[Firmware][7.1.1] OxygenOS Open Beta 11 [Nougat]
TomTim
TomTim
Ehrenmitglied
6.425
Beta 11 wird verteilt.
Änderungshistorie.
Optimization:
  • Battery saver indication changed from orange status bar to a notification
  • Optimized calculation method for data usage statistics, tracking is now more accurate.
  • Optimized expanded screenshot, now supports capture while gifs and videos are playing. (Experimental)
  • Visual effects improvements for Weather widget
Bug Fixes:
  • Resolved various 3rd party app crashes
  • Fixed bluetooth device battery status wrongly displayed for non-supported devices
  • Fixed Weather occasionally not being able to retrive forecast data
OxygenOS Open Beta 20/11 for the OnePlus 3/3T
Download:
http://oxygenos.oneplus.net.s3.amaz...8_OTA_028_all_1707141503_fc82c5d2e3054e44.zip
Bearbeitet von: AcmE85 - Grund: Habe mal die Links hinzugefügt, das OP3 folgt auch noch... Gruß Mari
Reaktionen: BassBua, Steili, Pharao373 und eine weitere Person
TomTim
TomTim
TomTim
spixi
AcmE85
AcmE85
AcmE85
