[ROM] X620 AOSP Verion 6.0 mit "neuer Kamera"
  • 0 Antworten
  • Neuester Beitrag
Diskutiere [ROM] X620 AOSP Verion 6.0 mit "neuer Kamera" im Root / Custom-ROMs / Modding für LeEco Le2 Pro (X620) im Bereich LeEco Le 2 Pro (X620/X52x) Forum.
kingoftf
kingoftf
Ehrenmitglied
Hier ein ROM von "NKLL" aus dem Mobile Uncle Forum, laut Google Übersetzer mit "neuer Kamera".
Features:
System Features
  • I used recRP TWRP3.1 can be brushed in theory sometimes Baidu cloud easily collapse, please download once!
  • Cofface adaptation based on the transplant production
  • New camera
  • New baseband
  • more stable
  • Special thanks to XJ God
  • Support fingerprint infrared
  • Optimize the signal
  • Support HD HD
  • Status bar drop-down picture
  • Battery mass icon
  • Added CPU real-time monitoring
  • New CPU core / power saving / smooth / full mode
  • Part of the bug will continue to follow up the follow-up
  • King of glory mode, the principle is to modify the model for the OPPO R11 to deceive the king of glory to open high-Zhen mode
  • Add multi-purpose goggles program to customize RGB values, remove ads and contact permissions
  • Advanced Settings will always display "Developer Options", you do not need to click 5 in the version number
  • Add root privileges lost tips, if the dual-root privileges lost after entering the system will have installation prompts.
  • Long press the virtual key in the status bar, short press to add the function of "pop-up program list let users select and run"
  • Add more customization for shaky phones
  • Added the left side of the status bar virtual key (the default is hidden unavailable), the virtual key long press, short press function can be customized, the default short press for the lock screen, long press for the screenshot, a variety of optional
  • Add the right side of the status bar virtual key (the default is hidden unavailable), the virtual key long press, short press feature can be customized, the default short press for the lock screen, long press the shutdown menu, a variety of optional features
  • Add phone shake custom function, the function is off by default
  • Add "Advanced Settings" program to freeze system functions
  • Because Xposed is a powerful and not stable tool, is the culprit caused by cell phone fever, so please choose to use
  • Add CPU performance control, you can set the CPU maximum and minimum frequency
  • Added DPI display density switching function
  • Added advanced restart menu, can be used in advanced settings
  • Use the standard SuperSU as a licensing management tool
  • Add system signature crack function
  • Removal of external SD card write restrictions (if the system models support external SD card)
  • Added ZTE screen assistant
  • Added a very useful WiFi password viewer, in the "Advanced Settings" open
  • Added mandatory RE manager
  • Full ROOT privileges, using standard SuperSU as a licensing tool
【NKLL】原生AOSP.8.2.14|Xposed|摇晃|新年_最新最全的乐2/乐2 ProROM刷机包下载、刷
Screeshots auf der Seite zeigen absolut nix, das erspare ich mir dann mal.
Download über Mega:
MEGA
Da ich selbst kein X620 mehr habe, kann ich das ROM nicht ausprobieren.
Wer wagt, der gewinnt. :biggrin:
Installation wie immer:
ROM downloaden aufs Leeco, Reboot in Recovery TWRP
Fullwipe ohne (!) Internen Speicher
ROM flashen
Eventuell kann es, wie üblich bei einigen ROM zu einer Fehlermeldung kommen, "kein BS installiert, wollen sie wirklich einen Reboot machen?"
Dann noch mal ins Recovery booten und das ROM OHNE Wipes erneut flashen, dann sollte es eigentlich flutschen
