morpheus620
Android-Guru
- 2.479
Nächste Woche ist Release von Android 10.
Anmerkung: Diese Funktion erfordert derzeit den Zugriff auf die Seite über den integrierten Safari-Browser.
bandit1976 schrieb:Langsam wird es ja, die Woche soll wohl noch die erste Beta kommen.
[Official ROM] Android 10 Beta For OnePlus 7/7 Pro (developer preview version fifth edition)
Landlord Hydrogen OS
****important****
Android 10 Beta is an early adopter version, we recommend developers to adopt early adopters, but it is not recommended for ordinary users to brush this version, thank you.
【update content】
1. Improve system fluency and stability
2. Add one plus full screen gesture
3. H2OS based on Google Android 10 Beta6
4. Developer Preview version 4 users can upgrade to this version via OTA
[known issues]
1. Application compatibility issues
2. Low probability stability issues
3. Low probability Caton problem
[brush tutorial]
One: From the OnePlus 7 /7 Pro P stable version or Android 10 developer preview first / second / third version brush to Android 10 Developer Preview fifth version tutorial:
Note: To avoid data loss, be sure to back up before upgrading.
1. Download the latest ROM upgrade archive from the specified server.
2. Copy the ROM upgrade archive to the phone storage.
3. Settings -> System Upgrade -> Top right icon -> Local upgrade -> Click the corresponding installation package -> Upgrade now -> System upgrade is completed to 100%
4. Select Restart (or press the power button to restart)
5. Enter recovery mode to format the data, it will be restarted after formatting (stable version and Android 10 developer preview third / fourth without this step)
6. Successfully upgraded the Android 10 Beta version
Two: Brush back to Android P stable version tutorial from OnePlus 7 /7 Pro Android 10 version:
Note: This upgrade method will erase all the contents of the phone, please be sure to backup first
1. Download the downgrade package from the specified download address on your mobile phone.
2. Copy to the root directory (if you download directly to the root directory, please ignore this step)
3. Settings -> System Upgrade -> Top right icon -> Local upgrade -> Click on the corresponding installation package -> Upgrade now -> System upgrade is completed to 100%
4. Choose to restart
5. Enter recovery mode to format the data, will be restarted after formatting
6. Successful upgrade
