[Firmware][7.1.1] OxygenOS Open Beta 12 [Nougat]
AcmE85
AcmE85
Enthusiast
5.702
OxygenOS Open Beta 21/12 for the OnePlus 3/3T
New addition:
  • Parallel apps:
    • All new parallel apps feature that lets you run a parallel version of the same app using a separate account. Right now this supports Facebook, Twitter, Whatsapp, and Instagram (and a few more popular apps)
Updates:
  • Updated to Launcher V2.1.5 :
    • Optimized home screen folder icon, with a preview look of first 4 icons in the folder
    • Redesigned UI for folders, allowing switch between folders by swiping left or right
    • Added double finger slide support, you can now slide the home screen with one finger while using another to hold an item
  • Updated to Gallery V1.8
    • Supports light theme
    • Supports opening RAW format images
  • Updated File Manager to V1.7.1
    • Long pressing search items now shows edit operations
Optimizations:
  • Call histories from the same person will now be merged
Bug Fixes:
  • Fixed increased battery consumption after connecting to a bluetooth device
Download (komplette Zip):
http://oxygenos.oneplus.net.s3.amaz...8_OTA_029_all_1708021855_80477ecd615347a7.zip
Reaktionen: Pharao373, Cyclotron, freeztyler und 2 andere
TomTim
TomTim
TomTim
spixi
AcmE85
AcmE85
AcmE85
