Black_Focus
Dauergast
- 622
So, dann stelle ich euch mal eine Stock basierte Rom für unser Galaxy S7 vor!
-SuperMan-Rom-
Features:
- Based on latest G935FXXS1DQK1 Nougat base
- Prerooted with SuperSU V2.82 SR5, Phh root r310 or MagiskSU (choose in aroma)
- Magisk V14.4 (aroma selectable)
- Latest Busybox installed (1.27.2)
- Aroma installer! with support up to 4GB zip files
- Full edge support features support
- Adblocker enabled or disabled (choose in aroma)
- Full rom control!! V2.1
- Zipaligned
- First fully deodexed rom without odex framework
- Rom informations and logo
- choose IOS or stock emojis in aroma
- DM-Verity disabled
- Force encrypt disabled
- ADB fully working
- Modded SystemUI with many tweaks in RomControl
- Applock feature supported
- Floating Message support
- Many csc tweaks!
- No sms to mms auto convertion
- Auto Call recording
- 3Minit Clock/battery in romcontrol
- Custom clock positions and customizations in romcontrol
- LED indicator in settings
- Autostart in settings
- Allow all apps in multiwindow
- USB Plug/Unplug disable wake up
- Remove high volume warning for headphones
- Private mode fixed for all kernels
- Enable TouchKey light duration in RomControl
- Knox stuff is removed
- Stock DQK1 Kernel, SuperStock-Kernel or SuperKernel (choose in aroma)
- Based off from latest touchwiz source available at this moment
- Many apps are selectable in aroma debloat menu now
- Selinux permissive on custom kernels
- UDS - Ultra Data Saving
- quicklauncher in recents app
- Sound Mod with lot improvements! (choose in aroma)
- November Security Patch with Blueborne fix and Krack fix
- Xposed V88.2 included
- Camera Mod included (choose in aroma)
- Many other features, please read changelog to see what changed over the time
Installations-Anleitung:
Links:
Quelle (XDA): XDA-Thread
Rom-Download: Download
Bootloader / Modem: Download
SuperKernel (Custom Kernel): Download
-SuperMan-Rom-
Features:
- Zipaligned
- ADB fully working
- Many csc tweaks!
0.Euer Gerät darf nicht verschlüsselt sein und die OEM-Entsperrung muss aktiviert sein!
1. Ladet die TWRP recovery herunter (TWRP) und folgt den Schritten in der Anleitung!
2. Rom herunterladen und auf die externe SD-Karte kopieren
3. Sichert all eure Daten (Auf die SD-Karte z.b.)
4. Bootloader immer den aktuellen nehmen! Alles andere wurde nicht getestet vom Entwickler! Ladet ihn hier herunter: here!
5. Installiert den Bootloader und das neuste Modem mit odin3.10.7 mit den CP und BL Tabs.
6. Anschließen bootet in die Recovery.
7. Nun einen Full-Wipe durchführen(in TWRP: wipe, advanced wipe,Wählt hier alles, außer den Ort wo ihr die Rom.zip hinkopiert habt [am besten auf die SD-Karte]!)
8. Installiert die Rom
9. Startet neu und wartet ca. 10 Minuten (Deodexed roms brauchen immer etwas länger)
10. Unterbrecht diesen Vorgang nicht. Wartet ab!
11. Viel Spaß mit der neuen Rom
Links:
Bearbeitet von:
submain
- Grund: aktualisiert... Gruß submain
