[ROM] X620 26s beta 2 Stock Chinesisch /Englisch
  • 7 Antworten
kingoftf
kingoftf
Ehrenmitglied
56.592
Hier die scheinbar erste Beta 2 der 26s Stock ROM.
Wie immer nur Chinesisch / Englisch, keine weiteren Sprachen.
Gapps fehlen ebenso, müssen mit Google Installer nachträglich installiert werden.
Sicherheitspatch ist brandaktuell vom 9. Mai 2017, ein Wunder bei der Stock ROM, die bisher immer stark hinterher hinkte.
Thread auf Leeco.re:
[10.5][X620] EUI 26s beta2
Original Thread auf Uncle Mobile
乐视2+Pro EUI 026s beta2|下拉农历|CPU调_最新最全的乐2/乐2 ProROM刷机包下载、刷 - 手机版
Features laut Google Übersetzer:
Optimization: built-in Supersu2.79, double after no longer lost
Optimization: crack system signature verification mechanism
Optimization: Streamlining useless applications and video files in the system
Added: self-compiled multi-function advanced settings
Added: pull down the lantern display switch, the default open
Added: lock screen lantern display switch, the default open
Added: lunar calendar support shows festivals, as well as custom lunar display format
Added: custom lock screen text customization
Added: status bar time display switch
Added: status bar time refinement function
Added: status bar week show
Added: linear power switch to support display charging animation, as well as custom power strip width and color, default green
Added: Flash function, support for custom flash frequency
Added: SMS flash function, support for custom flash frequency
Added: font switching function, several fonts at will
Add the following functions: start the specified software | open the file / Off wifi | background tasks.
Added: Lock screen auto-clean memory function
Added: lock screen cleanup time custom, default lock screen after 5 minutes
Added: a key to install uninstall XPosed framework function, the installation will automatically restart into the recovery to complete the installation
Added: eye protection mode, adjustable eye color and eye protection, add eight eye protection mode
Added: view the WIFI hot password, support the password has been registered hot check, click the option to copy the hot or password
Added: DPI density value custom, defaults to 480, support for customization
Added: CPU lock function, you can turn off the CPU core
Added: CPU frequency adjustment, support to modify the cpu frequency and FM strategy
Added: GPU frequency adjustment, support for modifying gpu frequency and FM strategy
Added: CPU dynamic core, support to view the current state of the CPU
Added: a key Brush function, support independent choice double clear or not double brush into ROM or patch package
Added: New application freeze
● 【Description】 love life is an attitude, brush machine is an experience
● 【Added】 Added in the advanced settings will always show "developer options", do not need to trouble in the version number with 5 times to display
● 【New】 Added advanced settings to view system information
● 【New】 Added advanced setting device model
● [Added] Added advanced settings for Android
● 【Added】 Added advanced system version number
● 【Added】 Added to the advanced settings Rom author
● 【Added】 Added advanced settings Advanced settings date
● 【Added】 joined the advanced settings contact author.
Download
MEGA
Installation wie immer, wenn von Stock 26 Beta 1 kommend, reicht Wipe Cache Dalvik, ansonsten Fullwipe.
Also das ROM runterladen und aufs X620 schaufeln, reboot in Recovery, Fullwipe (Data System Dalvik Cache) und ROM flashen.
Nach der Ersteinrichtung die gapps mit Google Installer installieren.
Flashen wie immer auf eigene Gefahr......
Bullshit, Sicherheitspatch ist vom 5. Januar wie auch bei der vorherigen Beta 1 :thumbdn:
Oder die hier, leicht modifiziert, schon mit Google Playstore und ohne China Bloatware:
MEGA
Also mit der leicht modifizierten Version habe ich Probleme. Gapps laufen nicht richtig, immer wieder Fehlermeldungen.
Ich warte bis die Version direkt zum download bereit steht
Gmx und web.de apps gehen auch nicht. Da hat er wohl zu viel an chinesischen apps gelöscht:cool2:
Ich bin wieder zurück zur Purple 23s, bisher nix besseres gefunden als die, sensationelle Akkulaufzeit, alles funktioniert. die 26s, die ich bisher getestet habe, haben alle noch ein paar Bugs, bei der letzten, in London geflasht, bekam ich keine Mobile Verbindung.
Die MIUI kann man leider momentan alle vergessen, alle mit dem 4% Bug beim Google Installer und opengapps funktionieren auch nicht.
Leider sind auf Leeco.re zwei der wichtigsten User weg vom 2Pro und haben nun andere Smartphones von Leeco, außer Gabi kann uns da keiner mehr mit schnellen Mega-Links versorgen.
