HexagonRom Nougat 7.1.2
siegie65
siegie65
Stammgast
401
Hier ist eine interessante neue Rom [ROM][7.1.2][LE MAX2][UNOFFICIAL] HexagonRom Nougat basierend auf Los14 mit jede Menge Einstellungen.
https%3A%2F%2Fimg.xda-cdn.com%2FAYFiEdhykGLbpeXROeF2RfC5dfI%3D%2Fhttp%253A%252F%252Fi.imgur.com%252FmH1nSBj.jpg
Code:
Very changeds for Hexagon
Design Hexagon
System extensions:
-App side bar
-App circle bar
-Pie Control
-System App Remover
Statusbar:
-Superuser indicator on/off
-Show 4G instead of LTE
-Battery bar
-Traffic indicators
-Carrier label
-Ticker
-Hexagon logo
Notification Drawer:
-Custom header image
-Header provider
-Header image pack
-Header image shadow
-Running shortcut
-Running services icon
-Edit icon
Blur UI:
-Blur statusbar background
-Blur scale
-Blur radius
-Translucent expanded statusbar
-Translucent level
-Blur recents background
-Colors
Advanced:
-Show settings
-Shutdown confirmation dialog
-Launch music app
-Camera shutter sound
-Disable immersive mode messages
-Disable FC notifications
-Swipe to screenshot
-Screenshot sound
-Screenshot type
-Screenshot delay
-Device hostname
-Scrolling cache
-Lockclock settings
Lock Screen:
-Colors
-Torch on power button longpress
-Double-tap-to-sleep
-Power Menu
-Quick settings disable on lock screen
-Hide statusbar
-Show alarms text
-Show clock, date and AM/PM
-Batery infor
-Colors
Recents panel:
-Show memory bar
-Immersive recents
-Hidden apps
-OmniSwitch recents
-Slimrecents
-Hexagon recents
Display and Animations:
-Power menu animations styles
-Quick settings animations styles
-Toast animations styles
-Animations duration
-Animation interpolator
-Toast icon
-Toast icon colors
Quick settings:
-Tiles customs
-Smalls tiles
-Rows portrait and landscape
-Columns portraits and landscape
Transparency:
-Volume dialog
-Power menu
-QS shade opacity
-QS shade stroke
Headsup notifications:
-Enable headsup notifications
-Time out
-Snooze timer
Einige Einstellungen fehlen noch .
Für mich die derzeit beste Android 7 Rom bis auf Volte welches beim nächsten update kommen soll und IR geht alles selbst Kamera und Video in FullHD . Ich nutze Snap Kamera mit c2api und habe keine Probleme nur 4K Videos gehen nicht Antutu ist bei 115000 nicht so doll aber im betrieb merke ich nichts davon .
Reaktionen: Kiwi++Soft
Läuft soweit sehr gut, nur leider geht der FP nicht.. Hoffe mal da kommt noch ein Update
Bei mir funktioniert er , nicht zu 100% von 10 versuchen klappt es ca. 8 mal.
Musstest Du auf F2FS umformatieren, um das Rom zum Laufen zu bekommen?
Habe erst Daten ,System und Cache auf f2fs formatiert bei der Installation konnte die Cache Partition nicht gefunden werden habe dann zurück auf ext4 formatiert dann gings .
Wenn man nur System auf f2fs formatiert geht es vielleicht.
siegie65 schrieb:
...habe dann zurück auf ext4 formatiert dann gings .
Hast Du dann alles wieder auf ext4 formatiert, oder nur die cache-Partition?
Ich würde am liebsten auf das umformatieren ganz verzichten, und alles auf ext4 lassen. Sollte das funktionieren?
Hab alles auf ext4 . Um formatieren ist kein muss , hab es versucht weil das f2fs Format schneller sein soll .
Super! Danke für die Infos :thumbup:
Bei mir leider nicht... Immer wenn ich ihn einrichten will stürzt es ab.. Hast vielleicht eine Idee war?
Beim einrichten musst du ja erst eine zahl eingeben und wiederholen dann kommt die Meldung Sensor suchen nicht auf den Sensor tippen sondern sofort auf weiter dann erst den Finger scannen lassen .
Reaktionen: djnik
Super.. Viel Dank.. Es funktioniert..
Habs anfangs auch falsch gemacht irritiert etwas mit der Sensor suche
@siegie65: Kannst du mal eine Anleitung geben für das Flashen der Hexagon ROM (vom rooten bis zum aufspielen der Custom ROM). Funktioniert bei dieser ROM die Kamera ordentlich?
Am einfachsten ist es dieses tool runter zu laden All in One Tool Le Max 2 und am PC zu starten , dann schließt du das LeMax 2 an den PC . Dieses Tool installiert die Treiber entsperrt den Bootloader falls noch nicht geschehen und installiert das Recovery . Wenn du soweit bist startest du das LeMax 2 in den Recovery Modus , Lautstärke plus und Power dann musst du deine jetzige Rom sichern und auf einem PC sichern . Gehe nun im Recovery auf löschen , erweitert und wähle alles an ausser USB , zurück zum Start Bildschirm unten auf Neustart und das Handy Ausschalten . Handy wieder in den Recovery Modus starten ( es gibt eine Option die das Handy automatisch in den Recovery Modus starten soll diese geht bei mir aber nicht ) . Dann brauchst du nur noch die HexagonRom HexagonROM-V2.4-20170423-OFFICIAL-x2.zip und die Gapps The Open GApps Project Arm 64 Android 7.1 ich nutze Pico , aufs Handy kopieren auf installieren die Rom anwählen und auf mehr ZIP Dateien die gapps anwählen und unten den Schieber nach rechts . Handy neu starten und einrichten Root ist schon vorhanden . Als Kamera nutze ich die Snapcamera kannst aber auch Google nehmen die original Leeco ist etwas tricky . Bilder und Videos sind sehr gut kaum focus Probleme .
P.S. ich nutze jetzt die ResurrectionRemix ist nach meinem empfinden noch besser Antutu 152000 und IR geht auch . Die kannst du hier finden [6.0.1][7.1.2][OFFICIAL] Resurrection Remix for LeMax 2 Official . ROM:[x82X][7.1.2] ResurrectionRemix-N-v5.8.3 OFFICIAL
Reaktionen: gamekiller und derkobi
@siegie65: Danke für deine ausführliche Anleitung. Ist es bei der ResurrectionRemix ROM der Installationsweg wie bei Hexagon?
Ja alles gleich egal welche Rom du nimmst bei der Resurrection kannst du noch die angegebene Viper FX und die LeTvRemote Datei runter laden . Ich habe erst die Rom und Gapos installiert das Handy gestartet und eingerichtet danach in Recovery neu gestartet und die Viper FX sowie die Remote APP im Recovery geflasht und alles läuft .
Hier bekommst du das neueste update von Heute RR-N-v5.8.3-20170504-x2-Official.zip
Reaktionen: derkobi
Danke. Was oder für was ist die Viper FX Datei und brauche ich die LeTvRemote Datei?
Viper FX ist eine sound Optimierung und Le TV Remote ist für die IR Fernbedienung wenn du diese nicht nutzt brauchst du diese Datei nicht.
Reaktionen: derkobi
wori
  • wori
wori
wori
  • Maddog30
JoergHH
JoergHH
Mikehop
Mikehop
Mikehop
