HenkerLenker
Dauergast
Bravia Engine v4 - X-Reality Engine v4
This rom is the product of 5.1.x Lollipop Linux 3.10.x STOCK Testing 1 2016-01-07 2015-12-21 2016-01-07
Code:
#include
* Your warranty is now void.
* I am not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at me for messing up your device, I will laugh at you.
The Sony Mobile BRAVIA Engine 4 is a video enhancement program for Sony phones. It uses filters and algorithms to create a clearer and more contrasted picture and an overall smoother experience. This is perfect for the huge HD screen but can be a little to saturated for people like photographers who want to see how the photo looks exactly with out any enhancements. The change is not huge but is definitely noticeable if two devices are compared.
Code:
××××××××××××××01/08 [V1.5]××××××××××××××
××-FIXED FONTS
××FIXED GRAPHICS GLITCH
××ADDED GPU MOD TO LIBS
××××××××××××××01/07 [1st]××××××××××××××
×××INIT.D SUPPORT ON LOCKED BOOTLOADER(SCRIPTS THAT RUN AT BOOT]
×××LATEST BUSYBOX INSTALL PLUS BATTERY SAVER INSIDE XBIN
×××15+ FONTS
×××REMOVED SPRINT BLOAT...EVEN HANDS-FREE POP-UP[NEXT-TIME]
×××V10 APPS AND BUILD.PROP MODS
×××HIGHER VIDEO RECORDING BIT 60 FPS
×××SELINUX SET TO PERMISSIVE FOR FULL ANDROID CONTROL
×××USERS MOD FROM CM
×××TEXT-A-LINK FROM G PRO 2
×××UNLOCKED FULL 60 FPS MOD
×××NEWEST GOOGLE EMOJI...
××××I HAVE MORE COMING...AM JUST NOT TRYNA BRICK AGAIN...SO PLS BARE WITH ME....××××××
[CENTER]
IF YOU HAVE TROUBLE WITH CALLERS HEARING YOU ....
[A]------- Settings > Call (under Networks) > activate Noise Suppression
-------- Go to GOOGLE SEARCH >google card settings -> Voice -> "Ok Google" detection
Turn off "From Any Screen"
:::::::::STOCK-LOLLIPOP FLEX 2 [1ST]:::::::
-----------------------[FLASHING STEPS----VIA FLASHFIRE APP]---------------------------------------------------
[1]--DOWNLOAD FLASHFIRE & INSTALL
[2]--MAKE SURE YOUR CURRENT SYSTEM IS BACK-UP TO INTERNAL STORAGE [SYSTEM.IMG]
[3]--DOWNLOAD G-FLEX2-MODS-V1 FROM DOWNLOADS OR HERE
[4]--AFTER FLASHFIRE REBOOTS CHECK INTERNAL STORAGE FOR THESE {Everything-Wrkn.txt}{Cleaner.txt}...
BOUNTYMAN334!!
XDA
evDB Information
DOWNLOAD:
[XDA]:::[LS996]:::::FLASH-ABLE MODS V1.5 STOCK-LOLLIPOP FLEX 2 -----------------------[FLASHING STEPS----VIA FLASHFIRE APP]---------------------------------------------------
BOUNTYMAN334!!
XDA
DOWNLOAD:
[MEGA]:::[LS996]:::::FLASH-ABLE MODS V1.5 STOCK-LOLLIPOP FLEX 2
[XDA]:::::::[H995[::::::FLASH-ABLE MODS V1.5 STOCK-LOLLIPOP FLEX 2
[MEGA]:::::::[H955]:::::FLASH-ABLE MODS V1.5 STOCK-LOLLIPOP FLEX 2
