[ROM]MTK X20 [01.12] für das X620 Version 21s
  • 1 Antworten
kingoftf
kingoftf
Ehrenmitglied
56.413
Hier ein neues ROM von der bekannten Entwicklerin "1175680614“, die schon etliche sehr gute ROM herausgebracht hat.
Es handelt sich um die erste Version mit Nummer 21s, Sicherheitspatch nun endlich zeitnah von Dezember.
Ein Wunder, lobpreiset den Herren :biggrin:
Google Übersetzer
【01.12】乐2-21S内测第一版|新语音助手|状态栏自定义|蝰蛇音效|DPI|稳定流畅_官方刷机包_ROM下载_刷新教程_最新最全的安卓系统下载_乐2/乐2 Pro论坛_移动叔叔 - 手机版
Thread im Leeco Forum:
【01.12】 Le 2-21S closed beta first edition | new voice assistant | status bar custom | Viper sound | DPI | stable and smooth
Als weitere Features laut Google Übersetzer:
21S update instructions:
The official did not release the update log.
Own experience.
Dial optimization
Suspended Ball Optimization
Add the latest voice assistant (can speak oh)
Keep live, you can enter the video from the live video
Upgrade the theme store to the latest version and fix the search function
Hide my music, can be entered from the settings inside
Hide my wallet
Other small updates and so on. Own experience
【Theme Store】
Theme fonts are free to use
(Usage: Click the trial option, then enter the settings - unloading and freeze frozen theme store, you can achieve long-term trial.)
Retains the weather, application store (App Store required in system / app / LetvStore inside the LetvStore.apk.bak to LetvStore.apk restart it)
Remove the headlines from the desktop and enjoy it
Retention preference backup, for some users to restore the software data
The Net Speed Display (Steward - Flow Control - Flow Settings) is on
【Settings】 interface to increase and music toolbox and freezer, intelligent recording screen
Hosts block some ads
Modify the desktop Live button to lock the screen
Increase the RE Manager (well uninstall the built-in software)
Streamline the official a large number of useless software and resources, more memory more power
Preservation of music video, music, search, search, compass, remote control, butler and other practical tools
Built-in software, do not need to be in the settings in the freeze or uninstall delete, restart (hope to help activate and then delete Oh)
Power saving tips:
Close a variety of software since Kai, delete some useless built-in software, do not install too many XP plug-ins, can not tick the best not to activate, so much power
Developers option / the animation zoom off, so more fluid
CPU core settings and freezer! LAY team from @ Lengyu Ye Great God, without permission is prohibited steal, otherwise bestowed processing!
● Support xposed framework component custom installation or uninstallation
● support xposed frame (module must artifact)
● frame module: Open Music Toolbox → xposed framework → module, in which those modules tick restart on the line
● Support for freezer rooms (which can freeze or unload any unwanted applications)
● Support Wifi password view (you can view the connected WIFI password)
● support for memory release (after the release of large memory, 4G can be left 3G, 3G can be left 2G)
● Music Toolbox increased performance monitoring
● Added Turbo download
● Add a custom modification of the DPI value
● Add a flash of incoming calls (turned on by default, can be turned off in Settings - Accessibility)
● Support Viper Sound
● support cpu core functions, can be free to open nuclear
● Support advanced power, restart to Brush mode
● Customize the status bar
● Add shortcut entry to project mode
Installation wie immer über Recovery, ich nehme mal an, wegen der neuen Basis, sicherlich besser mit Fullwipe.
Gapps wie immer bei den China ROM nicht enthalten, per Google Installer V2 installieren.
Download über Leeco.re noch nicht erhältlich, ich lade das gerade mit Schneckentempo von den Chinesischen Servern....
Download
MEGA
Screenshots:
Es gibt ein Update vom 13-12, einziger Unterschied ist aber anscheinend, dass die Chinesischen Einstellungen für CPU und so weiter in der neuen nicht mehr zu finden sind und nun ein "Update-Checker" dazugekommen ist, mit dem man wohl OTA Updates suchen kann.
MEGA
