[ROM] AOSP V3 für das X620 mit Stock Kamera
  • 6 Antworten
  • Neuester Beitrag
Diskutiere [ROM] AOSP V3 für das X620 mit Stock Kamera im Root / Custom-ROMs / Modding für LeEco Le2 Pro (X620) im Bereich LeEco Le 2 Pro (X620/X52x) Forum.
kingoftf
kingoftf
Ehrenmitglied
Hier ein neues ROM vom chinesischen Dev Wazl
Basis ist AOSP 6.0
http://bbs.ydss.cn/forum.php?mod=viewthread&tid=995684&extra=page=1&filter=typeid&typeid=3357
[MTK X20 ROM] [AOSPV3] Andrews 6.0 core xposed floating ball double row speed | shaking lock screen sliding brightness | IOS animation fingerprint infrared
Features laut Goggle:
ROM introduction
  • Thanks to the big bottom package
  • Team exclusive transplant production, prohibited reference extraction!
  • Two desktop styles
  • The feedback on the oil is updated as follows:
  • Increase the temperature of the forced shutdown of the phone
  • Double line speed display
  • The flashlight can be set to advanced settings
  • Modify the key vibration logic
  • Optimize the fingerprint code
    Optimize the camera, I test everything is normal, if there is Caton, clear the background can be
    Optimize remote controller initialization failure
    MZ suspension ball, pull down more convenient
    IOS animation
  • Advanced settings update
  • Mainly maintain official stability
  • Promotions can be uninstalled by the re manager
  • After testing, ROOT authority is normal
  • Percentage of electricity displayed
  • Dolby
  • Freeze unloading
  • CPU content
    • Advanced settings are implemented using code, not bundled with a large number of apk
    • Dat format brush machine, better authority
    • Pull down the lunar display
    • Optimize init.d permissions
    • Integrated busybox instruction set
    Past Update: - Advanced settings, misappropriation!
    • Screen assistant
    • Strong unloading
    • Power menu
    • CPU parameter settings, control of heat, manual control core
    • Go directly to the developer option
    • Time to stay in the next period to add
    • Self-opening management
    • Status bar advanced settings
    • Slide brightness adjustment
    • Shake set
    • Please click on the specific function
  • It is so simple, brush into the experience
___________________________________________________________________________
【note】
1. Brush before, please back up your own Nvram partition, no matter what package you brush, brush who package!
3. Built a small amount of promotional software, do not need to uninstall, can not accept the promotion of the other brush! The
Other optimization:
Developers / off animation & open Gpu rendering & background process limit no more than 4
I repair bugs, are driven one by one investigation, spend a lot of time with the energy, apply the party please specify! Otherwise found by the depth of investigation
Download Link
MEGA
feuerossi
feuerossi
Bin nach vielen Roms mal hier gelandet. Erster Eindruck scheint ok zu sein.
Installiere gerade alle meine Apps
feuerossi
feuerossi
Sieht sehr gut aus. Bluetooth , dass Sorgenkind der Rom, funktioniert sehr gut. Alle Apps laufen, ausser
Google Notizen. Da habe ich aber bei mehreren Roms Probleme.
Sicherheitspatch vom 01.01.2017.
Mit gekaufter App Snap Cam 21 Megapixel bei Kamera
Fingerprint ok
Xposed läuft auch
Werde die Rom mal länger testen.
feuerossi
feuerossi
kingoftf schrieb:
Ich bekomm immer Error 7 beim Flashen, trotz TWRP 3.1.1
Das ist der Fehler. Musst TWRP 3.0.2.0 nehmen. Mit der 3.1.1 hatte ich auch den Fehler
kingoftf
kingoftf
Ehrenmitglied
Ok, hatte mich vertan, bezog sich auf die AOSP V4, die auch erhältlich ist, die V3 lief ohne Probleme.
-- Dieser Beitrag wurde automatisch mit dem folgenden Beitrag zusammengeführt --
Einzig Snapseed ging nicht, deshalb wieder runtergeschmissen.
feuerossi
feuerossi
Was noch nicht richtig geht, ist die Flat Style Bar für Xposed. Lässt sich zwar installieren, aber die Benutzeroberfläche geht nicht.
naja, Spielerei :)
feuerossi
feuerossi
Schade schade, Bluetooth speichert die Geräte nicht. Man muss jedesmal nach Trennung neues Paring durchführen. Sonst eine echt tolle rom.
