			kingoftf
Ehrenmitglied
- 56.573
Hier noch eine weitere Beta der neuen ROM Stock 26s, diesmal vom Dev Wazl, dem Entwickler der tollen MIUI mit Stock-Kamera.
Läuft auf meinem X620 wesentlich flotter als das andere schon vorgestellte ROM, zumindest laut Messung bei Antutu
ROM ist nur in Englisch / Chinesisch, die Apps können aber zumindest eingedeutscht werden mit Morelocale aus dem Shop.
Gapps sind ebenfalls nicht mit an Bord und müssen mit Google Installer eingerichtet werden.
Thread auf Leeco.re:
[MTK X20 ROM] [EUI] 26S latest official test - the new feeling CPU-DIY shaking slippery brightness time is not only broken DPI smooth and durable
Features:
Download:
MEGA
Features:
- Boot directly skip! Directly into the desktop
- Support xposed
- Mainly maintain official stability
- Desktop can choose drawer type
- Desktop can choose other desktops
- Update root2.79
- Dolby Skills: Settings / Sound or Advanced Settings inside {Do not choose game mode - only music as 1S}
- Promotions can be uninstalled by the re manager
- After testing, ROOT authority is normal
- Time-centered selection of three-stage non-modular
- UI landscaping device
- Strengthen the freeze unloading
- Strengthen the CPU content, make it more abundant - Definition switch
- other
 - Add the latest version of Viper sound effects
 - Integrated xposed
- Advanced settings are moved to the settings
- Increase the status bar to switch items
- Advanced settings are implemented using code, not bundled with a large number of apk
- Dat format brush machine, better authority
- Pull down the lunar display
- Optimize init.d permissions
- Integrated busybox instruction set
 To update [if not, then deleted]:- Add goggles
- Add mandatory self-management, ROOT authority to implement, can effectively prevent some boot program
- Shake the custom
- Status bar advanced settings
- Slide the status bar to adjust the brightness
- A key lock screen
- Added live advanced settings to replace
- Supersu authorization
 - Screen assistant
- Strong unloading
- Power menu
- Goggles
- Application hides
- Green guardian
- CPU parameter settings, control of heat, manual control core
- Go directly to the developer option
- Time to stay in the cut
- Desktop LIVE Toggle: Brightness / Lock Screen / Original / Advanced Settings
- Self-opening management
- Slide brightness adjustment
- Shake set
- Please click on the specific function
- It is so simple, brush into the experience
- Yellow box Cancel method: Turn off USB debugging
Download:
MEGA
