[ROM][MTK X20 ROM] "MI9. Poland-X620" very smooth large transport open nuclear frequency international lightning version of the many custom most comfortable MIUI
  • 4 Antworten
kingoftf
kingoftf
Ehrenmitglied
56.562
Hier endlich mal wieder eine internationale Version von MIUI, sprich Multi Sprachen.
Chinesischer Thread;
《MI9.波兰-X620》极顺滑 大运存 开核开频 _最新最全的乐2/乐2 ProROM刷机包下载、刷
Thread auf Leeco.re:
[ROM MTK X20] [Brush Pack] "MI9. Poland-X620" Gran Canal Suave Guardar Frecuencia Nuclear International Lightning Edition Personalizado MIUI más cómodo
Sicherheitspatch ist vom 5. September.
Beide Kameras (MIUI und LE-Stock) an Bord.
Features laut Google Übersetzer:
  • MIUI9 latest development board
  • Keep more powerful
  • Update the bottom
  • Fingerprint Infrared
  • apk optimized
  • Lightly streamlined, ultra-stable experience
  • Shipped large
  • Do not kill the background
  • No advertising
  • Various optimization
  • Deep freeze
  • Advanced settings important function code implementation, non-apk power consumption stacking. Add only utility
  • Play the king glory, open the nuclear full! Overall frame rate is smooth, running smoothly! Self-feeling is still possible
  • Do not want to introduce more, introduced more than a brush!
  • Basic sound quality has been added
  • Support init.d
  • Themes, permissions have been cracked
  • This package has done a relatively partial streamlining, not your intended, do not brush
  • Advanced settings New version:
  • Add a variety of features
  • Power menu
  • Suspension Assistant
  • DPI settings
  • WIFI view
  • CPU core control
  • Time to switch
  • Animation switch
  • Desktop layout switch
  • Time lunar calendar and so on
  • team
  • Other etc
Download:
MEGA
Gapps mit dieser Zip über TWRP flashen, sonst funktioniert die Le-Stock Kamera nicht mehr.
[NEW] ULTRA SLIM MIUI MOD V1.3 (Google Play Installer, Bloatware Remover, LeEco Stock Camera Added)
UltraSlimMIUIMod_1.3.zip
Funktioniert bei mir nicht, keine Mobile Daten
3x installiert, nix zu machen, SIM wird erkannt mit richtigem Provider, aber keine Chance auf Mobile Daten-Verbindung. alles versucht, Neustart, Deaktivierung von WLAN usw.
@kingoftf
Weißt du ob die Custom Roms für das X620 auch beim X626 passen ?
Das X626 hat ja auch den MTK 20 Chipsatz oder ?
Sollten funktionieren laut Leeco.re
@kingoftf
Danke für die Antwort.
