Relentless ROM v2 - FINAL
Ich hab auch mal wieder was zu sagen :-D Aber nur das es jetzt absolut perfekt ist ;-) Vielen dank RAB
Grüße euch, M@r$
Sorry for using english but its much better than my german.
Firstly, thanks for making this ROM happen! I find the simple look of it really classy. And its works smoothly.
But there is one thing I'd like to ask about: Is there a way to make twitter gtalk/hangout work? I went through thread and didnt find an answer.
Vielen Dank für die viele Arbeit! Alles läuft super...
You can try two ways...
1. Look for a program that can change userapps to systemapps. "Titatanium Backup" can do this, but there are others in playstore ... - maybe that works.
2. You have to resign the app, deinstall it, reboot, and then install the resigned app.
This is the way I did it. On my phone Twitter and Youtube are working as userapps. I can use older versions, the store can't see them and I get no updates. That's exactly what I wanted...
You can use "ZipSigner" for signing. How to? Find via google...
Hi RAB, can you explain how to install? i mean the steps i need follow. Because I flash IRM-1540-0-4073-A01_BFM after I set debugging mode flash IRM-1670-0-4073-A02_BFM. When is ready install RLR_v2.10,RLR_dark,RLR_v2.11,RLR_v2.12, RLR_v2.15 and i think that it's not the correct form. Sorry for my english, i am from argentina. A lot of thanks for the excelent work
The browser fc when i am using 3g. Anyone can help me ?
jajajaja, hola amigo argentino, es necesario el paquete base 2.10, la actualización 2.11 y éste, el 2.15,
Saludos.
PatricioJP
Der ursprüngliche Beitrag von 11:14 Uhr wurde um 11:23 Uhr ergänzt:
...con respecto al navegador, intenta reinstalándolo, o bien prueba con el "Next Browser" suerte ;)
Saludos.
PatricioJP
Gracias hermano, anoche pude hacer que funcione bien, pero me tira lo del browser, es rarisimo, ya reinstale y todo. Esperare alguna solucion de alguno.
Thanks brother, last night i could installed correctly RLR, but still don't work the browser, i wait for another solution from someone.
There is no other solution at this time. The browser crashes since my last changes and I don't know why... - I will try some things next weekend.
I don't use the android browser because there are better and faster apps like "UC Browser", which is - with my changes - faster than ever.
I don't use the android browser because there are better and faster apps like "UC Browser", which is - with my changes - faster then ever.
Ok man i will try with that browser. Thanks!
or I might just uninstall the apps and install them again which somehow solved the problem...
Is there anything you can do about this 10% battery indicator steps? It should be less in my mind, 1% optymally, but 5 would also do the trick.
thanks for help :) keep up the good work!
So nach flash auf 2.15 , Browser stürzt immer noch ab. Was nun?
Gesendet von meinem XT615 mit der Android-Hilfe.de App
Damit sollte der Standard-Browser auch wieder im 3g-Modus funktionieren...
  • Wer einige Google-Apps vermisst, oder Ärger damit hat, kann das neue ROM v2.16c auf der ersten Seite probieren
  • For the people who are missing (or have trouble with) some Google apps: Try the new ROM v2.16c from the startpage
Grüße, RAB
  • RLRupd_v2.16.zip
Reaktionen: olderpin, monstercaos, Modders Vision und 4 andere
Respekt, dass du so viele Updates machst, ich komm schon nicht mehr mit... :thumbsup:
Ich habe jetz lange keine Updates machen können, mein letzes ist 2.11, muss ich jetzt alles nacheinander flashen? (also 2.12; 2.13; ...)
Ich habe ausversehen mal die Systemapp "Zertifikat-Installer" gelöscht, jetz habe ich sie wieder installiert, aber wie bringe ich die jetz wieder in den Systemspeicher?
2.11 -> 2.16, das reicht
Im einfachsten Fall mit dem ES Explorer von /data/app nach system/app verschieben. Kann funktionieren, aber nicht alle Apps spielen da mit.
Oder mit "Titanium Backup" kann man User-Apps in System-Apps umwandeln...
Reaktionen: Modders Vision
Danke, es hat funktioniert den Zertifikatinstaller wieder ins System zu verschieben :) Damit müsste ich jetzt auch die lästigen Ordner mit Icons in meiner Bibliothek dauerhaft los sein :)
Titanium Backup werde ich mir trotzdem mal kaufen, weil ich finde, dass man damit echt super Sachen machen kann :)
Und jetzt zum neuen Update:
Als ich mein otoluxe entspeert habe sind mir fast die Augen ausgefallen!
Danke, dass man nun endlich im entspeerbildschirm sein Hintergrundbild sieht :)
Mach weiter so :thumbsup:
Irgendwie hab ich ein Problem mit der Tastatur :confused:Und zwar setzt die ab und zu aus. Z.b. wenn ich eine Nachricht bekomme und möchte zurück schreiben kann es sein das ich noch etwas warten muss bevor die Tastatur auf das reagiert was ich eintippe! :banghead:Weiß jmd Rat?
Vielleicht wäre es für die Profis hier gut zu wissen, welche Tastatur du benutzt. Ich hatte ein ähnliches Phänomen mit der Swiftkey Demo-Tastatur, was mich dann dazu veranlasst hat diese nicht zu kaufen, obwohl sie sonst echt klasse ist.
Bei mir hat es damals manchmal schon geholfen, einfach das Display zu sperren und wieder zu entsperren.
Noch die Standard Tastatur. Hab noch keine weitere installiert.
Nun, an der hab ich jedenfalls nichts geändert. Hätte gern eine andere eingebaut, aber die will irgendwie nicht als System-App...
Musst Du schauen ob das bei allen Programmen so ist, oder nur bei bestimmten. Möglicherweise bremst ja auch irgendwas Dein System aus.
Kannst auch mal versuchen via CWM-recovery Cache und Dalvik-Cache zu löschen. Eventuell bringts was.
RAB
  • RAB
2 3
Argonlegends
Argonlegends
RAB
M@r$
M@r$
RAB
  • Angepinnt
  • RAB
xadres
X
