless there are multiple APN's>
- Bearer: Unspecified
Never Settle.
Hi all,
We are rolling out OxygenOS 4.5.4 Hotfix OTA for OnePlus 5, here are the changes:
Recommendation: Users in Netherlands having 4G network issues are recommended to upgrade to this build asap.
Hot Fix:
- Fixed Netherlands 4G network issue
Never Settle.
Hi all,
We are pushing out the incremental roll-out of OxygenOS 4.5.5 OTA for OnePlus 5.
Optimizations:
Bug Fixes:
- Further improvements to Wi-Fi connectivity
- Clearer voice calling
- Video recording now consumes less battery
- Vibration intensity when receiving calls is now tuned to a gentler level
For those who were on previous versions for OnePlus 5, we appreciate your active feedback and attempts to reach out to us. With your help, we have been able to better optimize and improve several key areas. Thank you for your patience and as always, we look forward to hearing your continued feedback in the bug reporting forum here: Bug Reports - OnePlus Forums.
- Fixed Wi-Fi signal consistently being displayed as weak
- Fixed certain apps not able to work under IPv6 network settings
- To restore connectivity to a Windows 10 PC, please turn off USB debugging prior to the upgrade
As always, this OTA will be incremental. The OTA will reach a small percentage of users today, and we'll begin a broader rollout in a few days.
Your feedback is appreciated. We may not always be able to respond to every comment in the forums, but please be assured that we take your comments and feedback seriously. Hope you enjoy!
Never Settle.
Hi all,
OxygenOS 4.5.7 was withdrawn, we are pushing out the incremental roll-out of OxygenOS 4.5.8 OTA for the OnePlus 5 instead. Here are some of the highlights of this build:
New additions:
Introducing the all new OnePlus Slate font
Added EIS for 4K video recording
Updates:
Updated Android security patch level to 1st July 2017
Optimizations:
Wi-Fi connectivity improvements
Standby battery enhancements
Bug Fixes:
Fixed occasional sound leaks in the speakers when using earphones
Fixed camera shutter sound bug in silent mode for Indian region
Fixed occasional stutters when playing games
Fixed battery drain for Jio users
Never Settle.
Hi all,
We are pushing out the incremental roll-out of OxygenOS 4.5.10 OTA for the OnePlus 5. Here are some of the highlights of this build:
Camera:
Photo noise reduction
Improved Camera stability
60 fps video noise and texture improvements
Launcher:
Added country information of photographers in Shot on OnePlus
Phone:
Fixed accidental touches after hanging up
Improved Jio call functionality
Fixed display issue on calling screen
System:
Improved WiFi stability
Fixed clarity issue of videos taken by SnapShot app
Fixed display issue of new font
Fixed scrolling issue of Play Music
Never Settle.
Hi all,
We are pushing out the incremental roll-out of OxygenOS 4.5.11 OTA for the OnePlus 5. Here are some of the highlights of this build:
System
- Supports customization of notification ringtone
- Improved launching speed of apps
- Optimized adaptive brightness
- Fixed issue of YouTube video lagging behind audio
- Fixed display issues of some UI elements
- Updated Android security patch to September
- Fixed issue of no 4G+ network in some regions
- General bug fixes
For those who were on previous versions for OnePlus 5, we appreciate your active feedback and attempts to reach out to us. With your help, we have been able to better optimize and improve several key areas. Thank you for your patience and as always, we look forward to hearing yourcontinued feedback in the bug reporting forum here: Bug Reports - OnePlus Forums/.
Sorry for the delayed announcement thread. The OTA has reached a small percentage of users hours ago. And we will begin a broader rollout in a few days.
Never Settle.
Hi all,
We are pushing out the incremental roll-out of OxygenOS 4.5.12 OTA for the OnePlus 5. Here are some of the highlights of this build:
System
- Fixed bug of missing icon of Download app in 4.5.11
- General bug fixes
Never Settle.
Hi all,
We are pushing out the incremental roll-out of OxygenOS 4.5.13 OTA for the OnePlus 5. Here are some of the highlights of this build:
System
- General bug fixes
Never Settle.
Hi all,
We are pushing out the incremental roll-out of OxygenOS 4.5.14 OTA for the OnePlus 5. Here are some of the highlights of this build:
System
- Supported Airtel VoLTE in India
- Supported Band 66 of Freedom in Canada
- Fixed Wi-Fi WPA2 security issue
- Optimized battery usage in some cases
- Optimized GPS accuracy
- General bug fixes
Never Settle.
Hey everyone!
We are super excited to announce that we are ready to kick off the Open Beta Program for the OnePlus 5 today! The first Open Beta build based on Android 8.0 for the OnePlus 5 is available for download now. Here’s the changelog of this build.
[Changelog]
[Instructions and Info]
- System
- Updated to Android O (8.0)
- Added Picture in Picture
- Added Auto-fill
- Added Smart text selection
- New Quick Settings design
- Added Parallel Apps
- Updated security patch to October
- Launcher
- Added notification dots
- New app folder design
- Now able to upload photos directly to Shot on OnePlus
[Kind Reminders]
- Please keep in mind that this is beta software. These builds are sometime NOT as stable as our official OTAs generally are. By installing this update, you accept the potential risks of data loss.
- If you would like to join our Open Beta Program, please refer to the flashing instructions [HERE] ..
- Once you migrate to the Beta path, you will continue to receive Open Beta OTAs. You will NO LONGER receive the regular Official Stable OTAs.
- Reverting back to the Official OTA path from the Beta path will require a full install and clean flash (FULL WIPE of all data and cache). Please carefully follow the flash instructions below.
- Please be aware that all data will be wiped during the revert-back process, so do remember to backup your data in advance.
- Download the roll-back build provided [HERE] to Internal storage.
- Shut down your device and enter recovery mode by long pressing the Power + Volume Down key simultaneously.
- Select “Install from Local” and choose the downloaded build to install.
- Reboot your device after installing the build. You have to re-enter recovery mode to Wipe data cache and Erase everything(Music, pics, etc).
- Reboot your device again and you're all good to go.
- As this is a major update we hope that you will fill out our survey on UX & UI [HERE].
- And please remember to tell us about any bugs you may find using the bug report forums, found [HERE].
Since our buddy @Adam Krisko is away from the office this weekend, I helped him to pass this good news to everyone. Make sure to let us know how you feel about this beta build in the comments below, we are watching.
Have a Great weekend everyone!
Hi all,
We are pushing out the incremental roll-out of OxygenOS 4.5.15 OTA for the OnePlus 5. Here are some of the highlights of this build:
System
- GPS improvements
- Fixed issue of not able to set customized alarm ringtone
- Fixed issue of sharing emoji from Bitmoji
- Updated Android security patch to October
- General bug fixes
Never Settle.
Hi everyone,
This is our Christmas gift for you.
We are pushing the incremental roll-out of OxygenOS 5.0, our first official Android O OTA update for the OnePlus 5. And here’s the changelog of this build.
- Launcher
- Optimizations for Shelf
- Now you can upload your photo through Shot on OnePlus
- Camera
- New Camera UI design
- Optimizations for photo quality
- Added beauty effect for Portrait Mode
- Gallery
- Added “Places” tab for viewing photos on a map
- Calculator
- Added history feature
- Clock
- Added alarm calendar feature
- System
- Added Parallel Apps feature
- New design for Quick Settings
- New design for Lift up display
- Added “Adaptive model" screen calibration
- Optimizations for Wi-Fi
- Optimizations for Battery Saver
- Updated Android security patch to December
Your feedback is appreciated. We may not always be able to respond to every comment in the forums, but please be assured that we take your comments and feedback seriously. Hope you enjoy and let us know how you feel about the update in the comments below.
Merry Christmas and a Happy New Year!
Never Settle.
Edit: Because of a bug on Oxygen 5.0, we have cancelled its global release. And we're preparing for Oxygen 5.0.1, the partial release will go alive soon.
Edit:
Hey Everyone,
The build will be continuing to release here shortly. Remember this is a staged roll out, so it will take some time to get out to everyone. The build is now 5.0.1 and most of the changelog is the same, but we've added a few things to this new version.
Remember, currently any device with an unlocked bootloader will fail while tying to update. Please backup your data and then re-lock your device. (This will cause your device to be fully wiped, please be careful!) You will then be able to proceed with the update.
- Bug fixes for third party camera application
- Fixed network issues for European operators
Hi everyone,
- Launcher
- Camera
- Gallery
- Calculator
- Clock
- System
Never Settle.
Hi everyone,
We are starting to push the incremental roll-out of OxygenOS 5.0.2 for the OnePlus 5.
Changelog:
System
Applications
- Added Face unlock function
- Applied CPU security patch: CVE-2017-13218
- General bug fixes and improvements
Camera
- Updated Launcher to v2.2
- Updated Gallery to v2.0
- Updated Weather to v1.9
- Updated File Manager to v1.7.6
- Enhanced EIS for video recording
Never Settle.
