1. TomTim, 19.11.2018 #1
    TomTim
    TomTim Threadstarter Moderator Team-Mitglied
    [​IMG]
    Änderungshistorie:
    System
    • Updated Android Security Patch to 2019.04
    • Improved network speed display
    • Supported shortcuts to access corresponding interfaces in Quick Settings
    Quick reply in landscape
    • Supported quick reply in the notification bar
    Launcher
    • Added tutorial in shelf
    • Added Parking location feature
    • Improved page Indicator to mirror Icon pack
    Download
    Installationhinweis bei: Root & TWRP
    • Die Vollversion Laden und ins Hauptverzeichnis des Telefons kopieren, TWRP installer.zip und Magisk.zip ebenso.
    • Ins TWRP Navigieren
    • 1. OOS und TWRP installer installieren
    • 2. Neustart in TWRP
    • 3. Magisk.zip installieren
    • 4. Neustart ins System
    Sh0X31, XPDroid89, CyPress1988 und 5 andere haben sich bedankt.
  2. TomTim, 19.11.2018 #2
    TomTim
    OnePlus 6 Updateverlauf
    System
    Launcher
    Download
    System
    • Screenshot UI Optimizations
    Gallery:
    • Improved photo editor
    Launcher
    • Improved color adaptation for cards in the shelf
    OnePlus Switch
    • Supported permissions migration for applications
    Weather
    • More details added to weather warnings
    • Weather timeline now follows system time format
    • General bug fixes
    Phone
    • UI Optimizations
    Download
    System
    • Updated Android security patch to 2019.03
    • Improved lock screen interface
    • Improved sensitivity for screen rotation
    Messages
    • Now able to select contact groups for sending SMS
    Download
    System
    • General bug fixes and improvements
    Clock
    • Fixed lag while setting an alarm
    Phone
    • Improved stability for video calls
    Download
    System
    • Added OnePlus Laboratory
    • Gaming mode enhancement
    • Optimizations for screenshot
    • Support for quick reply in landscape mode, now easier to reply to new messages when watching videos
    Clock
    • Now supports world clock with weather information
    Download
    System
    • Updated Android security patch to 2019.1
    Phone
    • Messages now support landscape mode
    • Deep integration with Google Duo
    Weather
    • Added more search options to improve the accuracy of search results
    • Weather descriptions more accurate
    • Added more unit options for precipitation, visibility, pressure and other data
    • Added more detailed descriptions to weather icons
    Download
    System
    • Improvements for screen brightness control
    • Confirm pin without tapping √ for app locker
    • Improved color adaptation for navigation bar when using third party apps
    • General bug fixes and system stability improvements
    Phone
    • Added the caller identification feature (For India only)
    • Improved UI for Call History
    Gallery
    • Added create a collection, copy and move photos features
    • New illustrations and design on blank pages
    • General Bug fixes and overall experience improvements
    Launcher
    • Added recommended tools in Toolbox
    • Improved UI for category tags in app drawer
    Download
    System
    • Updated Android security patch to 2018.12
    • Added toast message when parallel apps are unavailable due to data corruption
    Phone
    • Added call history for incoming calls from unknown numbers
    • Optimized UI for Spam messages and calls
    OnePlus Switch
    • Now supports migrating data from iPhone
    Download
    System
    • Audio tuner for Type-C and Bluetooth earphones
    • About Phone UI improvements
    Communication
    Launcher
    • Supported dark theme for Dashboard in Shelf
    Camera
    • Improved slow motion
    Download
    System
    • Added Video Enhancer feature
    • Added OnePlus Roaming
    Communication
    • Added vibration when hanging up
    • UI Improvements for emergency rescue
    • Now able to assign a specific SIM for a specific contact or group of contacts when using dual SIM
    Launcher
    • Added User Agreement and Privacy Policy
    • App drawer options under launcher settings
    • General bug fixes and performance improvements
    Note
    • Video EnhancerWhere can I find Video Enhancer?
    • Settings -> Display
    • What is video enhancer?
    • In this mode, the colors are enhanced for a better experience while watching videos.
    • OnePlus Roaming
    • OnePlus Roaming lets you surf the internet without a local SIM card. It's like a virtual sim (only data, no calls); it should work globally in most of the countries/regions, and it will list out the plans available for the country/regions you are in so that you can purchase a suitable plan and access the Internet without a SIM.
    • Where can I find "OnePlus Roaming?
    • Settings -> Wi-Fi & Internet -> OnePlus Roaming
    • How to use OnePlus Roaming?
    • Step1: Purchase Package
    • Select the packet you want and click to buy, then finish the payment.
    • Step2: Enable Package
    • After arriving at the destination, choose the purchased plan from the ordered list and enable it.
    Hinweis in Deutsch: OnePlus-Roaming.
    Dies nennt OnePlus eine SIM-freie Methode, um eine Datenverbindung in einem fremden Land herzustellen. Wählen Sie einfach aus, wohin Sie wollen, und wählen Sie dann einen Plan aus, der Ihren Bedürfnissen entspricht. Was verfügbar ist, hängt davon ab, wohin Sie fahren, aber es ist eine wirklich nette Idee. Beachten Sie, dass Sie keine Anruf- / SMS-Funktionalität erhalten.
    Download
  3. TomTim, 19.11.2018 #3
    TomTim
    Anleitung zurück zu Stock
    Das hier sind meiner Meinung nach die einfachsten Methoden.
    Los geht´s und nochmals zur Erinnerung: Der speicher wird dabei Formatiert und alle Daten werden dabei gelöscht.
    Methode 1 = OS ist gleich auf dem aktuellen stand, setzt aber einen Entsperrten Bootloader voraus.
    1. Datei in einen Ordner entpacken
    2. OnePlus 6 in den Fastboot-Modus navigieren (Power & Volume +)
    3. Telefon und PC verbinden
    4. Im Ordner (punkt 1) die Datei flash-all.bat starten
    5. Warten bis das Installationsprozedere durchgelaufen ist – wenn das Telefon startet ist es soweit.
    Download: Fastbootversion
    Aktuell ist im Moment die OxygenOS 9.0.4
    Alternativ steht noch eine Downgrade Version zur Verfügung. Das System wird dabei zurück von Android Pie 9.0 auf Android Oreo 8.1.0 und OxygenOS 5.1.11 gebracht, was ungefähr Juli 2018 entspricht. Um auf den Aktuellen stand zu kommen muss nun nochmals OTA das aktuelle OS installieren.
    Methode 2 = weitere Installation Erforderlich um den aktuellen stand zu erreichen
    1. Datei auf das Telefon kopieren
    2. Navigiere zu: Einstellungen/Systemupdates/Zahnrad/Lokales Upgrade
    3. Wähle die Downgradedatei aus und und starte die Installation
    Download: Downgradeversion
    OxygenOS 5.1.11
    Ein Link für alle Notfälle: MSMDownloadTool
    CyPress1988 bedankt sich.
  4. AcmE85, 19.11.2018 #4
    AcmE85
    AcmE85 Moderator Team-Mitglied
    CyPress1988, dabistduja, Storky und eine weitere Person haben sich bedankt.
  5. dabistduja, 19.11.2018 #5
    dabistduja
    dabistduja Android-Experte
    @AcmE85: Der erste link geht gut und schnell.
    EDIT: Magisk 17.3 läuft bei mir sauber.
    Bluesforyou und AcmE85 haben sich bedankt.
  6. c@p, 19.11.2018 #6
    c@p
    c@p Android-Lexikon
    Was ist bzw. was kann man sich unter "OnePlus Roaming" vorstellen ?
  7. pleitegeier, 19.11.2018 #7
    pleitegeier
    pleitegeier Android-Ikone
    @c@p
    OnePlus Roaming
    c@p und TomTim haben sich bedankt.
  8. TomTim, 19.11.2018 #8
    TomTim
    Oder anders gesagt: Mit OnePlus Roaming lässt sich in vielen Länder ein Internetzugang (ohne SIM) Kaufen und nutzen.
    PS. Habe im ersten Beitrag eine kurze Erklärung hinzugefügt.
    PPS. Das Telefon lässt sich jetzt auch wieder Ausgeschalten laden.
    derstein98, AcmE85, c@p und eine weitere Person haben sich bedankt.
  9. Piwie, 19.11.2018 #9
    Piwie
    Piwie Android-Hilfe.de Mitglied
  10. TomTim, 19.11.2018 #10
    TomTim
    Ja übersetzt liest es sich so: "Jetzt können Sie eine bestimmte SIM-Karte einem bestimmten Kontakt oder einer Gruppe von Kontakten zuordnen, wenn Sie eine Dual-SIM verwenden."
    Wie dies nun praktisch zugewiesen wird, kann ich nicht nicht verraten. Da ich noch nie 2 SIM Karten genutzt habe.
    Es sollte hier aber den ein oder anderen User geben der da Auskunft geben kann.
    @AcmE85 Die beiden Voll-Versionen haben zwar unterschiedliche Endungen, aber sie weisen Identische MD-5 Prüfsummen auf. Von daher können beide für die Installation genutzt werden.
  11. AcmE85, 19.11.2018 #11
    AcmE85
    Der Video Enhancer ist ziemlich übel.
    Ich habe einige 720P Videos (per YouTube Downloader) auf dem Gerät.
    Diese werden total überschärft (Treppchenbildung bei Logos).
    Edit: auch auf YouTube. Was da genau passiert kann man nachvollziehen wenn man die Auflösung in YouTube testweise verringert.
    Es wird geglättet und nachgeschschärft. Die Entwicklungszeit hätten sie auch in andere Dinge stecken können.
  12. Storky, 19.11.2018 #12
    Storky
    Storky Android-Hilfe.de Mitglied
    In der Kontakte App hat man beim Kontakt im Kontext Menü die Auswahl. Da kann man da die Sim auswählen.
    malteknalte, Piwie, TomTim und eine weitere Person haben sich bedankt.
  13. bandit1976, 19.11.2018 #13
    bandit1976
    bandit1976 Foren-Inventar
    Vowifi und Volte bleiben beim Update erhalten.
    AcmE85 bedankt sich.
  14. Piwie, 19.11.2018 #14
    Piwie
    Super, Danke!
  15. AcmE85, 19.11.2018 #15
    AcmE85
    @bandit1976 Stimmt, war bei mir auch.
  16. derstein98, 19.11.2018 #16
    derstein98
    derstein98 Moderator Team-Mitglied
    In welcher VErsion wurde das denn ausgeschaltet und vor allem warum?
  17. habehandy, 19.11.2018 #17
    habehandy
    habehandy Junior Mitglied
    Die Preise des oneplus Roaming sind z.T. recht gut. Interessant wäre jetzt zu wissen in welchen Land der APN steht. ( Zensur) China (exklusiv Hongkong) würde die Nutzbarkeit (u.a. keine Google Dienste wie maps) einschränken.
    Japan 4GB/8 Tage 19€, 1GB/10 Tage 9,20€
    Indien (lokale SIM quasi unmöglich) 4GB/8 Tage 19€
    Asia Pazifik 14 (Hongkong, Macao, Taiwan, Malaysia, Philippinen, Singapur, Laos, Australien, Kambodscha, Japan, Indien, Südkorea, Nepal, Myanmar) 4GB/8 Tage 19€.
    In vielen Ländern gibt es für 19€ ein 4GB Paket mit unterschiedlicher Laufzeit. Einige problematische Länder ( z.B. Kuba) sind leider nicht dabei.
  18. TomTim, 20.11.2018 #18
    TomTim
    @derstein98 Seit wann genau kann ich nicht sagen, aber bislang wurde magisk als Verursacher verdächtigt. Beim OnePlus 6T besteht das "Problem" noch.
  19. derstein98, 20.11.2018 #19
    derstein98
    also betrifft das nur die gerooteten Handys?
  20. AcmE85, 20.11.2018 #20
    AcmE85
    @derstein98 Ja.
    Wobei das scheinbar auch nicht ganz korrekt war.
    Nach einiger Aussagen wurde das OP6 mit Root trotz diesem Bug sehr wohl geladen, jedoch wurde permanent
    der Hinweis des entsperrten Bootloaders eingeblendet. Burn-in Gefahr!
    Mit Beta 7 wird aber wieder der Akkustand eingeblendet und das Display schaltet sich nach kurzer Zeit aus.
    TomTim bedankt sich.
Die Seite wird geladen...
Ähnliche Themen Forum Datum
[Firmware][9.0] OxygenOS 9.0.4[Pie] Original-Firmwares für OnePlus 6 01.11.2018
[Firmware][9.0] OxygenOS Open Beta 6 [Pie] Original-Firmwares für OnePlus 6 30.10.2018
[Firmware][9.0] OxygenOS Open Beta 5 [Pie] Original-Firmwares für OnePlus 6 20.10.2018
[Firmware][9.0] OxygenOS 9.0.1[Pie] Original-Firmwares für OnePlus 6 16.10.2018
[Firmware][9.0] OxygenOS Open Beta 4 [Pie] Original-Firmwares für OnePlus 6 29.09.2018
[Firmware][9.0] OxygenOS 9.0 [Pie] Original-Firmwares für OnePlus 6 21.09.2018
[Firmware][9.0] OxygenOS Open Beta 3 [Pie] Original-Firmwares für OnePlus 6 15.09.2018
[Firmware][9.0] OxygenOS Open Beta 2 [Pie] Original-Firmwares für OnePlus 6 09.09.2018
[Firmware][9.0] OxygenOS Open Beta 1 [Pie] Original-Firmwares für OnePlus 6 03.09.2018
[Firmware][8.1.0] OxygenOS 5.1.11 [Oreo] Original-Firmwares für OnePlus 6 15.08.2018
Du betrachtest das Thema "[Firmware][9.0] OxygenOS Open Beta 16 [Pie]" im Forum "Original-Firmwares für OnePlus 6",
  1. Android-Hilfe.de verwendet Cookies um Inhalte zu personalisieren und dir den bestmöglichen Service zu gewährleisten. Wenn du auf der Seite weitersurfst stimmst du der Cookie-Nutzung zu.  Ich stimme zu.
